Geek stuff you are doing right now
Goto page 1, 2, 3  Next
Posted: Fri Jan 01, 2010 7:46 am    Post subject: Geek stuff you are doing right now
Jan 1/10 1:45am
I'm just (re) working my HTPC to play bluray's at 1080i/72.
Currently watching Braveheart Sapphire edition
What geeky thing are you doing now?
Posted: Fri Jan 01, 2010 7:55 am    Post subject: Re: Geek stuff you are doing right now
Jan 1/10 1:45am
Talking to you....... Laughing
Posted: Fri Jan 01, 2010 7:56 am    Post subject:
Ok, you got me there....er.....here. That's a pretty geeky thing to do.
huggy
Posted: Fri Jan 01, 2010 8:01 am    Post subject:
Ripping bd's and converting to mkv's,I've just finished Inglorious Basterds and am now doing District 9 Very Happy
LOTREE
Posted: Fri Jan 01, 2010 8:13 am    Post subject:
Just home from tonites shindigs reading what you're all posting. Went out looking for screens today as I'm itching to get the projector setup correctly. Going to check out some WilsonArt next week then hope the HTPC is shipped from NCIX and I'll also need either a VGA extension cable or just a longer BNC one. Nothing Geeky yet... Rolling Eyes
akajester
Posted: Fri Jan 01, 2010 3:25 pm    Post subject:
remuxing transformers 2 imax edition for tonight viewing. while waiting, vpn'd into work to turn off the "check filter" alerts from the server room cooling unit. I woke up to over 250 emails from the darn thing. Smile
Matrix
Posted: Fri Jan 01, 2010 3:39 pm    Post subject:
Have to swap out monitors on this computer today. This one is having issues with the HV supply and flickering. Not too geeky but necessary.
Dennis in Indy
Posted: Fri Jan 01, 2010 3:47 pm    Post subject:
Muxing BD's and HD-DVD's to MKV on my HTPC, done ~50 so far.
Posted: Fri Jan 01, 2010 4:02 pm    Post subject:
Scanning Computer websites putting together an htpc for the Bedroom and a NAS unit for the network...
MikeEby
Posted: Fri Jan 01, 2010 4:06 pm    Post subject:
Tinkering around with the eac3to gui.
BradTheAggie
Posted: Fri Jan 01, 2010 4:18 pm    Post subject:
Trying to get UltraVNC to work under Windows 7 Professional...
(bholman on the AVS forum)
Posted: Fri Jan 01, 2010 4:46 pm    Post subject:
Readin all the crap you geeks are postin.......... n Laughing
JK.............
Posted: Fri Jan 01, 2010 4:48 pm    Post subject:
Investigating the cause for a speckle problem in the display of a Barco SLM R6 3-chip DLP projector. It looks like stuck pixels, but only
when there's an active signal present. Which means it's NOT stuck pixels Interesting. Some of the pixels flicker rapidly but at a clearly visible rate, as well. And a few go on and off erratically.
I have two of these PJs to go through and test, and eventually, sell. Perhaps one will give me the cure for the other.
CJ
Posted: Fri Jan 01, 2010 4:54 pm    Post subject:
Could be a poor connection from 1 of the DMD panels to the main board. The DMD is usually a solderless BGA style to its board and usually a film style ribbon cable to the main board. Also could be a connection in other locations.
Posted: Fri Jan 01, 2010 5:01 pm    Post subject:
CJ
A lot of the commercial 3 chip DLP projectors has special setups in the menu to adjust that problem out.
They're not plug and play like the consumer units are. You really have to tweak the image on them, and there should be something in the menu that would allow you to do that.
I've never seen that Barco unit, but if it's using TI's DLP's, then it going to need some tweaking to get around those pixel problems.
Posted: Fri Jan 01, 2010 5:10 pm    Post subject:
Does it have an OSD? If so are the sparkles in the menu also?
Posted: Fri Jan 01, 2010 5:30 pm    Post subject:
Visiting in-laws in Phoenix, so no projects. Geekiest thing I'll do today is take my kids to Avatar 3D Imax. Smile
Posted: Fri Jan 01, 2010 5:32 pm    Post subject:
Laying out all the pages and hooking up IR codes for the iPhone- or iPod touch-based remote I'm beta-testing, so I can start making custom buttons for it all.
MikeEby
Posted: Fri Jan 01, 2010 5:36 pm    Post subject:
COOL!
Posted: Fri Jan 01, 2010 5:45 pm    Post subject:
Yes, it has OSD and the sparkles (lit pixels) are visible in them, and in the internal test patterns. I'll investigate the service menu
adjustments and see what's in there. And, some adjustments require a PC connection, I think. If I can get the software from
Barco, that may be the way to go. Hopefully it's just a free download.
I'm also having trouble getting the unit to display a picture from an upscaling DVD player with a DVI output. I'm going straight from
DVI to DVI (the PJ has two DVI inputs and yes, they're selected active) and I can see the Samsung startup screen but when the disk
goes to play, the screen goes blank. Background only.
I'm about ready to grab my extra computer from work and bring it into the garage and just feed it signals via 5 wire from VGA.
These projectors came from a theme park attraction. I'm still not quite sure why they were surplussed out as they're in generally great shape and the lamps are (a) hideously expensive, and (b) are very low hours. The only real problem is that there are two projectors
but only one lens between the two of them. And those lenses are expensive. The one lens I got with them is very short throw, just
screen height x 0.85. I'd prefer a lens that was a little longer, around a throw formula of 1.2 to 1.5. But I can't be picky.
If anyone has any extra Barco TLD lenses hanging around, part number starting with R98406xx, R98407xx, or R98409xx, I'd sure
like to see about making a deal if it's one of the right lenses.
CJ
Page 1 of 3
