Say it aint so!
Posted: Sun Jan 03, 2010 5:34 pm    Post subject:
Oh, and let me add that the illustration that I used, uses the same LED chips that that Marquee claims to use. Its the same as those used in some RPTVs.
Posted: Sun Jan 03, 2010 8:52 pm    Post subject:
macgyver655 wrote:
This is not how the process works. It does not mix to white prior to DMD contact.
?? That's sure what your illustration shows... isn't it!?
Posted: Sun Jan 03, 2010 8:58 pm    Post subject:
Nope. Do we need to have class? Laughing
Posted: Sun Jan 03, 2010 9:53 pm    Post subject:
(pulls up a desk at the back of the class room)
Posted: Sun Jan 03, 2010 10:00 pm    Post subject:
So your the one back there throwing erasers.
I think you guys just like to here me talk.... Laughing
I need more then 1 curious person..... Mr. Green
Posted: Sun Jan 03, 2010 10:07 pm    Post subject:
(Raises hand) May I go to the bathroom please?
Posted: Sun Jan 03, 2010 10:30 pm    Post subject:
Hate to correct the teacher before class ever begins ( actually I love to do it )
But that should be hear me talk Laughing
"here me talk" would imply you were here talking to us...wait a second..... was that just a clever double entendre? Very Happy
Posted: Sun Jan 03, 2010 10:37 pm    Post subject:
Hey.....you want to teach this class? Twisted Evil
This is not english class!!!! Laughing
But its nice to see you've learnt sumtin....... Shocked
Posted: Sun Jan 03, 2010 11:52 pm    Post subject:
Just like my 9" plow....................You're bagged buddy Laughing
See what happens when your fingers work faster then your brain Mr. Green
Posted: Mon Jan 04, 2010 12:00 am    Post subject:
Alright, but I'm not going to make it easy. There will have to be participation. So you guys can understand whats happens HERE, you'll have to answer questions for me to continue.
First, lets go back before LEDs and look at a DLP that is bulb lit. The bulb is white light so how do you think it is able to make colors on the screen?
Posted: Mon Jan 04, 2010 12:16 am    Post subject:
Mac,
I am interested in how the LED pjs work along with how well the current RPTVs are holding up.
As for VDCs engine, I am not sure if it is laid out like in Mac's post. I do know that Scott said they aren't doing anything different than the other LED pjs.
dturco
Posted: Mon Jan 04, 2010 12:34 am    Post subject:
The spinning color wheel is timed to send the individual r,g,b light through?
Also I am VERY interested in the LED projectors, for the 3 year cycle that I see before GOZER needs replacement with a new comparable technology OR tubes.
http://www.hulu.com/firefly
Posted: Mon Jan 04, 2010 1:25 am    Post subject:
Anyone else, agree/disagree?
Posted: Mon Jan 04, 2010 1:37 am    Post subject:
As it pertains to a while light bulb projector, yes.
That's why the rainbows on DLP.
Posted: Mon Jan 04, 2010 1:42 am    Post subject:
So if I was to say incorrect? Very Happy
Posted: Mon Jan 04, 2010 1:45 am    Post subject:
I'd probably retort " I don't give a rat's azz about DLP" Laughing
Or I'd ask why, shut my mouth and maybe learn something from my cunningly linguistic teacher. Laughing
Posted: Mon Jan 04, 2010 3:07 am    Post subject:
It's not NECESSARY, though. Each DMD in a 3 chip system gets fed separate red, green, and blue light anyway. Why mix and unmix from RGB to white then back to RGB? You lose lumens by doing that as no optical system is 100 percent efficient.
I don't quite understand youir comment "and although 3 chip is possible I haven't heard of any yet". Certainly you know that 3 chip DLP engines were the first type of DLP engines to be developed and all the highest output projectors use 3 chip engines.
The Phlatlight is also available in a single RGB module (driven sequentially, R, then G, then B, typically) for use with one chip engines, and they're available in individual color modules as well.
The single RGB module, driven sequentially, allows you to create a single chip DLP projector that has NO color wheel, too.
This by itself is a nice development because we know that the color wheel motor is a weak point in the design. Particularly
in unsealed optical engines.
I think that the ideal configuration would be to dedicate one Phlatlight color module to its own DMD optical system, lighting it up right at the DMD with appropriate light guides to ensure even DMD illumination and minimal losses. The system output would be combined conventionally into a single lens.
CJ
Posted: Mon Jan 04, 2010 3:15 am    Post subject:
Answering Mac's question: DLPs take the white light from a bulb and split it into 3 colors. Some split it simultaneously, sending the 3 colors out to 3 DLP chips; others split it temporally, with a color wheel that passes sequential R/G/B/etc colors.
Ahh. I got it, Mac. The light from the 3 lasers follows the path in your diagram, but NOT AT THE SAME TIME. It never mixes into white light (except in your visual perception system) because only one of the 3 LEDs is on at once. Duh. Smile
Posted: Mon Jan 04, 2010 3:36 am    Post subject:
Ok then, lets just say that it's partially correct. The color wheel is not timed to allow the light to pass through the colors. The color wheel just spins, usually anywhere from 8 or 9 thousand to 15 or more thousand RPMs. Also note that there are different color wheels, designated by number of segments. A 4 segment is usually RGB and white, a 7 segment adds cyan, magenta, yellow. There may be other varieties but you get the basic idea.
So you have a bulb that is at a constant brightness and a color wheel that is just spinning away. As you can see, the colors are never mixed in this sequence, they each pass at their own individual time.
So as the varying colors of light come off the color wheel they are then reflected onto the DMD (Digital Micromirror Device). The DMD is a device that has several hundred thousand microscopic mirrors that can be turned to either reflect or not reflect light. Any light that is reflected is then directed to the lens which projects the image.
So how does this happen.
Lets slow down the color wheel to observe 1 revolution and we will use a 4 segment wheel. As the red part of the wheel is in front of the light tunnel (a mirrored tunnel that the light from the bulb passes through) the red light beam is reflected to the DMD. Now the processor will determine which mirrors to turn to reflect the red beam through the lens. Which mirrors are turned it based off the video signal so the DMD will have a reflected image.
As the wheel turns to the green part, the process now begins as to which mirrors are turned to reflect the green part of the image...... and so on.
There is a marker on the color wheel so the processor knows the location of the wheel at all times.
The DMD must reflect each color multiple times to produce 1 frame of image and then 60 frames per second if that is the selected refresh rate.
The intensity of a color in various location of the image is determine by how fast a mirror is turned on. The stronger a color is needed, the faster a mirror is cycled on.
ANY QUESTIONS ??
Edited for correction.
Posted: Mon Jan 04, 2010 3:44 am    Post subject:
Um, minor quibble. The brightness isn't determined by the NUMBER of mirrors, but by HOW MUCH TIME each pixel's mirror is flipped to the "full on brightness" position. Those little suckers flap like a mofo to regulate the level of brightness -- more "on" time (during a single frame) translates to a brighter pixel during that frame. See e.g. bullet 2 on this page.
Page 2 of 7
