Marquee longbow issue, vertical bars.Scott Any Ideas?Solved
Goto page Previous  1, 2, 3, 4, 5
Posted: Sat Feb 27, 2010 11:24 pm    Post subject:
draganm wrote:
Thanks Craig, looks like the moving of wires helped. But the issue is still there for oscillation on the SAB board Like TSE stated. I noticed they use a new chip the EL2245 and its a 100Mhz chip and that seems like the noise getting through.
I am pretty sure i seen a SAB board with the MC3402 chip which is much less. I am at work now so have to look.
Steve and I were talking and He thinks he used the TLE2072 chip there. I have some at home and might try it. But i have to wait for his confirmation. Not sure what bandwidth requirements are needed for the astig adjustment but i don not think its a high bandwidth need, unless its dependent on the refresh rate your running,
EDIT: Ok just got home and the older boards have the same chip. Maybe Steve was mistaken, have to wait and see.
Any confirmation on a replacement for the EL2245CN? I'm not looking to hot-rod this board, simply looking to repair a SAB channel and the EL2245CN is no longer available? Sad
Never heard back from steve but doing some quick research I think this chip might work:
http://www.intersil.com/data/fn/fn7058.pdf
http://www.mouser.com/ProductDetail/EL2227CYZ/?qs=2VKgqYuc3OtW9NqIU4REvA%3d%3d
Posted: Sun Feb 28, 2010 12:08 am    Post subject:
I'll give it a shot
Posted: Sun Feb 28, 2010 12:32 am    Post subject:
thanks Nash, I'll give it a try. Probably best to replace both on that channel so they match
I actually think they might be way better, look at the voltage input and Current noise figures for the original and the replacement. The original was tested at 10khz and had more noise, usually if you raise the frequency noise also rises. the replacement chip is 10x lower noise figure at 100khz!!!! so that would suggest even much lower at 10khz.
I am interested to see the results.
HK-Steve
Posted: Sun Feb 28, 2010 9:00 am    Post subject:
Sorry Guy's, I have not been on the computer for the last couple of days.
I do use the TLE2074 in place of the MC34084's on a number of boards.
I don't replace the EL2245's, I looked at this, but never got past talking about it with Athanasios, too many other things on my workbench Sad
Cheers
Steve
Posted: Sun Feb 28, 2010 5:15 pm    Post subject:
Cheers
Steve
I ordered 2 last night and I'll let everyone know. I too am buried so don't expect any scoped pics , Just looking to get this board working quickly. Clipped a transistor down pushed over and it shorted to the clip, not hard to do after soldering for 6 hours+ Sad
Posted: Sat Mar 27, 2010 4:05 pm    Post subject:
oops, that's not it
 Filesize:  74.32 KB
 Viewed:  6049 Time(s)
Posted: Sat Mar 27, 2010 4:20 pm    Post subject:
Ooops is right, i forgot it was the dip version not the SOIC. Sorry drags, thought you would double check.
Athanasio
Thats why those data sheets are so handy. It indicates they are not the same style.
Cant say I haven't made the same mistakes before also. I'm very cautious myself anymore. Very Happy
Posted: Sat Mar 27, 2010 4:25 pm    Post subject:
http://www.sierraic.com/pnresults.asp?part=EL2245CS
edit: scratch that. it has to be a CN
Posted: Sat Mar 27, 2010 4:37 pm    Post subject:
any chance of jumping the legs over to the through holes with fly-wire?
Posted: Sat Mar 27, 2010 4:55 pm    Post subject:
http://www.sierraic.com/pnresults.asp?navpart=el2245cn&r1=4
tse
Posted: Sat Mar 27, 2010 6:17 pm    Post subject:
Fly wire would work. Keep them short.
Check to make sure the pin-out is the same and if it is something like this can be found, search for msop to dip adapter.
Scott
 Filesize:  85.59 KB
 Viewed:  6012 Time(s)
Thomas Jefferson
Posted: Tue Jan 10, 2012 12:15 am    Post subject:
Reviving this thread to ask if this(tlc2272) would be a good replacement for the EL2245 since Scott says that the SAB only needs maybe up to 2mhz bandwidth chip.
Pin out looks the same, the lower bandwidth would make this an active filter for the SAb and then the ferrite clamps would not be needed.
http://www.ti.com/lit/ds/symlink/tlc2272am.pdf
Posted: Tue Jan 10, 2012 1:15 am    Post subject:
Man just had some nostalgia here. Went back looking all over for that pic and came across the SAB and CMM issues with my Longbows in another thread. That was where you accidentally bought the SOIC chips instead of DIP chips for the SAB. Did you ever buy those SOIC to DIP adaptors to test those out?
https://www.curtpalme.com/forum_archived/viewtopic.php@t=19086.html
nope. IT was easier to just replace the amp. It didn't seem like the chip was the bad part anyway, not sure really what bolew on that board. One of the transistors got bent over during re-assembly and shorted against a heat-sink clip. Spent some time on it and then moved on to better things
Page 5 of 5
