FAQ: ChromaPure Video Calibration Software
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CurtPalme.com Forum Index -> ChromaPure Products
Posted: Wed Dec 30, 2015 8:10 pm    Post subject:
ChromaPure 3 is now available for download!
This is the most comprehensive upgrade in the product's history. ChromaPure has been completely redesigned to make it more powerful and even easier to use.
Upgrade Pricing from version 2.x is available for existing users. Those who purchased ChromaPure on or after December 18, 2014 are entitled to a free upgrade from version 2.x.
New Features
New streamlined and efficient user interface
Enhanced user-configurable reporting
User-defined automated measurements
Multiple gamma runs on one chart for comparison
12/21 pt selectable Lumagen LUT auto-calibrate
User-selectable dynamic range for grayscale and gamma
dE method selectable by module
System-wide gamma, select once and apply everywhere
Calibration Templates for unlimited customized measurements and reporting
Support for sRGB gamma
Support for Rec. 2020 gamut
To download or order see here:
http://www.curtpalme.com/ChromaPure.shtm
Posted: Wed Jan 13, 2016 1:15 pm    Post subject:
ChromaPure 3.0.3 is now available for download
This is a bug fix release only for version 3.0. All licensed users of 3.0 are entitled to this release free of charge. There will be one additional bug fix release in a couple of weeks.
New Features
N/A
Bug Fixes
The following bugs have been fixed:
Using Meter Correction caused the application to report incorrect dE values for white
The AccuPel generator was not initializing properly
The APL and small window pattern sizes for built-in generator were not working
The Rev B i1D3 meter was not initializing properly
Any license with a large number of meters was not displaying fully on the Home page
Several meters were not detecting the serial number
Accessing the built-in drop-down patterns would cause a fatal exception
The i1D3 meter options in Settings were disabled
The DVDO TPG generator was missing from Professional Licenses
The test patterns were incorrect when using the 75% of Rec. 709 gamut.
To download see here:
Posted: Sat Feb 13, 2016 12:08 am    Post subject:
ChromaPure 3.0.5 is now available for download
This release restores missing features and fixes bugs contained in the initial 3.0 release. It also adds some fixes for long-standing issues that significantly pre-date v3.
The following features have been added, restored, or enhanced:
DVDO Duo support is restored, including auto-cal
RGB and xyY Color Space modes are restored in the Color Management module
User images can be added to Custom Reports
An Application Settings icon has been added to the auto-cal screen
European users no longer have to manually adjust Windows regional format settings. ChromaPure now automatically forces U.S. formats for list seperators and decimal places regardless of the settings in Windows.
ChromaPure now will scale properly on high-resolution, small size displays without user intervention. This is a temporary fix because the application simply automatically adjusts the resolution of the display downwards so that text scaling is not required. This works but results in some loss of sharpness. A permanent solution will be provided in 3.1.
We have added a new item in the File menu called "Repair Settings". Selecting this will close the application, delete the settings file, create a default settings file, and then restart the application. Selecting this option will resolve many issues if instability is apparent.
The following bugs were identified and fixed:
Attempts to take measurements without initializing a meter did not display an error message.
When fL had been selected in the application, the report still showed cd/m2 in the Gamma modules.
Opening the Grayscale module, closing, and then reopening resulted in a benign fatal exception.
If the user failed to click Stop when in continuous mode and navigated to a separate module, continuous mode would still be active. Continuous mode now automatically stops whenever the focus changes from one module to another.
If the user clicked the Measure All button starting anywhere other than white, then the 90% point would measure multiple times.
Reports would not update data if the report module was already open.
A few tooltips were missing.
The Pre and Post-calibration data were switched on the final Advanced Auto-cal page.
Luminance correction was missing from the Contrast module.
Posted: Fri Feb 26, 2016 9:19 pm    Post subject:
ChromaPure 3.0.6 is now available for download
This small release addresses two issues that were important enough to fix now rather than waiting until 3.1. Please uninstall any previous 3.x version prior to installing 3.0.6.
The method for generating RGB values when using the 75% of Rec. 709 gamut has been changed. This pseudo-gamut can now be used throughout the application.
Some problems were identified and fixed in the Lumagen manual control toolbar.
Posted: Fri Mar 18, 2016 8:57 pm    Post subject:
ChromaPure 3.0.7 is now available for download.
It is free for license v3 users.
New Features
Added support for the 4K Murideo signal generator.
Enhancements
These enhancements involve making small changes that lessen the opportunity for error.
In Continuous mode, the user is now prevented from selecting other read modes until Continuous mode is stopped. Also, Continuous mode stops automatically whenever the user selects a different color. Continuous will have to be started again to resume readings of the new selection.
The i1D3 options panel in Application Settings has been removed and optimal settings have been hard-coded behind the scenes.
Bug Fixes
The following issues have been fixed:
When attempting to initialize a serial meter after ChromaPure has started, the system failed to update the list of available com ports.
