Anyone using a Pronto with a Barco?
Z-Photo
Posted: Fri Mar 24, 2006 3:04 pm    Post subject: Anyone using a Pronto with a Barco?
Just looking to reduce the number of remotes laying around the HT
Engineer by Day
Photographer by Night
My Portfolio
secstate
Posted: Fri Mar 24, 2006 3:11 pm    Post subject:
I use a JP1 programable URC-8811 with my Barcos no problem. I believe any universal remote worth its salt should work with Barcos. In fact, I am pretty sure I have seen pronto remote codes out on the Internet for Barcos.
Tinman
Posted: Fri Mar 24, 2006 3:59 pm    Post subject:
I'm surprised there are no Barco codes on remote central.
This space for rent.
Z-Photo
Posted: Fri Mar 24, 2006 4:09 pm    Post subject:
I found one for the 3000
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=prontong&db=devices&br=barco&dv=projector&md=701s&kw=barco&st=&ar=&dt=&so=&pg=1&file=prontong/devices/projector/bar-proj-701s.zip
bar-proj-701s.zip
Pronto-Barco control file
 Filename:  bar-proj-701s.zip
 Filesize:  7.89 KB
 Downloaded:  280 Time(s)
Engineer by Day
My Portfolio
Z-Photo
Posted: Fri Mar 24, 2006 4:13 pm    Post subject:
There are others for the older 1000
Engineer by Day
My Portfolio
secstate
Posted: Fri Mar 24, 2006 4:29 pm    Post subject:
As far as I know there are two sets of Barco remote codes. The pre-2001 versions which are common across the digital chassis Barcos (70x/80x/120x) series and the later codes used on all post 2000 or thereabout Barcos. Those latter codes are the pain in the rear ones to find. Greg when he got the 909s had to buy the orginal remotes from Barco. In any case the 701s should work fine with your 808 and 1208 Barcos.
Z-Photo
Posted: Fri Mar 24, 2006 4:32 pm    Post subject:
Thats what I thought...
Engineer by Day
My Portfolio
Person99
Posted: Fri Mar 24, 2006 4:53 pm    Post subject:
Yep, the codes for my Zenth (Cine 8 Onyx) are different than my 1208/2. The Cine series remote is also nicer looking and has a cool red backlight.
Anyway, I hate touchscreen remotes--I gotta have buttons! I was able to learn all the codes for both the old and new Barcos to my Home Theater Master remotes. I currently use an MX-500 in the theater. I love it because it is such a powerful remote the PJ gets the bounce off the screen with no problem. Heck, my IR light control on the back wall gets the bounce of the screen (that is 11' to the screen, then 18' back to the light sensor!).
secstate
Posted: Fri Mar 24, 2006 5:15 pm    Post subject:
Yeah you are right the newer Barco remotes are much nicer. Of course for the $400 bucks they cost from Barco they should be. I tried to program a JP1 remote for the newer Barco but at the time at least, I could only find the pronto version and the conversion to JP1 wasn't very good so I gave up (since they weren't mine 909s).
Ridebreck
Posted: Fri Mar 24, 2006 5:32 pm    Post subject:
I agree. Popcorn and Prontos weren't a good mix when I had mine. Very Happy
"Hooray Beer!!"
Posted: Fri Mar 24, 2006 6:09 pm    Post subject:
I've been using a Pronto for years with Barcos. See my Photo Album for the layout I use.
Pete: There are tons of Barco CRT projectors on remote central: 701s, 1208, 808, 808s, Cine7, Cine8, 800
See here:
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?kw=barco&st=1&fc=--&area=pronto&db=devices&br=&dv=&dt=&so=
Z-Photo
Posted: Fri Mar 24, 2006 6:50 pm    Post subject:
Kal,
Yeah those were the same ones I found.
Even a Guy K ccf. too funny..
Engineer by Day
My Portfolio
Heywood Jablome
Posted: Sat Mar 25, 2006 7:01 pm    Post subject:
Graphics 801 and Pronto-Neo is a no-go... The Neo can't reach high enough, apparently.
Posted: Sat Mar 25, 2006 8:38 pm    Post subject:
Tons of Barco IR and rs-232 codes at Crestron Wink Otherwise, I have a 10-lb sledge you can borrow to coax that Barco to do what you want. Laughing
Heywood Jablome
Posted: Sat Mar 25, 2006 8:50 pm    Post subject:
No need, Howie... Barco's have their own branded accessories:
http://www.barcotools.com/product_info.htm
Posted: Sat Mar 25, 2006 9:11 pm    Post subject:
I think the post maul looks midevil enough to be a strong contender for the job Wink
Z-Photo
Posted: Sun Mar 26, 2006 3:39 pm    Post subject:
Those are only for uppied Ampros.
and any digital - (makes the picture look better)
Engineer by Day
My Portfolio
Posted: Sun Mar 26, 2006 6:07 pm    Post subject:
You have to have the arms sufficient to even pick it up Wink
Did you sic Troy on me over at AVS. He's ragging on AmPro's big time. I backed him into a corner and he came out like a wild dowg. He's correct in saying that the Marquee is ultimately a better projector but, he's completely wrong about the later models of AmPro, once you get past the code thingy Wink
Z-Photo
Posted: Sun Mar 26, 2006 7:39 pm    Post subject:
Nope,
Troy is wierd all by himself - no prompting by me. He was going after Mike for a bit.
Engineer by Day
My Portfolio
PsychoDogBeast
Posted: Mon Mar 27, 2006 2:13 pm    Post subject:
Hi there
My mates been using an original pronto for the past couple of years for his data 808s, ive used it on my 701 & 808 numerous occasions too, ive got the ccf files stored somewhere if you would like them.
James
Rockford Fosgate made me deaf!! Sad
