seanoise
| Posted: Sat Jan 30, 2010 2:18 pm Post subject: marquee 9500 no picture - maybe hvps ??? |
hello guys.
i have a problem with my marquee 9500lc ultra...
after 2 hours of watching movie suddenly a noticed a strange sound for one or two seconds, like a small detonation, and then the picture was gone.
i turned the machine off for a while and then on again! no error lamps are lighting and the typical startup crackle from the hvps was missing.
i opend the hvps but counldn't see and smell anything... the other boards, including the lvps, are looking good too.
what you think about this problem? think i need a new hvps?
i hope someone can help me!
| Posted: Sat Jan 30, 2010 3:30 pm Post subject: |
There's a couple of guys here that still like Marquees. I've up-graded to a AmPro 4600HD so I can't help you
_________________ Chip
dmarnold
Joined: 18 Jan 2010 Posts: 73 Location: St. Louis, MO
| Posted: Sun Jan 31, 2010 7:03 pm Post subject: marquee 9500 |
well seanoise,
have you confirmed HVPS failure?
_________________ enjoy today, for change is on the way
seanoise
| Posted: Sun Jan 31, 2010 7:15 pm Post subject: |
not really...
i only guess the hvps failure. i don't know what else to try...
in a few days i get another hvps, hopefully the marquee will continue working!
i only wanted to know if the "pros" in this forum confirm my diagnostics...?!?!?!
if i have the new hvps i will report again.
| Posted: Sun Jan 31, 2010 8:34 pm Post subject: Re: marquee 9500 no picture - maybe hvps ??? |
| seanoise wrote: | | after 2 hours of watching movie suddenly a noticed a strange sound for one or two seconds, like a small detonation, and then the picture was gone. | typically a high voltage supply just dies quietly. A HV leak which takes out the HDM like Nash mentioned is a loud SNAP like those little paper crackers little kids throw on 4th of July.
What you described sounds like a tube imploded. This can be caused by Glycol chamber swelling/overpressure or running raster/image off side of tube bell. Look into tubes with flash-light, you'll know quickly if one imploded on you.
LOTREE
Joined: 19 Mar 2006 Posts: 401 Location: Paradise, Newfoundland
| Posted: Sun Jan 31, 2010 9:13 pm Post subject: Re: marquee 9500 no picture - maybe hvps ??? |
| draganm wrote: | | What you described sounds like a tube imploded. This can be caused by Glycol chamber swelling/overpressure or running raster/image off side of tube bell. Look into tubes with flash-light, you'll know quickly if one imploded on you. |
Been there, done that and while the tube was still sealed the scent of a imploded mint blue tube drifting into the kitchen while I was cooking put tears to my eyes. Sounds very similar though from what you describe. Any electronic smell right after? I guess we'll find out soon enough if that's the case or not.
_________________ Zenith Pro 1200x | Electrohome ECP 4500 | Yamaha HTR-5740 | HTPC & Speaker build to follow
seanoise
| Posted: Sun Jan 31, 2010 9:40 pm Post subject: |
at first, thanks for your help guys.
i'm a little bit smarter now. the tubes all look ok, nothing is imploded.
the hv-wires also look ok.
but on the hdm board i found a burned resistor, it is the resistor R96. i have no idea for what it is good... maybe a protective resistor???
so, i'm looking forward for more help.
| Posted: Sun Jan 31, 2010 9:47 pm Post subject: |
| seanoise wrote: | at first, thanks for your help guys.
so, i'm looking forward for more help. | well thank goodness for that, HDM's are plentiful but tubes are still very expensive. Best bet is to have Curt repair it or just replace it. which version is it 04P,07P, or 08P?
seanoise
| Posted: Sun Jan 31, 2010 10:05 pm Post subject: |
it is a 08P board.
so you think my hvps is still intact?
as next step i wanted to change the burned resistor, do you think it would be senseless?
seanoise
| Posted: Sun Jan 31, 2010 11:03 pm Post subject: |
and i don't know the size of the resistor, because it is burned...
somebody knows it, or can give me the colour-code?
seanoise
| Posted: Mon Feb 01, 2010 12:34 am Post subject: |
thanks!!!
i will try it today...
| Posted: Mon Feb 01, 2010 12:42 am Post subject: |
If you get stuck, send me the HVPS and HDM for testing.
Cheers!
seanoise
| Posted: Mon Feb 01, 2010 2:07 pm Post subject: |
hello.
so i changed the damaged resistor, but nothing changed... the projector is still not running.
the problem is, i'm from germany, so shipping the board to canada would take several weeks...
maybe you could give me another hint Curt, Nashou66 or Draganm ?!?!?!
| Posted: Mon Feb 01, 2010 2:29 pm Post subject: |
If R96 on the HDM is open or bad, from there it's best to send that HDM to Curt for repair.
That's not a resistor that would just go bad and everything else is OK. If it opens, whatever caused it to open also took out R92 and R1001 - they are all in parellel.
That's not a DIY repair.
| Posted: Mon Feb 01, 2010 4:58 pm Post subject: |
that's always a hard thing to explain to people who are trying to do repair. It's not a simple matter of of "oh look there's the bad part, just replace it and everything is fine". A blown resistors is 99% of the time the messenger, not the cause. Like Mike explained, when electronics fail it's like Dominoes , they fail in a chain and sometimes with many branches.
seanoise
| Posted: Mon Feb 01, 2010 5:02 pm Post subject: |
ok, i understand.
i found someone in germany, who can help me maybe with the hdm...
tomorrow, i will know more and post the results!
seanoise
| Posted: Thu Feb 04, 2010 5:04 pm Post subject: |
good news!!!
a repaired the hdm-board by myself.
ich changed the mosfet and the ic in the same circuit (it is the 85V circuit), and now the machine is working again!
thanks for all your help and the circuit-diagrams!!!
