Chad B
Joined: 02 Apr 2008 Posts: 11 Location: ISF calibrator
| Posted: Tue Jun 01, 2010 10:38 pm Post subject: Weird green problem on Electrohome 9500LC |
I'm doing a first time setup and calibration of a 9500LC, and am having problems with the green tube (a brand new LUG).
Problems:
1. Green tube blooms and gradually loses focus above contrast setting of 25. By 45, it's looking fuzzy. By 65, it's very poor, and by 75 it starts to bloom severely. Image is way too dim at 25.
2. Green drive has little to no visible effect. When adjusting 6500 col temp preset, the green G2 works, but the green drive does not. R and B drives work properly.
3. Stigmatism is adjusted and in good shape; defocused green dots are round with no flare.
4. Green focus has to be near 0. Anything above 5 or 6 starts to look fuzzy. R and B focus are OK around midpoint, which is 50.
My customer and I would greatly appreciate any help. Thanks!
CZ Eddie
| Posted: Tue Jun 01, 2010 10:44 pm Post subject: |
I would suspect a cable not being connected where it's supposed to be.
Verify cable connections on all modules first (VIM, HDM, Focus). If it looks good, then reseat the connections.
If still having problems, then try swapping all the red cables over to the green and vice versa.
This way, your internal menu should come up on the red tube.
Then try comparing the difference in behavior between red & green.
_________________ Back after a digital sabatical.
| Posted: Tue Jun 01, 2010 11:08 pm Post subject: |
I'd suspect a bad neck card. I would exchange the green and red neck cards...or green and blue. If the problem follows the card, it's the card.
The symptom is similar to a low anode voltage condition. You could have a bad anode lead or it's not making good contact. But this is not to be messed with if you're unsure of how to discharge and bleed off the anode potential before messing with it.
To test this, I'd swap anode leads between green and any other CRT, at the splitter block.
CJ
| Posted: Tue Jun 01, 2010 11:44 pm Post subject: |
Guys, the set came from me, and has one of Terry's greens in it.
I did observe the focus to be best at about 3-4. I know that's low, but tried 2 focus yokes and two HVPS, and that's where it remained. Tube is razor sharp, or should I say..was.. (ran it for 24 hours or so before shipping it out) until the contrast hits about 65, at which point it would defocus. Every new LUG I've had here does that, and I've discussed it here before, and others agree, above a typical contrast range, LUG tubes do defocus.
Absolutely the green drive worked here, I preset the G2s and drives before I send them out, and I would have caught that.
I also agree that there could be a bad CRT socket and MAYBE something happened to the HV splitter in transit. I'll shoot the customer an email to try swapping HV leads out of the splitter. I'll have to send a modded CRT socket down, as the other tubes are LJE tubes.
tse
| Posted: Tue Jun 01, 2010 11:48 pm Post subject: |
The green drive is limited to a very small adjustment range by the firmware. It is only a couple of percent from min to max. Just set it to 92% and use the red and blue drive for the white balance. Adjust the static focus (center area) with contrast at 50% and input video at 0.7vpp (100% white). The tube should focus good there.
Scott
Thomas Jefferson
| Posted: Wed Jun 02, 2010 1:55 am Post subject: |
Isn't there technically supposed to be a modification that should be performed above and beyond moving the bias lead to the appropriate pin (usually pin 6) when using LUG tubes?
If so, would it have any effect on the problem described?
CJ
| Posted: Wed Jun 02, 2010 5:21 am Post subject: |
| cmjohnson wrote: | Isn't there technically supposed to be a modification that should be performed above and beyond moving the bias lead to the appropriate pin (usually pin 6) when using LUG tubes?
CJ | yes, a 1Kohm 1/2 watt resistor bridged from pin 7 to ground I believe
Bitwize
| Posted: Wed Jun 02, 2010 12:01 pm Post subject: |
| CZ Eddie wrote: | I would suspect a cable not being connected where it's supposed to be.
