Marquee LC guys, check your glycol!
Posted: Fri Jan 22, 2010 5:54 pm    Post subject: Marquee LC guys, check your glycol!
Not like this is an unknown issue especially on Marquee LC machines, but you guys should ALL check your glycol condition. If you look at your blue tube and see a yellow mess as in the photo below, you really need to change your glycol.
One of my clients sent me that blue out of a 9500LC for me to put an LUG in. The client wasn't even aware that there was a problem with the coolant being golden color. This coloration will cause two serious problems.
The first problem is that the colourimetry of the projector will be incorrect and there will be no way to fix it. For example, this is a blue tube with yellow coolant. The yellow color will have a similar affect as adding color to the glycol in the application of fixing the primary colors. However, since blue is already perfect without correction, the yellow colored glycol will basically add yellow to the blue and pull your blue primary towards white. This will result in under saturation in blue (in this case) and your projector will not properly reproduce any color with a blue component.
The second problem with this is that you can't add color to LC 9" projectors because they have curved C elements. When you add color to the glycol, the light at the center of the image will have to pass through less colored glycol than the portion of the image at the sides of the tube. This will result in serious problems in field uniformity because the center of the image will be brighter (and in this case bluer) than the sides. You can try and correct this with the CMM in the Marquee, but this is not what the CMM is for and it will wind up being over driven. Also, over time the glycol will get more and more yellow so the uniformity will vary.
Here is a photo of the glycol after I drained it.
It should be crystal clear, not at all yellow.
Look into your blue tube and see if there is any coloration. If there is, it is also likely that the red and green also have the same problem. On projectors with a clear C element on the red assembly you will also be able to see the yellow problem. However, if you have colored C elements for red and green, you will most likely not be able to see the yellow coloration. In this case I would recommend just dumping the coolant in all three tubes, clean them out, and refill.
After that you will need to redo gray scale as the primary colors will have changed.
Posted: Fri Jan 22, 2010 6:11 pm    Post subject:
His green was the same way, pretty awful. I'm betting it's either 15 year old original Glycol or the original seller was stupid enough ot re-use old glycol when they potted the Red and blue (which BTW were both leaking around the potting)Overall the entire LC assembly on that machine was a total hack-job:(
I'm glad you'll be finalizing it and putting the finishing touches on the set-up Craig
Ben851
Posted: Fri Jan 22, 2010 6:17 pm    Post subject:
That's funny I have zenith pro 841 (it was free) that has the exact same issue... I figured the whole tube had yellowed...
Ben
Posted: Fri Jan 22, 2010 6:57 pm    Post subject:
Craig if you need two more bellows just order one and Ill send you two.
WTS
Posted: Fri Jan 22, 2010 7:00 pm    Post subject:
So what causes it to turn yellow, is it the heat from the tube?
Walter
Posted: Fri Jan 22, 2010 7:36 pm    Post subject:
For those who don't know, this is what a blue tube with good glycol should look like in a 9500LC.
Last edited by CIR Engineering on Fri Jan 22, 2010 7:45 pm; edited 1 time in total
Posted: Fri Jan 22, 2010 7:39 pm    Post subject:
Yeah, this can happen on any CRT projector, but for some reason Marquee is extremely prone to the problem. I have only seen it on a G90 once, and I see it on almost every 9500 to some degree or another. If the tint is not that great, you might let it ride for a year or two, but it gets worse and worse over time once the condition sets in.
Posted: Fri Jan 22, 2010 7:41 pm    Post subject:
Thanks Tom, but Draganm already re-potted the green and red tubes for this client and put your new bellows in them already. This blue was for the same client that we spoke about on the phone the other day when I asked about the bellows Wink
Posted: Fri Jan 22, 2010 7:43 pm    Post subject:
I wish I knew. One theory is that contamination causes it. As in there was some contamination that got into the glycol when the LC was put together. It does seem weird that we don't just get "fungus" because I really don't understand why it turns yellow Question
Posted: Fri Jan 22, 2010 7:56 pm    Post subject:
I bet it has to do with the permeability of the older silicon Bellows. they had a vapor transmission 7 times worse than the new style bellows. Now the new bellows have not been in the field long enough to really attribute the yellowing to moisture absorption but it is possible.
Ben851
Posted: Fri Jan 22, 2010 7:57 pm    Post subject:
I'll have to pull the lenses off my marquee to take a look then... That won't be a big deal since pretty much everything else has been disassembled on it in the last week!
The zenith has it brutally bad (about as bad or worse as what you posted... a little bit of fungus to boot) but the zenith also has an intermittent hvps issue and is my 3rd string projector so I'm not in a hurry to take a look at it Laughing
Ben
Posted: Fri Jan 22, 2010 8:09 pm    Post subject:
Thanks Tom, but Draganm already re-potted the green and red tubes for this client and put your new bellows in them already. craigr
i'm looking forward to hearing from tony, something like " wow that was a royal PITA but the picture is awesome and it was worth the trouble getting here". Thumbs Up
Posted: Fri Jan 22, 2010 8:12 pm    Post subject:
Saving the Marquee one PJ at a time Wink
Nice Work Drags and Craig !
Posted: Fri Jan 22, 2010 8:38 pm    Post subject:
I'm having a bit of a problem with that in my own machine and I retubed it in 2005. Just 5 years later.
The problem started becoming visible just recently with a greenish cast to the perimeter of the screen when showing a pure blue field.
As the glycol is "deepest" at the perimeter, this makes perfect sense, optically speaking.
One issue with the Marquee LC assembly is that the glycol is slightly corrosive to aluminum, and the chamber is aluminum, but it's
anodized. However it's not perfectly protected against glycol attack.
I can take a clean piece of aluminum, close it up in a jar of glycol, and observe it slowly start to corrode over a period of time.
I BELIEVE that an optimal solution would be to obtain some black industrial epoxy paint and paint all inner aluminum surfaces that will
be touching glycol. For obvious reasons this would best done when the CRT is completely out of the housing and the bellows is not
attached, either.
Several gun finishes may also be appropriate: KG Guncote, Cerrocote, or Duracoat.
If anyone has stripped LC chambers lying around, they would be ideal for making this experiment a reality.
Since I'll have to go in there anyway, soon, I'll be removing the old bellows, cleaning everything, mask off the CRT, apply epoxy
paint, install new bellows, and see how that holds up for the long term with fresh glycol.
CJ
Posted: Fri Jan 22, 2010 11:57 pm    Post subject:
Consumer Hitachi RP tubes are also known to do this.
secstate
Posted: Sat Jan 23, 2010 3:16 pm    Post subject:
I got some NOS Ampro Retro P16s off of GL a few years ago. Still new in the box, never used, probably about 6-7 years old at the time and while not quite as bad as this the glycol was quite yellow. So it happens even if the CRT is not being used.
Posted: Sat Jan 23, 2010 4:32 pm    Post subject:
Holly apple juice bat man!
Posted: Sat Jan 23, 2010 8:31 pm    Post subject:
I was thinking of something else Mr. Green
Last edited by CIR Engineering on Sat Jan 23, 2010 8:32 pm; edited 1 time in total
Posted: Sat Jan 23, 2010 8:32 pm    Post subject:
Interesting...
Posted: Sat Jan 23, 2010 8:33 pm    Post subject:
I do have to wonder why some brands do this and others don't as often...