The installation routine now requires the user to first uninstall a previous version of ChromaPure. Also, the application checks at runtime whether .Net Framework 4.6.1 is installed. If not, then the user is required to first install.
The Quantum Data 801 and 882 signal generators now generate the proper levels.
Posted: Sat May 14, 2016 2:33 pm    Post subject:
ChromaPure 3.0.8 is now available for download.
New Features
Added support for the JETI 1501 spectroradiometer.
Enhancements
Enhanced support for JETI 1211.
Added user selectable wait times between generated test patterns.
Explanation: Some displays require some extra time to settle in after switching test patterns. This option allows to user to increase the default wait time. This feature is set to zero by default and should only be used in special cases when explicitly needed.
Added support for signal generator intensity in session files.
Explanation: If the user saves a calx file after taking measurements with a 75% intensity, then changes to 100% intensity (or vice-versa), continues to work, and then loads the saved calx file, reporting and dE calculation will be incorrect because they will be based on the currently-selected intensity, rather than the intensity used when the file was saved. With this build the intensity is saved in the calx file and restored when loaded.
The measurement order in the Gamma module is now high to low.
For those using a signal generator, when switching between modules the test pattern now updates to reflect whatever color is selected in the active module.
Bug Fixes
The data recovery feature was not working properly and could result in loss of data after a bad shutdown. This has been fixed.
Known issues
Switching rapidly between already-open modules using the navigation toolbar can result in a benign null fatal exception. Switching more slowly or using the tabs for navigation avoids this issue.
Please use DVDO Duo auto-cal with 100% intensity test patterns only. Support for 75% patterns will be restored in 3.1 when auto-cal in general will receive a substantial refresh.
Posted: Tue Jan 03, 2017 7:54 pm    Post subject:
ChromaPure 3.1 is now available for download.
This is a major release in which ChromaPure has been completely re-written on a new platform.
New Features
New tablet-like user interface. The classic interface can also be selected in application options.
Support for UHD Rec. 2020 and HDR10 EOTF.
New Screen Uniformity module.
Enhancements
Redesigned Color Gamut module.
Enhanced reporting cover page.
Enhanced Color Management module.
New Advanced Auto-cal engine.
Redesigned and simplified Meter initialization and Test Pattern generation components.
Meter Correction integrated with Meter Initialization.
Bug Fixes
The new platform allows for optimized display quality for high-resolution screens. The problems with text scaling on high res screens has been resolved.
Improved stability for auto-calibrate.
Known Issues
DVDO Duo auto-cal is not included in this build. The Duo can still be used as a signal generator and for standard calibration tasks. Duo auto-cal will be included as part of the first maintenance release in January.
Posted: Fri Jan 06, 2017 9:26 pm    Post subject:
ChromaPure 3.1.1 is now available for download.
Bug Fixes
The code that accommodates international regional formats was not included in the initial 3.1, which led to unexpected behavior on non-English language PCs.
Attempting to switch between the default tablet UI and vertical or horizontal versions of the traditional UI caused the application to shut down.
There was no intensity selector when the Calibration Disc mode was selected.
The Color Management module suffered from various types of instability and unexpected behavior.
Posted: Tue Feb 07, 2017 9:09 pm    Post subject:
ChromaPure 3.1.2 is now available for download.
Bug Fixes
Version 3.1.2 has been released to fix a problem with the luminance measurements of color in HDR10 mode.
Posted: Thu Feb 16, 2017 9:38 pm    Post subject:
Note: The CHROMAPURE GRAYSCALE & COLOR CALIBRATION FOR DUMMIES guide has been updated!
- Added ChromaPure 3.1 support (all new screenshots and instructions)
- Added Rec. 2020/UHD/HDR support
See: https://www.curtpalme.com/forum_archived/viewtopic.php@t=35322.html
Posted: Thu Feb 16, 2017 9:40 pm    Post subject:
ChromaPure 3.1.3 is now available for download.
Enhancements
We have simplified the X-Rite i1D3 initialization procedure. We have eliminated auto-detect and provided the user with the ability to select 25Hz, 50Hz, or 60Hz as the sync value.
We added degamma to HDR10 which allows ChromaPure to support HDR10 using external signal generators.
Bug Fixes
There was a cluster of problems regarding importing calx session files:
- 3.0.8 calx files did not import correctly. The gamut data in the CIE chart is still broken. This will be fixed in the next release. All other issues were resolved.
- When double-clicking calx files the application would open, but no data would appear.
- Imported calx files did not show average summary data.
- Imported calx files that contained auto-cal data prevented the user from accessing the data logs and full color information.
When clicking Measure All without having a meter initialized the system would generate a lengthy loop of error messages.
There was a refresh problem that occurred when changing Color Intensity. The values did not update in Color Management until the user restarted the application.
There was a refresh problem that occurred when changing the Reference Gamut. The saturations for the gamut did not update. NOTE: When changing the Reference Gamut you will lose all of the data from the previous gamut. If you want to keep this, save the data first or run a report.