Then try comparing the difference in behavior between red & green. |
Thx for the suggestions. Tried switching the cables as well as reseating connections...did not fix the Green focus issue.
Bitwize
| Posted: Wed Jun 02, 2010 12:08 pm Post subject: |
| cmjohnson wrote: | I'd suspect a bad neck card. I would exchange the green and red neck cards...or green and blue. If the problem follows the card, it's the card.
CJ |
We tried to switch the Red and Green neck boards. Unfortunately, only the Green board is modified to fit the LUG. The Red and Blue are LCP. This is how the set was configured when I received it. Curt is going to send me another Green neck board. I'm not comfortable messing with a bad anode lead, etc.
Side note, on a scale of 1-10, the Red focus is a 10. It looks incredible and Chad (ISF Tech) said he's never seen better focus. It's so razor sharp that I can't imagine anything being sharper. And this is with HD10L lenses and an LCP tube. Makes me wonder if a Green LUG really would give me any advantage over an LCP with my configuration--small screen, short throw. Also, won't the LUG give me less light output?? 30% less or something??
Bitwize
| Posted: Wed Jun 02, 2010 12:10 pm Post subject: |
| tse wrote: | The green drive is limited to a very small adjustment range by the firmware. It is only a couple of percent from min to max. Just set it to 92% and use the red and blue drive for the white balance. Adjust the static focus (center area) with contrast at 50% and input video at 0.7vpp (100% white). The tube should focus good there.
Scott |
OK, we set the green to 92% and contrast as you suggested. This made no difference. The Green still focuses around 25 contrast, but anything higher and it blooms like spring. Thx for the suggestions though.
Bitwize
| Posted: Wed Jun 02, 2010 12:13 pm Post subject: |
CJ |
Are you implying that the neck board might not be completely/correctly modified? Guess it's a mute point now since Curt is sending me a "new" modified neck board. I just hope it's not the tube. I have a "new" 200lb projector hanging in my home theater and the last thing I want to do is change a tube. This experience is disheartening to say the least. Now if I'd spent around $1200 on an 8500, I wouldn't be nearly as stressed :p
| Posted: Wed Jun 02, 2010 12:36 pm Post subject: |
I'm not "implying" anything. Just asking a straight question. The LUG tube is a slightly different animal than the LCP and apparently it gives different results, particularly when mixed into a PJ with LCPs.
But as for the focus range, Tse can answer this question which I'm about to ask:
Does the LUG tube require a different static magnetic field strength for optimal focus, as compared to an LCP?
Marquee yokes can be expected to be calibrated to the static magnetic field strength which is optimal for the LCP tubes (9") or
180DMB tubes (8") and I think that's the same value in either case, 294 Gauss, but as the LUG is a slightly different tube,
it may require a different magnetic calibration value. Scott, is this the case? Do you have a different magnetic calibration value
for the LUG tubes?
If the magnetic field strength of the focus coil is ideal, then when the coil is correctly placed and disconnected from the focus drive
board, then central focus will be very sharp. There are two focus coils in the assembly, a static coil and a dynamic coil. The static
coil is driven to modify the overall magnetic field strength to compensate for slight differences in tubes and in the basic magnetic
strength of the permanent magnets in the assembly. It can add a little field strength, or cancel out a litttle bit. It's driven by a DC
voltage, if I remember correctly. Tse will correct me if I'm wrong about that.
The other focus coil is the dynamic coil. Its field strength is very rapidly adjusted as the electron beam flies across the CRT face,
making small corrections to keep that flying beam in optimal focus at all times It has to make up to three adjustments to the field
strength every single time the electron beam draws a single scan line.
Your LUG tube seems to need a focus yoke that is calibrated to a different value than the regular LCP, OR you have a yoke that is
way off on its magnetic strength. This does happen. If yokes get taken off and just tossed in a box with each other, they can and
will slightly demagnetize each other, especially if there is no keeper ring inserted in the gap. (The keeper ring is a steel tube about the
diameter of the CRT neck and about an inch and a half long. When inserted, it helps to maintain the magnetic field strength of the
permanent magnets in the focus yoke assembly.)
