| Posted: Mon Jan 04, 2010 11:16 pm Post subject: Mac: Broken Sony KP-53V80 4:3 set. No Red or Blue output |
Hi Mac, my neighbour was just given a Sony KP-53V80. I'm just heading out to have a look at it. There's no output from the Red tube he says. We'll tear it apart and see what's what.
Any known issues with this chassis? STK chip? etc....
TIA man
| Posted: Mon Jan 04, 2010 11:28 pm Post subject: Re: Mac: Broken Sony KP-53V80 4:3 set. No Red output |
| AnalogRocks wrote: | Hi Mac, my neighbour was just given a Sony KP-53V80. I'm just heading out to have a look at it. There's no output from the Red tube he says. We'll tear it apart and see what's what.
TIA man |
Fingers swollen today?
I think you mean KP-53V80....... Ya got it right in the heading but I didn't notice it until now. I can't HEAR you....
Let me see what I got........
| Posted: Mon Jan 04, 2010 11:36 pm Post subject: Re: Mac: Broken Sony KP-53V80 4:3 set. No Red output |
| macgyver655 wrote: | | AnalogRocks wrote: | Hi Mac, my neighbour was just given a Sony KP-53V80. I'm just heading out to have a look at it. There's no output from the Red tube he says. We'll tear it apart and see what's what.
TIA man |
Let me see what I got........  |
Hahah nice. Semantic's aren't they grand?
BTW I blame this keyboard. It likes to type extra characters from time to time just for the hell of it.
| Posted: Mon Jan 04, 2010 11:43 pm Post subject: |
I pulled a copy of the SM so I have that.
Did a check and no common failures, which is a good thing.
I'll check for service bulletins.
STK's wont cause no red.
Let me know what you have after you get a look at it.
| Posted: Mon Jan 04, 2010 11:45 pm Post subject: |
No red output is a video issue, not an STK issue. The last time I had one, the video output chip was bad, and it was mounted right on the CRT socket. All three should be identical if the chip is on the socket, and you can swap neck boards to see if the problem is on that board.
If it's not, then try putting up the test/convergence pattern to see if that works on the red. If so, check other input connections, whatever one was being used could have cracked on the input PC board.
| Posted: Tue Jan 05, 2010 12:53 am Post subject: |
Just got back. I have it all apart. No obvious burnt components. We've now lost the blue as well.
All tubes are glowing.
I've got raster on the Blue and the Red, no image.
Green is fired up as normal projecting a picture.
I had to chide my neighbour for twiddling with the lens focus before I got there. He said he just couldn't help himself
The green neck card is different than the blue and the red. If the tube numbers are the same shall I swap the green socket to the red then the blue?
I haven't done a close examination of the neck cards yet.
| Description: |
| Filesize: |
110.99 KB |
| Viewed: |
106 Time(s) |
| Posted: Tue Jan 05, 2010 1:35 am Post subject: |
| AnalogRocks wrote: | Just got back. I have it all apart. No obvious burnt components. We've now lost the blue as well.
I haven't done a close examination of the neck cards yet. |
How about menus?
| Posted: Tue Jan 05, 2010 3:13 am Post subject: |
Ok done playing for the night. Everything's green.
The menu's are all green, the quick focus was green only. The neck cards are glued in place so I'll have to try chipping away at it if we want to swap neck boards.
The power LED on the front is flashing slowly RED.
The green also has a diagonal retrace lines that are arced back and forth across the screen:
| Description: |
| Filesize: |
75.36 KB |
| Viewed: |
93 Time(s) |
| Posted: Tue Jan 05, 2010 3:38 am Post subject: |
I need very specific answers.
1: Does the green display clear video?
2: Is there sound?
3: Is the menu clear?
4: If menu is clear can you go into the menu and look for an adjustment screen for red/blue and does it bring up a cross hair?
| Posted: Tue Jan 05, 2010 3:41 am Post subject: |
oh yea.
5: How many blinks per cycle, if it pauses between a certain number of blinks.
I'll guess 5.
| Posted: Tue Jan 05, 2010 4:03 am Post subject: |
| macgyver655 wrote: | I need very specific answers.
2: Is there sound?
4: If menu is clear can you go into the menu and look for an adjustment screen for red/blue and does it bring up a cross hair? |
1: No, the green's very washed out.
2: Yes, the sound is perfect
3: No the menu's not very clear at all.
4: I can't enter the setup. It keeps telling me to connect the TV cable even though it's already connected.
| macgyver655 wrote: | oh yea.
I'll guess 5. |
5: I'll check tomorrow.
| Posted: Tue Jan 05, 2010 4:14 am Post subject: |
Can you change components? I don't know if I ever asked you that, LOL.
| Posted: Tue Jan 05, 2010 5:20 am Post subject: |
Engine and transmission yes. Soldering maybe....
Here's what the menu's looked like.
| Description: |
| Filesize: |
70.75 KB |
| Viewed: |
72 Time(s) |
| Posted: Tue Jan 05, 2010 5:57 am Post subject: |
I'll PM you tomorrow on what you gotta do........
| Posted: Tue Jan 05, 2010 6:18 am Post subject: |
| macgyver655 wrote: | | I'll PM you tomorrow on what you gotta do........ |
Cool thanks
| Posted: Fri Jan 15, 2010 4:39 am Post subject: |
OK I poked around as per Mac's instructions. Those capacitors look ok. However I couldn't find any of my 5 DMM's So I'll have to test them later.
I did manage to snap a piece of the power supply board off though damit! There's a really tight spade lug in the middle of the board I pulled and wigled, wiggled and pulled. Then the board snapped.
The hardest connector was on a peninsula part of the board with a moat machined around it. 1/4 inch or board holding on one end and 3/8" of board on the other. Stupid design.
SO I have to fix that too. ( grumble...sony...grumble )
| Description: |
| Filesize: |
166.9 KB |
| Viewed: |
50 Time(s) |
| Description: |
| Filesize: |
85.95 KB |
| Viewed: |
50 Time(s) |
| Posted: Fri Jan 15, 2010 4:55 am Post subject: |
| AnalogRocks wrote: | | Those capacitors look ok. |
You are joking, right?
| Posted: Fri Jan 15, 2010 4:56 am Post subject: |
| macgyver655 wrote: | | AnalogRocks wrote: | | Those capacitors look ok. |
You are joking, right? |
No, I'll post pictures in a minute. My card read came unplugged.
| Posted: Fri Jan 15, 2010 4:59 am Post subject: |
The caps I PM'ed you to change stated, change them, dont look at them, dont test them...... change them. Then I said just look around for any visual things.
