| Posted: Sun Jan 17, 2010 11:40 am Post subject: |
OK, today's the day. I've told everyone to leave me the F alone so I can finish this up. I have two tubes to install followed by a couple of hours of carefull stig and flare tweaking and a complete ground up for three memory locations and rough color calibration. Fine tuning the color will be next weekend after the new tubes have settled in for a while. I'm really looking forward to seeing how this set's up with all three new Thomas tubes
_________________ Chip
| Posted: Sun Jan 17, 2010 11:44 am Post subject: |
Now we need to find a functional G-90 with torched tubes to modify with Thomas tubes. Hmmmm, a functional G-90 might be a little hard to find
| Posted: Sun Jan 17, 2010 12:40 pm Post subject: |
| stefuel wrote: | Now we need to find a functional G-90 with torched tubes to modify with Thomas tubes. Hmmmm, a functional G-90 might be a little hard to find  |
Dochlwd has been wanting to send me a G90 to play with for free. i declined
I think Cliff is the next candidate. I will send him a Tube next week, Unless the used Thomas tube you used is bare again and ready for shipping?
nashou
| Posted: Sun Jan 17, 2010 1:03 pm Post subject: |
| Nashou66 wrote: | | stefuel wrote: | Now we need to find a functional G-90 with torched tubes to modify with Thomas tubes. Hmmmm, a functional G-90 might be a little hard to find  |
nashou |
Shipping a whole g-90 to experiment with is kind of a bitch. I would be willing to look at a G-90 neck board first. If that looks doable and whoever makes a deal with you for the tubes in advance and pays shipping both ways for the projector, I'll give it a shot. As you've seen, it's taken me close to three weeks just to get my own projector done and that's with incentive. So I will absolutely not do it if I have a time frame to adhere to and I will not get involved with one that is not fully functional to begin with.
| Posted: Sun Jan 17, 2010 5:59 pm Post subject: |
Neck rest time. Besides just re-tubing, I have to check the CPU battery and clean up all the wiring. I may also shorten up all three HV leads as they are about a foot to long. It's a bitch to do if you are to short to do it standing on the floor and to tall if you are standing on a foot stool.
| Posted: Sun Jan 17, 2010 9:36 pm Post subject: |
Been pulling my fugging hair out for a couple of hours. I said earlier that the red neck board is layed out different to allow for tube swing but I did not notice that the tube socket is wired a bit different and that there are multiple G1 pins to choose from. Pin 5 on the AmPro blue and green card is un-used. However, pin 5 on the red is a G1. That pin on the Thomas tube is G2. I'm glad I decided to slide the used green in the red position to test the red board. I unknowingly tied G1 and G2 together. I don't think I harmed the used tube as I slid on the extra modded blue card and it fired right up. I think I have it worked out now. I just have to rewire the G2, snip one more socket leg and jump G1 from pin 13 to pin 5 on the trace side.
| Posted: Mon Jan 18, 2010 12:04 am Post subject: |
OK having one small problem. What size resistor did you tell me to go from the arc surpressor to ground? I used 1/4 watt 1M resistors on all three. Now the new green is in. I have seen a couple of arcs in the tube neck and the 1/4 watt 1M sparks accross making a snap. I think you said 1/2 watt but all I had was 1/4 watt. Can I put 2 side by side and make 1/2 watt? The tube might just be clearing it's self of impurities. I'm tempted to leave it running and see if it settles down.
I had the same problem when I installed brand new tubes in my NEC. The blue is fine and the red is also just the green.
| Posted: Mon Jan 18, 2010 1:56 am Post subject: |
The snapping does seem to be less frequent now. It doesn't make me feel all warm and fuzzy with my hand up there doing stig and flare. It started doing it about twice a minute. Now it's down to once every ten minutes or so.