Check this: How is your central focus with the focus yoke totally disconnected from the focus board? (Disconnect the astig cable, too.)
Now reconnect it, find the best static focus value, and try to adjust zone focus. How well does zone focus work?
CJ
Bitwize
| Posted: Wed Jun 02, 2010 1:29 pm Post subject: |
| Nashou66 wrote: | Has anyone thought of swapping focus coil connections.I didn't read the whole thread, it could be a bad mosfet on the green channel. It sounds like an issue i had after i shorted a channel probing around with a scope.
Swap the red focus connector tot he Green and use the red focus in the service menu to adjust.
Athanasios |
Thx for the suggestion, Athanasios. We tried that and determined that the focus board is in good shape.
Bitwize
| Posted: Wed Jun 02, 2010 1:54 pm Post subject: |
| Nashou66 wrote: | I'm wondering if the tube guns maybe got some crud on them in transport. It might cause some voltage irregularities . a few light taps on the tube neck while the PJ is running might solve this issue.
Athanasios |
The projector was boxed up, wrapped in lots of bubblewrap, and on a palette. If there is crud on the tube guns, it would more than likely have been there before leaving Curt
Appreciate all the suggestions from so many of you on the forum! The CRT community is very supportive
| Posted: Wed Jun 02, 2010 2:01 pm Post subject: |
| Bitwize wrote: | [
No, he's talking about contamination/crud on the electron gun within the tube. This is what I'm suspecting as well, but we'll try the CRT socket first.
I realized this morning that I have a LUG tube here in a BArco housing. It will take a bit of playing, but I'll put that into my test 9500 LC and will play with the tube and neckboard to check a few things. I'll get the neckboard out tomorrow regardless though.
Bitwize
| Posted: Wed Jun 02, 2010 2:10 pm Post subject: |
| Curt Palme wrote: | | Bitwize wrote: | [
I realized this morning that I have a LUG tube here in a BArco housing. It will take a bit of playing, but I'll put that into my test 9500 LC and will play with the tube and neckboard to check a few things. I'll get the neckboard out tomorrow regardless though. |
OK, I understand what you're saying. Why not go with a new LCP and a neck board that matches the Red and Blue? As I said, I don't see any focus advantage with a LUG (in my setup) and I'm going to get less light output from the LUG. Only saying this as my Red LCP looks razor sharp with the HD10L lens on my small screen. 1080p, 1 on/off lines are completely resolved...sharp as a tack.
| Posted: Wed Jun 02, 2010 2:19 pm Post subject: |
| Bitwize wrote: | | Curt Palme wrote: | | Bitwize wrote: | [
OK, I understand what you're saying. Why not go with a new LCP and a neck board that matches the Red and Blue? As I said, I don't see any focus advantage with a LUG (in my setup) and I'm going to get less light output from the LUG. Only saying this as my Red LCP looks razor sharp with the HD10L lens on my small screen. 1080p, 1 on/off lines are completely resolved...sharp as a tack. |
Red is always sharper than any other color . I noticed this before as well and asked in another thread somewhere. I do not remember who but one of the more knowledgeable and engineer types here said it has to do with the inherent physical properties of the phosphor. Something along the lines of the red phosphor tends not to scatter the electrons to surrounding phosphor as much as the green and blue. I might have the exact details wrong but it has something to do with that.
I always thought it might be because the red is further away from the HDM which causes lots of airborne noise.
Bitwize
| Posted: Wed Jun 02, 2010 2:41 pm Post subject: |
| Nashou66 wrote: | | Bitwize wrote: | | Curt Palme wrote: | | Bitwize wrote: | [
Athanasios |
Interesting info. Thx for sharing! Well, right now my Green is not even close to the sharpness of the defocused Blue
