studio
| Posted: Tue May 25, 2010 8:56 pm Post subject: Win 7 & Powerstrip with Barco 1209s |
Have a ATI HD4890 1g card. Using 2nd head for pj. Can not seem to get windows to see the custom resolutions created in Pstrip. Need to know how to fix.
akajester
| Posted: Tue May 25, 2010 8:59 pm Post subject: |
Hey Studio, don't you just set it in powerstrip and go? I don't think I've used the ati control panel or windows after installing powerstrip and setting it up.
studio
| Posted: Wed May 26, 2010 2:57 am Post subject: |
Win 7 doesn't work that way. Needing a EDID file for barco.
akajester
| Posted: Wed May 26, 2010 3:27 am Post subject: |
try manually loading a inf file for the "monitor". I'm using windows 7, ATI and powerstrip and don't think I have this problem.
http://www.videoi.com/~pietro/monitor/
studio
| Posted: Wed May 26, 2010 10:49 am Post subject: |
How do you set it up for the different film formats? 4:3, 16:9, 2.35:1, 2.40:1 etc? In powerstrip can you change the pixels at will. I have made custom resolutions inside PStrip but win7 won't let them be active. I have Admin rights on everything.
akajester
| Posted: Wed May 26, 2010 11:48 am Post subject: |
I run 1080i@96 with my bg808s. I mostly feed it bluray movies but some 16x9 content. I don't change anything in powerstrip when I switch between formats. I thought about making some masking but haven't got around to it yet.
studio
| Posted: Wed May 26, 2010 12:51 pm Post subject: |
In Pstrip you can setup different setting to deal with the format changes. This is what I'm trying to do.
studio
| Posted: Fri Jun 04, 2010 2:20 am Post subject: |
I'm not sure what is going on. I can't seem to get any image on the pj out of the computer setup now. I had just got it working with Pstrip @ 1920x1080p last week. If I hook up 2 lcd's to the ATI HD4890 card they display fine. I have been having power issues. I borrowed a 550w PS to see if the problem would go away, but it didn't. Once in a while I will get a faint blackened image, it's skewed. I can get an image fine with my PS3 & a HDFury2 (see screenshot thread). Is there a resolution that will be easy to display without special timing. Not sure what to do??
| Posted: Fri Jun 04, 2010 10:28 am Post subject: |
| studio wrote: | | How do you set it up for the different film formats? 4:3, 16:9, 2.35:1, 2.40:1 etc? In powerstrip can you change the pixels at will. I have made custom resolutions inside PStrip but win7 won't let them be active. I have Admin rights on everything. |
Why would you?
Just run 1080p at 72hz and be done with it.
If you need to run a multiple of 25fps for Euro tv, setup a 75hz res as well.
You can created powerstrip command line shortcuts to change refresh rate, like this for 1080i 96hz:
"C:\Program Files\PowerStrip\PStrip.exe" /target:1 /t:1920,112,128,115,1080,46,7,30,126874,542
| Posted: Fri Jun 04, 2010 10:30 am Post subject: |
| studio wrote: | | I'm not sure what is going on. I can't seem to get any image on the pj out of the computer setup now. I had just got it working with Pstrip @ 1920x1080p last week. If I hook up 2 lcd's to the ATI HD4890 card they display fine. I have been having power issues. I borrowed a 550w PS to see if the problem would go away, but it didn't. Once in a while I will get a faint blackened image, it's skewed. I can get an image fine with my PS3 & a HDFury2 (see screenshot thread). Is there a resolution that will be easy to display without special timing. Not sure what to do?? |
The projector doesn't like the timings you are sending it.
This is nothing to do with the Powersupply in the PC(eh??).
| Posted: Fri Jun 04, 2010 10:32 am Post subject: |
| studio wrote: | | Win 7 doesn't work that way. Needing a EDID file for barco. |
No you don't, you need a monitor driver and you need to turn off EDID in the ATI CCC.
Attached is one for an XG-1101LC. It will do. Edit the max scanrate and rename it if you like.
| Description: |
 Download |
| Filename: |
XG110 monitor.zip |
| Filesize: |
574 Bytes |
| Downloaded: |
356 Time(s) |
studio
| Posted: Fri Jun 04, 2010 12:44 pm Post subject: |
I got it. When I had set my pj up a couple of weeks ago, I had the computer right next to the pj with a short video cord. I had bought a 25ft HD15 to BNC cord. I have had problems since. I moved the computer back close to the pj and it worked. So now the question is what do I need between my pj and the computer? How would I know if this cable is bad?
| Posted: Fri Jun 04, 2010 1:19 pm Post subject: |
Can you test the cable with a CRT monitor?
Do you have one with BNC inputs?
studio
| Posted: Fri Jun 04, 2010 1:45 pm Post subject: |
No I don't. Should you need a amplifier normally for this distance or not?
| Posted: Fri Jun 04, 2010 1:49 pm Post subject: |
Usually not.
But I do use an NEC switcher to drive my cable of similar length.
studio
| Posted: Fri Jun 04, 2010 2:32 pm Post subject: |
I have an svga amp that will drive several monitors 1in/4out. Will try tonight.
studio
| Posted: Wed Jun 09, 2010 1:05 pm Post subject: |
Mark,
It was the cable. Now that I'm getting a image, one of the things I would like to do is to get the pj to project at it's highest possible resolution. Run a test pattern at that resolution to get everything adjusted and go forward from there. I can't seem to get it in windows to go to 2500 x 2000. In Pstrip I create a new user resolution of 2500x2000 it tells me that it needs to restart but I can never get it to this resolution. The highest I have been able to get win to see is 1920x1440. I am using the monitor.inf method. Any ideas?
| Posted: Wed Jun 09, 2010 1:35 pm Post subject: |
Why on earth would you want to go further than 1920x1080?
Higher is not better, it will just get blurrier.
studio
| Posted: Wed Jun 09, 2010 1:46 pm Post subject: |
My thinking was for setting up the pj , focus, alignment, etc only.
| Posted: Wed Jun 09, 2010 2:03 pm Post subject: |
No, you should do it at the resolution you intend to use.
I would use 1920x1080 at 71.928hz on a 1209s.
