Water instead of glycol?
Goto page 1, 2, 3, 4, 5, 6, 7  Next
antorsae
Posted: Fri Jul 30, 2010 7:52 pm    Post subject: Water instead of glycol?
Anybody done it? Side-effects?
Posted: Fri Jul 30, 2010 8:02 pm    Post subject:
Hello
All water in an LC glycol chamber might have focus issues to to difference in density; the fluid IS the lens. You can add five or ten percent water to top off a glycol load, probably with no visible effect.
Posted: Fri Jul 30, 2010 8:17 pm    Post subject:
Index of refraction of water is 1.33, glycol is 1.4318. So there's a 7.5% difference in refraction.
Water seems like a bad thing to use in a chamber like that, but if it can handle glycol's corrosive properties, it should have no problem with water. But you have to assume they used something nasty like glycol for a reason.
Posted: Fri Jul 30, 2010 8:55 pm    Post subject:
Hello
They use glycol for its' antifreeze properties. You can't have tubes exploding during shipment due to ice in the winter. If time permits next week I'll fill a Marquee tube with just water and see how it looks.
Posted: Fri Jul 30, 2010 9:36 pm    Post subject:
Chip said you need distilled water or some type of hospital grade 100% pure water. I forget which one but he did use it or at least try it.
Posted: Fri Jul 30, 2010 10:03 pm    Post subject:
Isn't distilled water more corrosive than tap water? But again, probably less so than glycol.
antorsae
Posted: Fri Jul 30, 2010 10:35 pm    Post subject:
Hi Tim.
I'll be nice if you can test the water thingy!!!
I don't think any of us in Souther Spain or Scottsdale are going to get our projectors frozen... It's like 90F here now and it never freezes in the winter either....
Posted: Fri Jul 30, 2010 10:44 pm    Post subject:
Why not just use glycol ?
antorsae
Posted: Fri Jul 30, 2010 10:52 pm    Post subject:
If given the choice, I'd rather use water than glycol, why?
- Glycol corrodes electronics
- Glycol harder to procure than water
- Glycol corrodes aluminium, fungus may develop
- Glycol absorbs water, depending on your bellows, you may develop leaks
- Glycol is highly poisonous
Glycol is just so messy... It's actually (along with the HV crackle which freaks me out) one thing that I don't like about CRT.
Water may have side-effects to prevent its use. I wish the only one is the freezing one as I doesn't apply in my area - but others here may know better.
Posted: Fri Jul 30, 2010 10:55 pm    Post subject:
Don't bother, I've already tried it. It kicks-ass at first. Ultra sharp focus. Just about as good as a AC projector. However, I left one alone for about a year out in my shop. It had mega fungus. Crying or Very sad
Posted: Fri Jul 30, 2010 11:04 pm    Post subject:
Ah haaa!! I knew there was a reason why you went to Glycol with the Thomas Tubes.
Posted: Fri Jul 30, 2010 11:05 pm    Post subject:
*Organic* fungus, or metal-growing type fungus?
Living stuff might have grown in water. I would think if you used distilled water with a good shot of chlorine you might be able to avoid that, but I don't know how long the chlorine would keep stuff at bay. I would think a good shock of chlorine when you poured it in ought to sterilize the inside of the chamber so nothing (living) would grow in there.
Posted: Fri Jul 30, 2010 11:10 pm    Post subject:
Where do you live ? I would never use water and Chip as I remember switched back to glycol due to corrosion from the distilled water.
Can you buy this where you live ?
http://www.mcmelectronics.com/product/20-4275
antorsae
Posted: Fri Jul 30, 2010 11:20 pm    Post subject:
Hi Tom,
I do have a good reserve of mono-ethylene glycol and glycerin to do the 70/30 mix. No issues on the availability front.
I am in the process of re-bellowing my tubes hence the question. I am re-bellowing b/c it's been only a year since I changed glycol in the PJs and even though I left an air bubble in all tubes the bellows are hard as **** (!)... I live in a humid area so I guess old VDC bellows just tend to absorb a lot of water... and I don't want to have glycol leaks over my head...
Maybe I will try this in a test projector I have with a drop or two of bleach in the water... wait...
Chip: did you have fungus AND corrosion?
Can water corrode the chamber more than glycol?
Posted: Fri Jul 30, 2010 11:25 pm    Post subject:
"*Organic* fungus, or metal-growing type fungus?"
Ohhh for sure it was organic. Big black crawly things Wink
Now to be honest, I wouldn't give up all together on the idea of medical grade water. Something like that industrial grade anti-fungus agent like the schit they give you to put a couple of drops in a water bed might just do the trick. Perhaps even a couple of drops of bleach might just do it.
The other thought is, was it the water or did I just not get it clean enough.
Hmmmm.........................Vodka Thumbs Up
tse
Posted: Fri Jul 30, 2010 11:53 pm    Post subject:
Way back in the middle 80's the coolant for the ESP (which became Esprit, then Ampro) CRTs was half and half distilled water and glycerin. The housings were plastic and zinc. Some lasted for years and stayed clear, some corroded up real bad.
I was stationed at the Rota naval station (near Cadiz) when I was in the Navy middle 70's. One of the nicest places I've ever lived.
Scott
Thomas Jefferson
Chip I think you just had an AmPro infestation Wink
grogthegreat
Posted: Sat Jul 31, 2010 12:49 am    Post subject:
From someone who is into watercooling computers: You would need to put a very small piece of silver into the water. The silver will kill and prevent any infestations. Might be worth giving it a try if there are significant focus improvements like Stefuel reports.
First projector: Sony 1252q with 3500 hours
Second projector: NEC 9PG+
current projector: Sony G90
100" 3:4 draper screen.
I must keep upgrading till the voices stop!!
"I CAN HAZ CRT PRUJEKTER."
-Curt Palme
antorsae
Posted: Sat Jul 31, 2010 7:37 am    Post subject:
Silver + distilled water... sounds like a fun project!
Do you think chamber corrosion would be an issue? How much silver?
antorsae
Posted: Sat Jul 31, 2010 11:25 am    Post subject:
Would this http://www.petrastechshop.com/sikibyia.html work?
Distilled water + $7 per tube sounds like a real deal to me!
Page 1 of 7
