Anyone else have this problem with 720p?
Posted: Thu Dec 17, 2009 1:10 am    Post subject:
Mark_A_W wrote:
Zebu Fellenz wrote:
Craig,
Quick question. If I got a processor like the Lumagen could I place it between my HTPC and my G70 so when I'm watching a Blu-ray in 2.35:1 or 2.40:1 I could keep feeding 1080p 60 into the lumagen and then feed out 800p 60? I also have some issues with the porches on my 1080p 60 output that the Nvidia control panel won't fix, and powerstrip won't run right on Windows 7. Could the Lumagen be setup to easily fix these problems like I did with powerstrip in the past.
I know most people don't use a processor with a HTPC but the convenience sounds like it may be worth it, in addition to being able to easily add other sources in the future.
Erik
Don't use Powerstrip with an Nvidia card, use the Nvidia custom resolution settings.
Unless you want to do something "else" with the Lumagen, it is a total waste fitting it between a PC and a CRT.
Mark,
I would use the Nvidia custom resolution if it worked Wink
I kind of works some of the time, but I've wasted enough time trying to get it to do what I need it for, Maybe I should just get an ATI card and go back to Powerstrip?
Posted: Thu Dec 17, 2009 1:49 am    Post subject:
It works fine.
I have it running 1080i 72hz for my TV PC.
What problem have you had with it?
Kiev Savoie
Posted: Sun Jan 31, 2010 2:43 am    Post subject:
I think i need to start saving for Lumagen. Belated thanks to everyone for the comments.
Kiev Savoie
Posted: Sat Feb 20, 2010 10:51 pm    Post subject:
Just reread this thread. Yes it is time for a video processor!
