All about Glycol CRT coolant and where to buy...
Goto page 1, 2, 3  Next
Posted: Thu Apr 01, 2010 7:50 pm    Post subject: All about Glycol CRT coolant and where to buy...
Where have you purchased glycol and glycerin and in what country ?
Where have you found it at a reasonable price ?
Do you mix glycerin with your glycol and at what percentage ?
Whats the difference between different types of glycol ? (triethylene glycol come to mind)
I'll start with a source in the USA...
http://www.mcmelectronics.com/product/20-4275
This thread comes to mind Wink Wink Wink
https://www.curtpalme.com/forum_archived/viewtopic.php@t=20914.html
jkruger
Posted: Thu Apr 01, 2010 8:07 pm    Post subject:
Glycerin, Ethylene Glycol and Propylene Glycol available here in bulk:
http://www.mcmaster.com/#catalog/116/2024/=6h3pfv
dvh99
Posted: Thu Apr 01, 2010 9:14 pm    Post subject:
ok
ethyleenglycol 2 liters 25 euro
glycerine 1 liter 10 euro
glycol-glycerine 75%-25%
www.labstuff.nl
les pays bas
Posted: Thu Apr 01, 2010 9:32 pm    Post subject:
There is also this thread...
http://www.curtpalme.com/forum/viewtopic.php?p=243926#243926
Posted: Thu Apr 01, 2010 9:35 pm    Post subject:
CRT fungus removal video.
http://www.youtube.com/watch?v=Z2A0fK6NlXY
Sparky015
Posted: Thu Apr 01, 2010 11:40 pm    Post subject:
Cool. I just want to be able to move that fast. Laughing
~Paul
LOTREE
Posted: Fri Apr 02, 2010 1:49 am    Post subject:
http://www.chemistrystore.com/product.cgi?group=49939&product=64138
Propylene Glycol 1 Quart: $12
And they also ship to Canada.
That YouTube video is okay. Like I commented before in another thread he's pretty violent with the glass and doesn't really use a lot of RTV sealant not to mention you don't need to hang the tube face up as there's a lip built in to hold the glass on the 07MS tubes. I could presume it was made based on my walkthrough of cleaning all the tubes in my ECP 4500 but then again there's only a few ways to do it.
Gerbrand
Posted: Fri Apr 02, 2010 8:28 am    Post subject:
LOTREE wrote:
Propylene Glycol
I thought you needed ethylene glycol for crt coolant?
Gerbrand
BG1209s (color filtered,new LUGs!), 13000h
Bat cave
Ile
Posted: Fri Apr 02, 2010 10:00 am    Post subject:
Gerbrand wrote:
LOTREE wrote:
Propylene Glycol
Gerbrand
Propylene glycol works just fine, it have same refraction index that ethylene glycol.
Actually it should be better, because it's nontoxic and it's not corroding aluminium as much that ethylene glycol. Corroding tube hardware cause fungus. I guess that ethylene glycol was chosen for crt coolant only because it's cheaper.
I have used straight propylene glycol in AC tubes years without problem.
For LC-tubes I mix 70% propylene glycol and 30% glycerin to get similar refraction index that tubes front glass and plastic c-element have. I have bought these from pharmacy.
papalek
Posted: Fri Apr 02, 2010 12:20 pm    Post subject:
The Techspay TV coolant that is sold by MCM electronics is not Glycol unless these are other names for the same stuff.
1915-16SQ TDS 040208.pdf
 Filename:  1915-16SQ TDS 040208.pdf
 Filesize:  53.49 KB
 Downloaded:  1038 Time(s)
I do love my AmPro's
papalek
Posted: Fri Apr 02, 2010 12:34 pm    Post subject:
Well I guess after further checking it is the same. The Chemical numbers are the same just different names for it.
Posted: Fri Apr 02, 2010 7:35 pm    Post subject:
The MSDA sheet for Tech Spray coolant...
http://www.mcmelectronics.com/content/ProductData/MSDS/20-4275.pdf
Note the precautions on handling this stuff !
Use rubber gloves as it can be absorbed through the skin.
Posted: Sat Apr 03, 2010 5:09 pm    Post subject:
Ethylene versus propylene glycol..
http://www.engineeringtoolbox.com/ethylene-propylene-glycol-d_904.html
TESTS FOR THE CHRONIC TOXICITY OF PROPYLEXE GLYCOL AND TRIETHYLENE GLYCOL ON MONKEYS AND RATS BY VAPOR INHALATION AND ORAL ADMINISTRATION
http://jpet.aspetjournals.org/content/91/1/52.abstract
Diethylene glycol
http://en.wikipedia.org/wiki/Diethylene_glycol
Ile
Posted: Tue Apr 06, 2010 11:32 am    Post subject:
Didn't know that Propylene glycol have also better heat transfer efficiency.
dvh99
Posted: Tue Apr 06, 2010 11:50 am    Post subject:
yes but is it needed i dont think so.
these machines were used 10000 hrs and more in warm environments(simulators) with e-glycol so for home use it will be more than sufficient.
keep in mind it has a higher viscosity so it will be harder to fill the chambers and its twice as expensive.
i filled the marquee with a needle and had to apply quite some pressure with e glycol and glycerine.
Ile
Posted: Tue Apr 06, 2010 12:58 pm    Post subject:
Yes, I know that.
Just trying to convince myself that it's better, because I couldn't get clear ethylene glycol from here. Laughing
Only colored one is easily available here, that's because it's poisonous.
If heat transfer efficiency would been my only worry, I'd been used distilled water. Wink
Actually someone reported few years back that he have been using distilled water in his projector tubes without problems. Can't remember if it was AC or LC optics, I guess that in LC there could be some small differences because water refraction index is different. Here freezing could cause disaster during storage or transport.
David_Web
Posted: Tue Apr 06, 2010 2:11 pm    Post subject:
I wonder if distilled water would help with halos on an AC projector. The different IOR might send stray light all the way to edges.
HD144/145 already take care of the lens induces bounce.
Ile: I think he also said it was the sharpest image he had seen.
Can somebody test this? Preferably with HD144/145 lenses.
Posted: Tue Apr 06, 2010 2:56 pm    Post subject:
MAT electronics is selling glycol in 16oz bottles for $6.50 each or 10 for $5.95 each. Order#212072-16
Posted: Tue Apr 06, 2010 5:15 pm    Post subject:
Cursor down to 2nd item from the bottom...
http://www.matelectronics.com/acatalog/Mat_Electronics_Chemicals___Tech_Spray_59.html
Checkout for a total of 10 bottles is $59.50 plus $2.50 shipping for a total of $62.00.
Looks like they only ship to the US though....
mycatisretarded
Posted: Thu Apr 08, 2010 9:33 pm    Post subject:
A little off topic......but I work in a facility that manufactures optical fibers. Some of the optical test equipment uses a refractive index immersion liquid made by Cargill. I saw a couple 5 gal. containers of the stuff, It has an index of refraction of 1.4571. I also saw some smaller quantities at 1.4460. I couldn't find much info on the stuff- the msds didn't give much info. The boiling point was fairly high but I can't remember right now, the viscosity about 170 cSt (maple syrup is 165, glycerin is 550). I did the touch, sniff and taste test, it felt like an oil. I don't know if this would be a good solution to use in a projector. If the main purpose is optical coupling it may be ideal, if the main purpose is thermal heat related whatever it may not be ideal? Any thoughts? I'm sure i could get a couple tubes worth if anyone is interested in experimenting.
Info about Cargill liquids.. http://www.cargille.com/opticalintro.shtml
Page 1 of 3