Load and Save were missing from the classic UI.
The Signal Generator drop-down would not allow the user to access all of the test patterns.
Posted: Fri Feb 17, 2017 10:15 pm    Post subject:
UPDATE:
The "Lite" version of ChromaPure has been discontinued.
Until the end of February 2017, we are allowing existing ChromaPure Lite users to upgrade to ChromaPure Standard for $49 instead of the regular $100 price. After that time upgrades will no longer be possible.
This upgrade is eligible for older v2 versions ChromaPure as well. Upgrade for $49 and you'll get the latest v3 version of ChromaPure Standard, which is an additional $79 savings.
ChromaPure Standard offers support for 2 meters (instead of 1) and adds the following features to maximize image quality: Gamma, Advanced Color Management, ColorChecker, Reports, Auto-Calibrate, Lumens Calculator, Conversion Utility.
To upgrade your version of ChromaPure, visit our order page: http://www.curtpalme.com/ChromaPure.shtm
For more information on using these advanced features see our ChromaPure Grayscale & Color Calibration for Dummies guide: https://www.curtpalme.com/forum_archived/viewtopic.php@t=35322.html
Cheers,
Posted: Sat Apr 15, 2017 1:05 pm    Post subject:
ChromaPure 3.1.4 is now available for download.
This release is free for licensed 3.x users. With this release we have stepped away somewhat from the bug fix cycle and focused instead on adding several useful enhancements and features.
New features
- The White Balance module now includes gamma information.
- Users can now select a Slow mode for the i1D3. Use this feature only when measuring black level, such as when measuring contrast. This is necessary because the default AIO measurement mode will not read below 0.01 nits.
- We have added support for the Quantum Data 780E signal generator.
- We have added a new gamma reference, HDR10 – Projector. Use this gamma target when calibrating front projectors using HDR10.
- The options module now includes a selection for Gamut Overlay. Select this option to see another color gamut superimposed on the reference gamut. This is useful when calibrating Rec. 2020. It allows you to see how the measured colors fit into other gamuts.
Enhancements
- The Built-in signal generator has been adjusted to facilitate easier use. Users no longer need to rely on a madVR utility to get proper levels.
Bug Fixes
- We have fixed data import problems with ChromaPure 3.0.8 data.
- We have fixed an issue that affected the user’s ability to scroll through the drop down list of individual test patterns for external signal generators.
- We have updated the Excel report to conform to the data structures of 3.1.x.
NOTE: DVDO Duo Auto-calibration will be released soon as part of 3.1.5.
steelgtr
Posted: Fri Apr 21, 2017 6:26 am    Post subject: ft-L reading
Does ver 3 readout ft-L or do you still have to calculate from the "Y" reading?
How do you adjust saturation now?
thx
bob
Posted: Fri Apr 21, 2017 12:07 pm    Post subject:
Hi Bob,
Check out our CHROMAPURE GRAYSCALE & COLOR CALIBRATION FOR DUMMIES step by step guide:
It'll walk you through how all calibration steps are done including the saturation sub-module.
You can also set the software to show Luminance as either cd/m2 or fL.
If interested in ordering at our discounted price, see: http://www.curtpalme.com/ChromaPure.shtm
Cheers,
steelgtr
Posted: Sat Apr 22, 2017 2:45 pm    Post subject:
Hi Bob,
Cheers,
Thanks, kal
I ordered the upgrade and disk from you. I still don't understand the saturation procedure. In the old days it was using red as a percentage of white or ????
Also, I have never been able to use the flashing bars for black level. Is it better to just use solid near black patterns?
Pioneer Elite PRO-101 plasma
thx
bob
Posted: Sat Apr 22, 2017 3:29 pm    Post subject:
Hi Bob,
Thanks for your order! It's best to follow the ChromaPure calibration guide - it'll walk you through everything step by step, including the items you ask about:
steelgtr
Posted: Sun Apr 23, 2017 2:08 pm    Post subject:
Hi Bob,
Cheers,
This is the part that doesn't make sense:
"2.6.1.8. Adjust the display's main color control on the display until you have minimized the red error for red, green, and blue. The human eye is especially sensitive to red errors, so it is best to concentrate on this. "
How do you minimize the red error for anything other than red? (green and blue)?
thx
bob
TomHuffman
Posted: Sun Apr 23, 2017 7:51 pm    Post subject:
The point is that if you see errors for red, green, and blue and you cannot correct them all (which you can't with a Color control), then focus on getting red right.
ChromaPure calibration software & meter packages at CurtPalme.com discounted prices!
steelgtr
Posted: Sun Apr 23, 2017 8:28 pm    Post subject:
Thanks, Tom
My Pio Pro-101 does have CMS but I think I remember it not being very good?
bob
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CurtPalme.com Forum Index -> ChromaPure Products All times are GMT
Page 4 of 6
