Marquee VIM 02P or 03P ?
Goto page Previous  1, 2, 3, 4 ... 12, 13, 14  Next
dvh99
Posted: Thu Jul 29, 2010 6:25 pm    Post subject:
donations are welcome i have the details for those that are interested.
i had a chat with mike and he is willing to mod the 03p vim.
mais je n`ai pas l`argent c`est dommage.
GeorgeSong
Posted: Fri Jul 30, 2010 8:31 am    Post subject:
i have 3 pics of VIMS:
2005-03P
2035-02P
2035-03P
dvh99
Posted: Fri Jul 30, 2010 1:06 pm    Post subject:
jantje112
Posted: Sun Aug 01, 2010 11:05 am    Post subject:
I have a spare 2035-03p vim, badly enough it's not working anymore. Maybe I let it get fixed and modded, should be fun!
dvh99
Posted: Sun Aug 01, 2010 1:33 pm    Post subject:
looking at the schematic it must be possible to place the ad834 instead of the ad835 and from there on use an addon board for the 2n3906 transistors to be used.
pins 4 and 5 should go to the addon board amplified and then fed into the clc449.
you will need +5v and -5v as well.
if i have a spare 02p vim this is a fun project.
dvh99
Posted: Tue Aug 03, 2010 10:35 pm    Post subject:
the 02p and 03p vims use the same circuit except the end section.
jarmo is going to send me a few pcbs.
i am going to order some parts for the addon board.
if all works well this will be a cheap upgrade for everyone owning a 02p vim.
jarmo tried some other transistors but had problems with them and used the 2n3906 as in the schematics, i will try some other with about the same specs as the 2n3906.
i was looking at a replacement for the clc449 and found these (link) what do the experts here "wink wink" tse think about the replacement for the clc449.
little diode charges 20 bucks a piece on ebay and since the ad834 don`t come cheap i wasnt planning on spending another 60 dollars on the clc449s.
http://www.farnell.com/datasheets/53391.pdf
if i use these do i have to replace the clc449 on the vnb`s too?
dvh99
Posted: Sun Aug 08, 2010 8:36 pm    Post subject:
http://www.vishay.com/docs/70228/70228.pdf
this is a mosfet i want to try instead of the 2n3906.
someone knows if this will work.
i am still making an inventory of what i need before ordering.
tse
Posted: Sun Aug 08, 2010 9:04 pm    Post subject:
The THS3201 should be a good replacement for the CLC449. It isn't a drop in replacement. With the gain set for +2 and +/- 5V power the feedback resistor for CLC449 is 250 ohms. For THS3201 it needs to be 715 ohms. The gain set resistor will have to change, also.
I am not going to say that the mosfets won't work. They might but I have to question the on resistance. At 300 ohms it is kinda high for the circuit. It will be plenty difficult to make the circuit work as designed by Analog Devices. Good RF circuit board design will be needed.
Scott
Thomas Jefferson
dvh99
Posted: Sun Aug 08, 2010 9:28 pm    Post subject:
scott on the 02p they use 260 ohm and on the 03p 300 ohm.
why the difference?
thanks btw i appreciate your input.
which traces need to be kept as short as possible?
is it wise to use 3 different ground planes for the 3 colours?
Posted: Sun Aug 08, 2010 10:29 pm    Post subject:
Scott, The transistors Dennis is talking about are after the Ad834 . They have a 20 ohm resistor before or after it IIRC. I'm going by Memory here. He is not talking about the op Amps.
The Op Amps you mention I did try and got to work somewhat with the spec'd resistors for FB and G and then the DC restore resistor as well but it did Oscillate a lot. I think If i had a vari Cap in parallel on the R92 or R83 i might have been able ti find the right combination. Jarmo tried it as well and lots of different buffering caps on the supply rails. But I think caps on the FB Or FG resistors would work too. I still want to get back to those some day, as they were razor sharp on the old 2006-03p vim but were Bright as Hell!!!!!!
Just looked they are in location Q18,Q19 Red Channel
dvh99
Posted: Sun Aug 08, 2010 11:35 pm    Post subject:
i will be ordering resistors in the range of 200 till 1k 1% for testing.
for the buffering caps i try 0.1 0.47 1 10 and 22uf.
i will use 1% resistors all along this circuit and maybe some with even a better tolerance for feedback and gain.
cannot wait to receive the boards from jarmo.
Posted: Sun Aug 08, 2010 11:57 pm    Post subject:
Dennis here is what jarmo did on the Decoupling caps for the THS 3201.
1031 wrote:
No keep those original 100nF caps there but put those 100pF micaīs arcoss them. Those caps on that picture are 15uF low esr tant+470nF cer+ 100nf(that original one) and 47pF cer and that blue one is 100nF and that is between vcc and vdd (+5/-5v)pins. Also i replaced those 4.7ohm resistors with 56uH smd coils. I scoped noise voltage on vcc/vdd pins and that cap combination showed that noise was very low. Much lower than original 4.7ohm+100nF combination.
Posted: Mon Aug 09, 2010 2:10 am    Post subject:
How did he get a 3201 to work with those FB/G resistors?
Posted: Mon Aug 09, 2010 2:14 am    Post subject:
Thats what I don't know, the stock resistor will no way work. I used 750 as they were all i had and I got close but gave up when i messed up the protection circuit accidentally on that vim. He said he had it working but went to the El5166 after for some reason.
1031
Posted: Mon Aug 09, 2010 6:49 am    Post subject:
Summer vacation is over Neutral
I will post that board to you today. Have fun
Smile
DVDO VP-50
New hobby, Rally
Posted: Mon Aug 09, 2010 6:57 am    Post subject:
IIRC it worked pretty ok with those resistors, not 100% perfect. But that was long time ago so i cannot remember exactly what was problem with those, for some reason i changed those back to EL5166īs
But there was something that liked much (3201īs) deepness, colors were good, natural sharpness etc..
DVDO VP-50
New hobby, Rally
Posted: Mon Aug 09, 2010 11:32 am    Post subject:
I agree, it had a different look. Not sure if it was better but just different. and for the short time i tried to tame them was not enough to say for sure I had them working 100%. They just were not stable, alway one or two would look fine and one channel would oscillate , then that would be ok and the others would do something.
Maybe Scott can mess around with them Wink
tse
Posted: Mon Aug 09, 2010 12:46 pm    Post subject:
Pics of a prototype board using the AD834. I can't believe that was in 2004. Wow!
Scott
 Filesize:  117.23 KB
 Viewed:  12279 Time(s)
 Filesize:  116.5 KB
Thomas Jefferson
Posted: Mon Aug 09, 2010 1:13 pm    Post subject:
I love CRT nostalgia ! Wink
dvh99
Posted: Mon Aug 09, 2010 5:34 pm    Post subject:
yeah that is one cool picture there scott.
jarmo too bad your holiday has finished i hope you had a great time, where did you spend your holiday, italy spain greek islands?
i will defenitely try that ths3201 even if it takes me 20 decoupling caps Smile.
as for the transistor/mosfet i have been searching some more on the www and i found this
http://www.semiconductor-sanyo.com/ds_e/ENN3179A.pdf
if anyone has some suggestions for a replacement for the 2n3906 please let me know because i am still on the lookout.
the 2n3906 is a limiting factor and i do not want that.
Page 3 of 14
