incova
dturco
| Posted: Sun Mar 28, 2010 4:17 am Post subject: |
I'm going to guess "the other side of the pond" issue is in play, but, what is wrong with HEX HEAD bolts?
http://www.hulu.com/firefly
| Posted: Sun Mar 28, 2010 4:20 am Post subject: |
You may want something stronger than stainless. Maybe a Grade 3 bolt at least.
incova
| Posted: Mon Mar 29, 2010 2:27 am Post subject: having a tough time finding this stuff |
Not easy finding these sizes over here not sure why but my Ampro seems to have a lot of CHevy Truck parts its similar with!
A grade 3 bolt? is that a tensile strength grade? 4 of these bolts should only be holding about 45 pounds of weight each you reckon thats too much for stainless?
the less I know.
incova
| Posted: Mon Mar 29, 2010 2:33 am Post subject: I cannot seem to find grade 3 |
No grade 3 bolts here that I can see mate, I have seen grade 5 in the U.S but nothing here. How does the grading system work?
the less I know.
| Posted: Mon Mar 29, 2010 3:16 am Post subject: |
Grade 5 would work. I have a Chevy truck downstairs if it helps LOL
I belive ( going from trade school memory ) there's ungraded, grade 1, grade 3, grade 5, grade 8 and I seem to remember a grade 10.
I used a grade 5 bolt to tow a car ( 84 Supra ) on a car dolly once when I miss placed my hitch pin. Very strong.
Stainless will snap very easy as I recall. Also going from my 20 year old memory of school, I think there's a reaction between aluminum and stainless. BUT don't quote me on that.
| Posted: Mon Mar 29, 2010 3:20 am Post subject: Re: eeesh |
| incova wrote: | | I have read that manual about 8 times as well................... |
What's it like?
| Posted: Mon Mar 29, 2010 3:33 am Post subject: Re: eeesh |
| AnalogRocks wrote: | | incova wrote: | | I have read that manual about 8 times as well................... |
What's it like?  |
Does it have a happy ending ?
incova
| Posted: Tue Mar 30, 2010 1:18 am Post subject: no |
I had to reset my brain for Ampro mode Tom I have a barco 808 G S and the Ampro is totally different so brainwashing is required, dont ask me to set up a Barco now though!
the less I know.
| Posted: Tue Mar 30, 2010 2:05 am Post subject: Re: no |
| incova wrote: | | I had to reset my brain for Ampro mode Tom I have a barco 808 G S and the Ampro is totally different so brainwashing is required, dont ask me to set up a Barco now though! |
Hey try going from a Barco to an Ampro then to a Sony and see how you like things.
incova
| Posted: Tue Mar 30, 2010 2:34 am Post subject: this ok? |
I got this from Mr Mad H from the Uk not specifically directed to me but for another guy just wanted to see what you guys thought. There will only be two unistruts on the pj though going from side to side I dont think you can attach three and I cannot find 50mm Unistrut only 41mm slotted. What do you guys think, on the right track? The picture below is what MR H was trying to explain.
2 x Ceiling mounted "DEEP SECTION Slotted 50mm UNISTRUT" 1-2m long each.
3 x PJ mounted "DEEP SECTION Slotted 50mm UNISTRUT" width of projector
6 x "10mm Threaded rod" length to suit drop required
Ceiling sections
6 (or 8) Number 8 size x "Coach Screws" - mount unistrut to ceiling approx 150mm long IF used through the unistrut, 100mm Long if bolted within the unistrut, within looks more tidy BUT you need a socket set that will fit within the unistrut channel.
Either 6 "Square Washers" for mounting "Coach screws" above the unistrut OR 6 normal washers for mounting within unistrut.
6 x M10 "channel nuts" - Go witin the unistrut, threaded rod fits into these
6 x M10 "Square washers"
6 x M10 "standard nuts" (NOT! Nylock type)
Projector Unistrut section to threaded rod
Projector Unistrut section to Projector
6 x M10 "Set bolts" - length could be 25mm to 80mm depending if you want to bolt within the unistrut OR have the final "Nylock Nut" on top of the unistrut (easier to work with)
6 x M10 "NYLOCK nuts"
12 x M10 "Washers" if inside the unistrut - OR 6 x M10 "Washers" AND 6 x M10 "Square Washers" if final nut is on top of Unistrut
| Description: |
| Filesize: |
34.22 KB |
| Viewed: |
3066 Time(s) |
the less I know.
