CRT pricing in 1997
cinema mad
Posted: Mon Jul 19, 2010 3:22 am    Post subject:
Mark_A_W wrote:
Cine 9 is worth about $3k tops.
XG LG/G70 maybe $1k, if you can find a sucker.
And it's all downhill from there.
Have you seen what a $3k digital can do these days?
Mark mybe so in the USA but can you point me to A
low hour G70 in good condition for 1K here in Aus ?..
Cheers..
Posted: Mon Jul 19, 2010 3:24 am    Post subject:
JOneil wrote:
Mark_A_W wrote:
But the SXRD is better in every other way.
Except for bulb life, and projector life. How many bulbs and digital projectors would you go through just to equal the life of 1 CRT projector? Add that cost up to see how it equals out. Being close to CRT in picture quality is just a slim part of the equation.
Very Happy
You are kidding me right?
I just swapped chassis, for various reasons, but one main reason was my Green tube had 2.40:1 wear showing. I was running 75% contrast.
At 600 hours. SIX HUNDRED. And the damn thing cost me $600.
I think almost any bulb in a HT projector does better $/hour than that.
600 hours was 6-7 years. 1500 hours on a bulb and two bulb changes per projector would be fine.
I don't think that's a valid argument anymore. I used to, till I saw my green tube wear.
JOneil
Posted: Mon Jul 19, 2010 3:25 am    Post subject:
stefuel wrote:
I now have zero interest in CRT. I will service mine until the new set of tubes is done then it's done. It will be replaced by most likely a LED digital projector or giant LED flatscreen. No more dicking around with cables, adapters and wall warts.
No more tweaking or modding. Just turn it on and enjoy. Just the thought of gutting my rack of all that un-needed wire, replaced by a couple of HDMI cables, makes me feel warm and cozy all over Thumbs Up
Make sure you but 2 projectors, one to use and the other for when the 1st one blows up. Oh, and a case of bulbs too so you can get the same hours you got out of your crt projector. Oh, you said LED, make that a case of LEDs, red preferably. Wait, maybe add a couple more digital projectors to that equation. Laughing
And if you go flat panel, make that a case of flat panels (24 to a case) to equal CRT life. Soooo, $1500.00 per panel times 24, equals? I'm not good at math. Can someone else figure it for me. Very Happy
JOneil
Posted: Mon Jul 19, 2010 3:29 am    Post subject:
Mark_A_W wrote:
Very Happy
Thats cause you have an XG, one of the biggest tube eating machines out there. You probably would win that argument with an XG. But 600 hundred hours? I'm not going to comment.
Posted: Mon Jul 19, 2010 3:31 am    Post subject:
Cheers..
No but would you accept an XG instead? Wink
Posted: Mon Jul 19, 2010 3:32 am    Post subject:
JOneil wrote:
Mark_A_W wrote:
Very Happy
So, it would be different with a G70?
I guess it would be with a 1292...
Who is this guy anyway?
JOneil
Posted: Mon Jul 19, 2010 3:37 am    Post subject:
Yes I have. I've seen them burn out or blow up bulbs prematurely, burn up ballasts, destroy power supplies and depending on technology, shatter color wheels, light tunnels come apart, polarizers burn up, LCD panels fry, DMD panels and driver boards stop functioning properly.
Oh yeah, I've seen all sorts of new digitals. Laughing
Posted: Mon Jul 19, 2010 3:47 am    Post subject:
Mark_A_W wrote:
Very Happy
I'll raise you a 326hr/$465 hitachi globe.
Posted: Mon Jul 19, 2010 6:37 am    Post subject:
I'm sure we can find all sorts of examples.
Has anyone really got 10000 decent hours out of a CRT? No way. And I've fixed enough of them (10+) to know they are not that reliable, but they are repairable.
I love my CRTs, but I think the end is nigh. Not sure. It's not longer a no-brainer like it was a couple of years ago.
I was seriously impressed by the Sony HW15, and seriously unimpressed by my green tube.
huggy
Posted: Mon Jul 19, 2010 8:16 am    Post subject:
I'm with Mark on this one.
Crt tube life/cost vs Bulb is a non issue anymore.Bulbs can be had for about 300 and replaced every one or two years,so non issue really.Replacing CRT tubes is costly and time consuming.
Get a Digital with a good warranty and you're right until the next upgrade.
Don't get me wrong,I love my 1209s and can't bear to part with it,I have 2 sets of spare lugs to burn through so I'll have this darn thing for a while yet Very Happy
Posted: Mon Jul 19, 2010 9:51 am    Post subject:
Copied from another forum on bulbs:
Please post experience of JVC HD750/350/550/950 bulb lifetime / lamp brightness drop
I can't speak for the JVC line, but a couple of years ago I tracked about a dozen lamps in various projectors. The average was about a 50% decrease in brightness right around 500 hours. After they reached the 50% point I stopped tracking them, as I personally consider that the point where they need to be replaced. The longest lasting lamps back then were from Sim2 and the shortest ones were from Optoma. YMMV....
This is the main reason that I'm going to wait for an led (or laser)-illuminated product before I upgrade again. I would be happy with even 500 lumens if it remained that over its (long!) lifetime.
