SweetChuck
Joined: 01 Jun 2007 Posts: 134 Location: Queensland Australia
| Posted: Mon Dec 21, 2009 10:45 pm Post subject: |
| Nashou66 wrote: | Is it all colors do not focus well or just one or two?
But id get a board from Curt they are cheap and spares are always good to have around, maybe pick up a few other board while your at to save on shipping.
Athanasios |
It seems to be all colours, I haven't confirmed yet if it at different frequencies
SweetChuck
| Posted: Fri Jan 08, 2010 11:17 pm Post subject: |
Well its not the focus board I got 2 off curt and the same result. It seems to try to adjust the edge focus but its too far out of whack from side to side. The left hand side is especially bad, If I did have low HV wouldn't the picture be larger due to low beam acceleration ??
BTW I replaced all the bellows and glycol , What a sh*t of a job
Gino are you still around and do you have any modules I may be able to borrow, I think we are the only Marquee owners in Aus . This is turning out to be expensive getting bits from overseas .
| Posted: Sun Jan 24, 2010 12:06 am Post subject: |
OK, it doesn't look like it's the CLM either. Works fine here, although the memory was gone when I got it (battery is OK).
Any other ideas?
| Posted: Sun Jan 24, 2010 1:03 am Post subject: |
Never mind, the board is bad. (CLM). THe astig section is funky, the focus is fine. Helps to boost the contrast to 90, and see the dots turn into lines.
