Is your Marquee convergence timing correct? (Advanced setup)
Posted: Wed Jan 13, 2010 12:34 am    Post subject:
Mistake quoted myself, deleted.
dturco
Posted: Wed Jan 13, 2010 4:29 am    Post subject:
What's the fuss all about, now I can get to the root of it. Neutral
http://www.hulu.com/firefly
Posted: Wed Jan 13, 2010 6:53 am    Post subject:
To quote a famous TV show:
" Ho Boy..."
backslap
Posted: Wed Jan 13, 2010 8:52 am    Post subject:
So. I've got the convergence timing corrected now, but the red lines are still a little too thick on the left side. Something I've noticed before is that electronic / dynamic focus was adjusted to 0 there when I got the PJ but changing it all the way up to 100 and everything in beween didn't really improve it.
Could there be something in this Super Secret Menu, such as 'fucus timing' or something that could make this better?
Grtx, Elwin
Posted: Wed Jan 13, 2010 12:42 pm    Post subject:
Yes, just look. Focus and astig have their own delay timing adjustments as well.
CJ
nuttall_chris
Posted: Wed Jan 13, 2010 12:54 pm    Post subject:
Grtx, Elwin
At the bottom of this post you stated that the image was sharp on the tube face. If the image is fine on the tube face this has nothing to do with electronic focus or anything else in the Super Secret Menus. This is a scheimpflug problem.
Chris.
backslap
Posted: Wed Jan 13, 2010 1:28 pm    Post subject:
Nuttall_chris, I agree that it sounds like a scheimpflug problem, but my theory is that while the image looks sharp on the tube from close range, it might still be just a little bit off. Believe me, I've fiddled around a lot with the scheimpflug but there's no way I can get it right like that.
Cmjohnson, alright, I will look. Do you believe the dynamic focus could be corrected this way, though?
Grtx, Elwin
EDIT:
Nutall_chris, I've rechecked the red tube face and you are right: I can see scan lines in the middle and on the right, but not on the left side of the tube! I should have looked better.
backslap
Posted: Wed Jan 13, 2010 1:56 pm    Post subject:
So. I've just tried adjusting the Focus timing but I couln't see any difference...
Do you guys think my problem with the red tube could be solved by doing a complete magnetical setup like so: http://www.curtpalme.com/docs/MARQUEE%20MAGNETICS%20SETUP%20101%20by%20Bill%20Blue.pdf
Or could my focus board be broken?
Posted: Wed Jan 13, 2010 2:49 pm    Post subject:
Backslap, here is a way to see if your scheimpflug is off and if its an electronic issue. Take a piece of whit card board or that white foam board, a nice 12x12 piece is best. go tot he side of the screen it is not focused well and move the card closer to see if you can get any focus, if it does then you need to adjust scheimpflug, if not you have an electronic issue since if its not focused on the tube that un focused grid will transfer to the screen/Card.
nuttall_chris
Posted: Wed Jan 13, 2010 3:18 pm    Post subject:
That will only work if your scheimpflug is off in such a way that the focus plane is in front of the screen, it's also possible that the focus plane is behind the screen making this method a little more difficult to use.
Chris.
Posted: Wed Jan 13, 2010 3:22 pm    Post subject:
Chris.
your correct, but i have not come across that yet and i was hoping his was problem was before the screen not behind it.
But if his screen is off the wall a bit and he has the ability to move the screen back a simple push on the screen will also work.
backslap
Posted: Wed Jan 13, 2010 3:26 pm    Post subject:
Hey guys, thanks for the suggestion but I already tried that and it has no effect.
I've adjusted scheimpflug a numer of times, I also tried if screwing all the bolts out a few turns, or in a few turns made any difference but it doesn't. On a 31KHz signal I can see scanlines all across the screen, just slightly less obvious on the left side, but on a 120KHz signal there are definitely no scanlines on the left and tje lines on the left just get so thick that when I converge the PJ on a crosshatch, the red sticks out of the white on both sides.
Let me make it clear that this isn't obvious when viewing a movie, but you guys know how it is with these things, right! Wink
EDIT:
Also, Nashou66, I saw in another thread that you've done the magnetics alignment and you warned about doing it on the floor and having to do it all over again on the ceiling. How would you advise I align my PJ magnetically? Just on the ceiling then?
Posted: Wed Jan 13, 2010 3:35 pm    Post subject:
EDIT:
This sound like a bad red channel for the dynamic focus. do this test swap cables for the green and red focus cables and see if it follows.
yes don't bother with CPC magnets till you move it to the ceiling.
backslap
Posted: Wed Jan 13, 2010 3:40 pm    Post subject:
Where can I find the focus cables?
Posted: Wed Jan 13, 2010 3:42 pm    Post subject:
they are going to the board between the red and green tubes. lift off the cover and pull the board out. the cables colors are marked on the PCB board or just follow the wires to the tube itself.
backslap
Posted: Wed Jan 13, 2010 3:54 pm    Post subject:
We have a winner!
What do I do about this? Get a replacement for the whole board of can I do something about this myself?
By the way, this isn't exactly related to Convergence timing anymore. Should I open a new thread for this?
Grtx
Posted: Wed Jan 13, 2010 3:58 pm    Post subject:
your correct, if you look to the my marquee maintenance thread i have the solution there, but it could be caused by another problem. The mosfet amps that switch in and out certain caps for the higher bandwidth resolutions are not working. I fixed it for a little while but it went out again. so i still need to track it down.
id just look for new board, in the buy and sell section there was some one selling it cheap, or Curt can get you a known working one, its probably the cheapest board to have go bad, so your lucky.
Posted: Wed Jan 13, 2010 4:07 pm    Post subject:
Interesting. I still haven't gotten into the secret menu (and won't for a while) but: how do you adjust it? With the convergence timing it was obvious -- skew the convergence and see if it was lined up properly. What about focus & stig?
Posted: Wed Jan 13, 2010 4:24 pm    Post subject:
I also have not looked into it, id assume if you put up a grid for all three with the service rgb all set to 50, then separate each grid so they are clearly visible from each other . I would assume that each color has its own timing adjustment, so youd select a color till you got the best focus, then move tot he next. till all have the same focus at the 50 RGB service menu setting. now when you adjust the global focus all colors react the same.
Make sense? its just how i think it should work, I wonder if I am correct. Smile
Posted: Wed Jan 13, 2010 6:28 pm    Post subject:
Yes, or just hit COLOR 2 and do your adjustments on green only.
You would want to intentionally misalign the grid (shift the focus and astig so they're NOT sharp) so you can see best how they work
when you change the delay settings. It doesn't do much good to have everything already turned to the sharpest settings, not when
setting the delays. You need to see WHERE the adjustments are working on the screen for this, not try to make those misadjusted zones
look their best with this adjustment.
It's very important to realize that. When setting delays, you are NOT tuning for best picture. You're putting the active adjustment zones
where they need to be.
As has been mentioned earlier, there are trim pots on some of the related boards. Some of them are used to match up the delay
timing between one color and another.
CJ
Page 3 of 8
