Are these the PJ's that are the size of a snowmobile?
drice1234
Posted: Mon Feb 15, 2010 4:48 pm    Post subject: Are these the PJ's that are the size of a snowmobile?
http://dallas.craigslist.org/ftw/ele/1600906482.html
Posted: Mon Feb 15, 2010 4:55 pm    Post subject:
Yep.
Posted: Mon Feb 15, 2010 5:26 pm    Post subject:
And we thought our projectors were hughes! ( pun ) Laughing
Posted: Mon Feb 15, 2010 5:56 pm    Post subject:
Quick!
Somebody Stop ME!!!!!!!!!!!!!!!!!!!
Posted: Mon Feb 15, 2010 6:08 pm    Post subject:
Tim in Phoenix wrote:
Quick!
Tim, go ahead, you know you want to. Not just one but you need them all. Wink
Posted: Mon Feb 15, 2010 6:37 pm    Post subject:
Quick!
It's a good thing those are not close by......buy?
yonexsp
Posted: Mon Feb 15, 2010 10:58 pm    Post subject:
Has anyone ever seen one of these setup? What is the image quality like?
Posted: Mon Feb 15, 2010 11:07 pm    Post subject:
I saw one at the local TV station that was state of the art back in 1994 or so. I thought it was amazing. It was used RP at the news desk, and the pix overcame all the studio lights and still looked great. Loud as hell, 220 volts.
The price on CL is really good... if you have a use for such behemoths.
Posted: Tue Feb 16, 2010 2:01 am    Post subject:
Over 20 extra lamps? Wow.
The thing to do here is to build a well soundproofed projection room in the back of your home theater, and install one of these suckers in there. Just run it. Replace lamps when they blow, swap out units for a good spare when one fries. Keep running 'em until they're all
dead or you run out of lamps. Then take them to the local electronic recycling facility and forget about them.
Those things use a CRT to drive the LCD panel. Neat technology. The CRTS put out IR and the back side of the LCD panels take a charge
when hit with IR light. So, whatever shows on the CRT face ends up on the LCD panel. Actually a simple concept.
If those were near me I'd probably go for it.
If anyone here decides to go for them, when they blow up I'd like to get at least one lens off of one for curiosity's sake. I have a habit
of taking DLP and similar projection lenses and building small telescopes out of them. Some of them end up being quite good,
far outperforming any comparable compact telescope you can buy for less than several thousand dollars.
CJ
Posted: Tue Feb 16, 2010 8:32 am    Post subject:
My Barco doesn't look big anymore.
donaldk
Posted: Tue Feb 16, 2010 4:40 pm    Post subject:
Unfortunately these are the low rez models, according to the listed spec. not the SXGA+ (type) resolution of some of the other 300/400 series.
Posted: Tue Feb 16, 2010 4:51 pm    Post subject:
Actually, I think the guy's listed specs are wrong if he has the right model number. As I understand it, like CRT, there isn't really a "native" resolution, anyway... But, according to what I found, the Hughes-JVC D340SC is indeed 2000x1280.
http://www.projectorcentral.com/Hughes-JVC-D340SC.htm
That's confirmed in the really interesting PDF I found.
It runs 3325 watts on a 30A/220v line, and puts out over 11,000 BTU's!!!
Oh, and BTW... It's also 369 pounds. Shocked
Somebody buy a couple of these things!!!! Twisted Evil
jvc-hughes-300-serie-en.pdf
 Filename:  jvc-hughes-300-serie-en.pdf
 Filesize:  126.22 KB
 Downloaded:  570 Time(s)
roland@b4
Posted: Tue Feb 16, 2010 5:32 pm    Post subject:
CRT with a Reflective LCD all that's missing is a spinning color wheel.
Any one else remember the Telaria
http://en.wikipedia.org/wiki/Talaria_projector
roland@b4
Posted: Tue Feb 16, 2010 5:36 pm    Post subject:
I just found a price list too $95,000 new
and the actual 340SC brochure
Model340SC.pdf
 Filename:  Model340SC.pdf
 Filesize:  618.21 KB
 Downloaded:  446 Time(s)
ILAoverview.pdf
 Filename:  ILAoverview.pdf
 Filesize:  769.83 KB
 Downloaded:  712 Time(s)
Posted: Tue Feb 16, 2010 5:39 pm    Post subject:
$250 G for the top model eh?
HEY TIM!!
Go buy some of these will ya?
roland@b4
Posted: Tue Feb 16, 2010 5:41 pm    Post subject:
tell you what these would soft edge a treat provided you can get hold of the software for a PC to run them.
Posted: Tue Feb 16, 2010 6:01 pm    Post subject:
Just get an external blender box.
donaldk
Posted: Tue Feb 16, 2010 6:39 pm    Post subject:
Talaria is CRT with oil film, as 'stolen' from the Eidophor.
Posted: Tue Feb 16, 2010 8:05 pm    Post subject:
No color wheel is required for those. They have three independent light paths.
AmPro infringed on the light valve patent (Greyhawk Systems, to be precise) and made it work with a single lens tricolor light path system.
It saved considerably on lenses, which started at around four thousand dollars apiece and went up from there.
CJ
Posted: Tue Feb 16, 2010 8:24 pm    Post subject:
I have one here with a couple of lenses and about 6 bulbs. $140K new, they rented for $5K a day back in 1986. I paid $500 for mine about 10 years ago, and it's been in the case ever since. I might just set it up outside this summer... but I've been saying that EVERY summer. Mr. Green
