The Official G70 Owners' Thread!
barcoed
Posted: Mon Sep 20, 2010 6:44 pm    Post subject:
I fiddled with Porsches (vrrroooomm!) and ended up with the G70 "flipping" between two memory blocks, so I keep to standard these days. Over the years I've spent too much time trying to get everything "just so", consequently (despite what I'm told) I run with "If it looks good, it is good". Very Happy
To quote Slartibartfast: "I'd far rather be happy than right".
Posted: Mon Sep 20, 2010 7:07 pm    Post subject:
You are fine with that res. One of the biggest misconceptions is that you need three times the video bandwidth to display the res. Consequently, a lot of people thought they needed 186 for 1080p60. Thank you, Extron!! Rolling Eyes Rolling Eyes I believe Dizzman over at AVS use to work at Extron and still defends this belief. Confused
If you are running a HTPC, then you only have the computer and the cable in the chain, so there is no degradation to be had between multiple connections.
Posted: Mon Sep 20, 2010 9:51 pm    Post subject:
I use 1080p 59.94Hz as the base scan rate on all the G70's I set up. The G70 won't fully resolve 1080p 60Hz, but it will look very nice none the less.
Htotal = 2200
Vtotal = 1125
_in_peace_
Posted: Mon Sep 20, 2010 11:47 pm    Post subject:
Spanky Ham>> Ok i plugged my PS3 straight in to G70 for 6 Months and there was no visual problem... but perhaps it was a hard time for it Confused
So what will it be? 1080p 60hz trough a Moome?
Posted: Mon Sep 20, 2010 11:58 pm    Post subject:
Yeah, get the new Moome IFB if you don't have it already.
_in_peace_
Posted: Tue Sep 21, 2010 3:40 pm    Post subject:
My receiver on the front end does not respond.. (only the one on the back when activating it by itself)
Any ideas?
"Index 5" comes up sometimes when dealing with this
Posted: Tue Sep 21, 2010 4:08 pm    Post subject:
You know you can select which IR receiver(s) are on, right? Front, rear, or both?
Or, are you saying even with the projector set to "both", that the front one won't work?
_in_peace_
Posted: Tue Sep 21, 2010 7:38 pm    Post subject:
Yes... of those three i can only use the remote when activating "rear" (only)
Posted: Tue Sep 21, 2010 9:02 pm    Post subject:
You don't have a fluorescent light on the ceiling in front of the machine do you?
_in_peace_
Posted: Tue Sep 21, 2010 9:19 pm    Post subject:
crab>> not that i know... it feels like a board is a little of.. to bad it was the front who loosing it
Is someone knowing of the BLKG prevent "tube over heating"?
(when the scan gets to close to the edges inside the tube)
Posted: Tue Sep 21, 2010 10:30 pm    Post subject:
Sorry - I didn't quite understand that... Try again. (I respect that you're a non-native English speaker and recognize that your English is far superior to my Swedish.) Wink
What you really have to worry about is active image area right next to the edge of the tube, or worse yet, extending past the edge of the tube where it's striking the side of the bell... There's no coolant there, and it will cause uneven heating of the glass, which can crack (and implode) the tube. But, you don't use blanking to avoid that... You make sure you physical setup (projector-screen relationship) are such that no active image gets within a cm or so of the edge of the tube face.
Posted: Wed Sep 22, 2010 1:33 am    Post subject:
I've actually been wondering - what's the tolerance there, actually? Not having any information to the contrary, I've always treated it like a single scanline at 20 contrast will instantly cause the projector to explode with the fury of a thousand suns. But I tend to be overcautious. Razz
_in_peace_
Posted: Wed Sep 22, 2010 9:03 am    Post subject:
Ahaaa thank's thats good to know! Smile
Ok the other thing.. I think a board will be broken then.. "It just happend one day"
cinema mad
Posted: Wed Oct 20, 2010 5:22 am    Post subject:
Just thought G70 owners might be interested in noteing:
I just swapt out my stock OEM panasonic p16 Tubes for first of there type High rez Simulation Grade p16's same pin out as sony G70 P16'08's
(based off the same tech used in the Boeing Sim Grade 9" Lug's that I am reviewing but will post about in the next week or so)..
while I was at it I also replaced the old Optical Glycol & found The G70 LC's hold around 450ml or 16fl ounces Shocked ...
Cheers..
geisemann
Posted: Wed Oct 27, 2010 3:23 pm    Post subject: Sim Grade
This will be the first test of G70 Simulation grade tubes.
I convinced the factory to make 4 of them.
They said they can make as many as we like.
So good news. I think he is going to post a review at some point.
http://www.eisemann-theater.com/index.php?option=displaypage&Itemid=83&op=page&SubMenu=
Greg
ronlangendyk
Posted: Fri Feb 11, 2011 8:54 pm    Post subject:
I'm getting an error code 35 on my Sony G70. From what I understand this is related to the E-board. How can I verify this? Also does anyone know how to locate the E-board?
zogomusic
Posted: Sun Feb 13, 2011 5:47 pm    Post subject:
How would the g70 compare to my current Barco 808s... no biased opionions here, i'm sure. I might be able to get my hands on one for cheap, hence my question.
dturco
Posted: Sun Feb 13, 2011 6:00 pm    Post subject:
Well of the 8" machines it ranked pretty close to the top. It is L/C IMO makes it a much better machine, parts wise for repair I think it and the barco are equal. So ...L/C makes for the best picture.
http://www.curtpalme.com/Projector_Rankings.shtm
http://www.hulu.com/firefly
Posted: Sun Feb 13, 2011 6:21 pm    Post subject:
Are you just setting this projector up or has it been in use?
ronlangendyk
Posted: Sun Feb 13, 2011 7:21 pm    Post subject:
Projector was in use for several years.
Page 2 of 4