I have just over 600 hours on my bulb and had my HD750 calibrated this weekend. We had to turn up the bulb in order to get a proper calibration since the bulb had dimmed considerably. At this rate, I will probably have to replace the bulb at 1000 hours...not the 1900 it is said to be rated for. Not to mention will have to have a tweaking done on the calibration as well. Please let me know if anyone has a reliable source for bulb purchasing.
Thanks.
This is one reason why it's hard spending $4k-$5k for a projector when the bulb dims so much. I didn't have any issues spending this on a top end plasma but it's disappointing that FP quality changes because the bulb dims at such a fast rate. Thankfully my average seems to be about 250 hrs/yr on my bulb (FPJ1) since I only use it for movies.
I have never used a projector yet that I didn't have to change out the bulb well before it's stated life ( or anywhere even close ). Loss of brightness, or using " too big a screen " ( or both ) is IMO front projections " dirty little secret ". I don't think I've gone beyond 500 hours on any projector before putting a new bulb in except for my dVision 1080p ( which uses 1 or 2 bulbs at the same time - I still changed out the first bulb at 875 hours with both running ).
http://www.avsforum.com/avs-vb/showthread.php?t=1223098
kschmit2
Posted: Mon Jul 19, 2010 12:43 pm    Post subject:
Mark_A_W wrote:
Very Happy
Why 75% contrast on the XG?
Weren't they default 60%, as opposed to the PG and GP series?
Posted: Mon Jul 19, 2010 1:01 pm    Post subject:
Well, it depends on the Sub Cont pot.
I did the white balance myself on that chassis, and the pot was probably a little low.
The new chassis is at 60% for roughly the same output. Which is just before the image gets a bit blurry.
yonexsp
Posted: Mon Jul 19, 2010 1:32 pm    Post subject:
+1 The new HW15 just blows me away, jaw dropping
Clarence
Posted: Mon Jul 19, 2010 4:09 pm    Post subject:
No way? Really?
I've gotten over 10000 hours out of my G90... over 13K last time I looked... probably closer to 15K now.
I've still got spare tubes on the shelf, but since the picture is still several notches above decent, I still don't feel compelled to swap them out. Hopefully I'll get another 10K-15K out of the next set of tubes.
Posted: Mon Jul 19, 2010 4:28 pm    Post subject:
I've said it before, I'll say it again, the big difference is the life of the chassis. ANYTHING new electronics today, be it computers, flat screens, MP3 players, etc are designed to last 3-5 years. CRTs can still be running strong at 20+ years old with minimal repairs.. and repairs can be done to CRT.
I agree, the tube/bulb issue is not really an issue any more due to bulb pricing, but if you've spent $300 on a new bulb and the chassis dies on a digital, you're out $300. If a CRT chassis fails after you retube it, you can get the failed board repaired, or heck, even take the tubes and put it into another chassis. You can't do that with a digital.
Posted: Mon Jul 19, 2010 4:30 pm    Post subject:
Clarence wrote:
No way? Really?
I've gotten over 10000 hours out of my G90... over 13 last time I looked... probably closer to 15K now.
Wow.. 15 thousand hours. That's about 30 lamps for the same hour count. But I'm only counting the QUALITY lamp hours of a bulb. Considering what I've read about digitals only getting about 500 hours before the lamp starts to degrade.
Well, you can still watch a digital beyond the 500 hour mark, though it could have problems with color balance once it exceeds the quality hour use.
Just a thought...
benareeno
Posted: Mon Jul 19, 2010 8:53 pm    Post subject:
You can get a humdinger of a digital projector now for 2k....it could easily last 5 years where the replacement will be 2k and likely have unreal picture quality.
Crt is dead and worthless...anyone trying to sell one would agree..so, why the discussion?
The bull case for crt is effectively dead in every conceivable way...and from every conceivable angle.
I was at a digital friends house the other day...his bulb is over 3000 hours and still looks good. In fact, it may even look better than when it was new...lower output mimicks crt. Every digital I owned, I used with an ND filter to take the brightness edge off.
When this XGLC has had it's day, I won't even consider another crt...I think Smile
JOneil
Posted: Mon Jul 19, 2010 10:07 pm    Post subject:
These digital vs CRT threads are just comical. The battle just keeps going back and forth. But whats interesting is that when REAL component level techs post they are just saying dont be brainwashed into thinking these digitals will last as long as CRT even "IF" PQ of the digital is closing in on CRT. And dont be fooled by some that say that you can't get 10s of thousands of hours on a well set up CRT.
There will always be those who are better fit with a digital, without a doubt. Hell, even 5, 10 15 years ago when digitals were real crap they were still sold by the thousands. Some people just dont have the know how or ability to have a CRT projector.
For some the cost is not relevant so bulb replacements and burned up projectors at low hours doesn't matter. And for them digital would probably be best also. There are many reasons to have digital.
But for those with limited initial budget and not much budget for a replacement projector or bulbs and have the ability to learn how to setup a crt even at a basic level, these are still the true CRTers. And you cant change that because they cant afford it. And by telling them they are (something)for wanting to stay with CRT will just piss them off.
There are many very happy CRTers, so leave them alone.
SO basically, if you want to switch to digital, go ahead but STOP telling everyone else that its the only way to go. Because your wrong. The way to go is what one person chooses to do based on their own reasons.
And lastly from a techs point of view, digitals don't last long, period.
Posted: Tue Jul 20, 2010 6:23 am    Post subject:
If isz nod analog isz crap Laughing
Page 2 of 8