Strange that it's only the new green. Having something to eat now then back to work on beam focus. I'm only going to get one memory location done tonight. That red board set me back a couple of hours.
| Posted: Sat Jan 23, 2010 4:11 am Post subject: |
I no longer think it's the tubes fault. I came home tonight and fired up the PJ. Again I got a snap from the 1M resistor. I pulled both the green and blue neck boards to double check my work. Both boards are modded identical. I re-installed the boards but on different tubes and the snap followed the board. I'll have to go through my stock and see If I have another g or b neckboard to mod or resolve the streaking in the first one. No sense in calibrating until all the bugs are worked out.
The red which was giving me head with braces on is working perfectly. I just need to get one more neckboard to work correctly and all will be well with the world.
These tubes are for sure sharper than LCP's. I don't know how well they stack up to LUG's
CRT_Ben
Joined: 28 Aug 2006 Posts: 1684 Location: Northern Virginia
| Posted: Sat Jan 23, 2010 4:56 am Post subject: |
Chip I ended up potting my modded neckboards with hot glue, because my G2 line was arcing just like Tom's was.
| Posted: Sat Jan 23, 2010 1:16 pm Post subject: |
I just got home from work. I have a little bit of house work to do, then a hair cut. Then I'll have to choose between chasing the old lady or play with the projector.
| Posted: Sat Jan 23, 2010 1:42 pm Post subject: |
| stefuel wrote: | | I just got home from work. I have a little bit of house work to do, then a hair cut. Then I'll have to choose between chasing the old lady or play with the projector. |
Let us know how the projector goes
| Posted: Sat Jan 23, 2010 7:02 pm Post subject: |
| AnalogRocks wrote: | | stefuel wrote: | | I just got home from work. I have a little bit of house work to do, then a hair cut. Then I'll have to choose between chasing the old lady or play with the projector. |
Let us know how the projector goes  |
The old lady won out....................but it was just a quickie.
Now for the important stuff
| Posted: Sat Jan 23, 2010 9:48 pm Post subject: |
| stefuel wrote: |
OH......THE PAIN.......SOMEONE PLEASE MAKE THESE IMAGES IN MY HEAD GO AWAY............
| Posted: Sun Jan 24, 2010 12:51 pm Post subject: |
| macgyver655 wrote: | | stefuel wrote: |
OH......THE PAIN.......SOMEONE PLEASE MAKE THESE IMAGES IN MY HEAD GO AWAY............  |
Oh stabbed in the back with a dull fork.
Anyway, I spent the remainder of the day working on perfect geometry. I now have 960P for std def stuff perfect. I have 1080I for Fios HD perfect. I'm having a problem with 1080P from my PS3. For some reason AmPro's never seem to set up the same way twice. If it doesn't set up correctly, sometimes it's as simple as clearing the active channel and starting over. When I roughed this in last weekend, it set up almost perfectly the first time. I should have left it alone and just tried to tweak it out. BUT NOOOO, I had to be a hero and start from scratch.
I string out my screen to get perfect aspect ratios and geometry. I have pre-drilled holes on my screen frame for center cross and various aspect ratios. Then it's just a matter of getting the all the pin, bow, keystone, skew and linearity correct.
Once you get the green to fill the screen perfectly, which if you are anal-og enough can take a couple of hours per memory location, the red and blue are usually a cake walk. It's not as easy as you might think to get every square on a cross-hatch the same size and every circle on a test pattern perfectly round. This is where the "set up the same way twice" problem comes in. After you've spent all that time on the green, it's a crap-shoot if the red and/or blue will perfectly overlay it. If it doesn't, re-set and start that channel from scratch. I might give up setting up 1080P from scratch and copy 1080I to the 1080P location and try to tweak it out. That might take less time.
I have not figured out why but as far as AmPro's go, it seems that it's the order in which you make your initial corrections is what makes the difference. I don't follow a fixed setup pattern. I just look at the screen and what ever catches my eye first as something that needs correcting gets done then. If it doesn't work, fire up another pot of coffee, 29[code] and begin again
| Posted: Sun Jan 24, 2010 6:48 pm Post subject: |
Interesting info on the setup. I'll have to look for that
