Marquee 9500 arcing everywhere, need new HV hardware
Goto page 1, 2, 3, 4  Next
SweetChuck
Posted: Sun Apr 18, 2010 2:28 am    Post subject: Marquee 9500 arcing everywhere, need new HV hardware
I'm sick of this arcing problem I can never seem to fully eradicate. The end of the HT leads have been repaired too many times and now I'm getting arcing all around the blue Tube somehow thats making the Pix go crazy and that smell of Ozone. I want to replace all of the leads and the HV splitter with brand spanking new ones. Can you still buy new bits for these or are you stuck with used ? I just cannot get the PJ to run Arc free with the splitter bolted on and even worse with the pininfarina case on , but with the splitter hanging down it was running fine, Perhaps thats why now I have an arcing blue tube around the cap as I think leaving it hanging down has stressed the lead.
When it was running ok ish with the splitter hanging down you could hold the plastic end of a screwdriver an inch from the splitter and it would hiss like madness, surely that not normal? I would say that the splitter is leaking but I have tried 2 other used ones, surely they can't all be leaking Crying or Very sad
mhalsan
Posted: Sun Apr 18, 2010 3:24 am    Post subject:
I had major arcing and corona problems, both at the splitter and at one of the tubes.
At the tube, I took the lead off, cleaned everything up and reassembled with new silicone. I cleaned the splitter and the HV ends w/denatured alcohol and let everything dry off. So far, so good.
Thanks, Mark
Sigh. We are getting aggravated (yes, we are....)
voodoo7869
Posted: Sun Apr 18, 2010 5:15 am    Post subject:
also you might want to check the deflection yoke a nick on the wires will cause all sorts of zipps and zapps
Marquee 8000 modded, Marquee 9500lc with LUGs, Frankenyokes, and Moome. My avatar is not just a black box. CRT Is KING!!!!
Posted: Tue Apr 20, 2010 3:22 pm    Post subject: Re: Marquee 9500 arcing everywhere, need new HV hardware
it's leaking at the boot and the HV is simply following the outside of the wire back to the splitter. If the HV wire has any carbon on it all that simply makes the leak that much worse since the soot is very conductive. Unfortunately VDC no longer sells the HV wires as a kit like they used to. however I have been suing both new and old wires for years now and I never get HV leaks. Like MArk mentioned, cleaning and re-sealing is key here
 Filesize:  74.82 KB
 Viewed:  13311 Time(s)
Posted: Tue Apr 20, 2010 3:23 pm    Post subject:
Thanks, Mark
Thumbs Up
Posted: Tue Apr 20, 2010 3:28 pm    Post subject:
I agree, nothing wrong with the old style boot. I clean it, but also put a second layer of heat shrink over the existing heat shrink.
Just FYI, the boots are made by Hobson Brothers. I got all excited and researched that a few years ago when VDC stopped selling me new HV leads, and found out that VDC bought out Hobson in 2002 or 2003 I think. SO they have the monopoly on new HV leads. I did find a source of leads in the UK, and bought 20, but the leads and boots were very thin, I don't trust them on the 34Kv used in CRT projectors. For 18Kv black and white sets, no problem.
SweetChuck
Posted: Thu Apr 22, 2010 12:30 am    Post subject:
So is normal black RTV silicon ok when reasealing the boots or do I need something special ? I really want to get this right as this problem haunts me .
Thanks for the help It really makes sense
JustGreg
Posted: Thu Apr 22, 2010 8:06 am    Post subject:
The HV wire required is UL1911. Good for up to 50kV DC. Resistant to corona effect, chemicals, high temps, etc. etc.; and is silicone sleeved.
It comes in (apparently) many colors. I'm trying to track down a small quantity vendor for ~15ft of bright yellow or safety orange for my 8500. So far all I've found are overseas manufacturers and/or middlemen who want to sell me enough to get to the moon and back. (can't blame them for that eh?)
Found this site (the best I could find with a quickie half hour search)...follow the links on the right to the manufacturer and the specs:
http://www.alibaba.com/product-gs/206277932/UL1911_high_voltage_and_high_temperature.html
As for silicone to reseal the caps, I called around to local repair shops and I found one that's willing to sell me a tube of Dow Corning he uses. He's had a case of it for a while and he's concerned that if he doesn't use it or sell it that it will reach EOL and be NFG. I guess the liquid vehicle part of it seperates over time leaving an unuseable gak under the liquid.
Greg
Ile
Posted: Thu Apr 22, 2010 11:40 am    Post subject:
How about red belden one?
http://www.surplussales.com/Wire-Cable/HVWire-1.html
Maybe this company have ready made leads or are willing to made patch.
http://www.jettron.com/crt_j122ac.html
Posted: Thu Apr 22, 2010 3:40 pm    Post subject:
if you should happen to brush up against that sizzling splitter it will do a lot more than just haunt you Mr. Green
I've always used GE 100% pure Black Silicone. I'm not sure how the Dow corning stuff could be different?
Putting in slick new HV wires wouold be great but at $11. per foot it's not cheap. My biggest concern is the terminations. how would you get the bayonet end on? looks it requires a special crimping tool.
Posted: Thu Apr 22, 2010 4:55 pm    Post subject:
I was able to obtain a few tips from Hobson that have small holes; if the wire is stripped with an eighth inch protruding it can be soldered on. If an existing tip were cleaned out and drilled you might be able to solder it.
Sparky015
Posted: Thu Apr 22, 2010 5:19 pm    Post subject:
If your really stuck on using Dow, you can request a sample tube from Dow Corning for free. 1 tube is more than enough to repair your HV leads. That's what I did when my M8000 started arcing a few years ago.
~Paul
SweetChuck
Posted: Wed Apr 28, 2010 12:31 pm    Post subject:
OK , I tore the tubes out , clean and resealed everything with dow corning . Now I have a tic tic tic from the HV supply and crazy pix . If I have a bad HV unit I am seriously thinking of giving CRT PJ's away , I'm just sick of this sh*t and want to relax and watch a movie !!!!!!
Posted: Thu Apr 29, 2010 4:42 am    Post subject:
Chucky, one of your leads in the Splitter isn't seated properly.
If it's one colour, it's the corresponding output, if it's all it's the input connection.
CZ Eddie
Posted: Thu Apr 29, 2010 4:58 am    Post subject:
Sounds like good advice. Try disconnecting all but one tube from the HV splitter. Then try one tube at a time, until the ticking comes back or goes away, just to narrow the problem down to a particular tube or lead.
SweetChuck
Posted: Thu Apr 29, 2010 9:35 am    Post subject:
Mark you are right , I think that over time either the rubber grommet gets squashed or something wears down, as I made my own plastic sleeves that pushes the end cap on to the splitter anode. I made them a tad longer than the originals and you could feel them lock in harder. So far so good, the ticking has gone and I can also hold a screwdriver on the splitter without hissing. The proof of fix will be when I put the case back on.
Thanks All
Posted: Fri Apr 30, 2010 12:09 am    Post subject:
Smile
Russ and I did the same thing when we were fixing his XG LC.
huggy
Posted: Fri Apr 30, 2010 2:02 am    Post subject:
Mark_A_W wrote:
Smile
Which is still sitting there EXACTLY the way you left it BTW Wink
Posted: Fri Apr 30, 2010 4:57 am    Post subject:
Yeah, well, he has a new shiny toy doesn't he?
Posted: Sun May 09, 2010 2:06 pm    Post subject:
I think you need a new splitter in any case. If it was ever hissing or spitting, it certainly now has some internal arcing damage and yoiu would be better off to simply replace it. It's not like that's a tough job.
CJ
Page 1 of 4
