| Posted: Tue Dec 15, 2009 12:56 am Post subject: |
| draganm wrote: | | dturco wrote: | And Dragan, more importantly for me, how could this be my fault? Be sure to make an itemized list,oKay?  | I meant that you haven't even got this thing straightened out yet and your ready to swap in Sony yokes which re-quire a bit of experience to modify, install, and adjust properly.
Any chance that you simply thrive off all this chaos and drama?  |
Never never never attempt to mod a unstable projector.
And when it is stable, one mod at a time, tested before you move on. Even just re-capping boards. Change out a few parts and test it.
_________________ Chip
dturco
| Posted: Tue Dec 15, 2009 3:24 am Post subject: |
Wow, so if it is a yoke I should buy Marquee yoke just to throw away? In other words why not find the problem with whatever yoke it is {if it is a yoke} and use the Sony's as the replacement instead of swapping in a marquee yoke and then swap that out for the Sony's later?
I mean if the yoke is bad why not just replace it once with what is the better [Sony] yoke anyway?
I'm not going to do the Frankenyokes if the yokes aren't the problem, but if they are, why do it twice? Why not do it while it's apart?
I realize that all of the yokes wouldn't need to be done if only one is bad, but why not do them all while your working on it?
Try this scenario, you pull the transmission from your car to fix the valve body or something like that. The parts to fix that are $125, or a complete rebuild kit including that valve body part is only $175. Do you just do the $125 fix or do you rebuild the WHOLE thing while it's apart?
Me I'll do the whole thing because it's already out of the car and the price difference is small. But opinions vary so...
Did I miss something here?
Also I'm swapping in a new power supply on Thursday to verify it's not that.
http://www.hulu.com/firefly
| Posted: Tue Dec 15, 2009 3:28 am Post subject: |
The Frankenyokes are the focus coils, not the main yokes. You can have a main yoke for the price of shipping, I have piles here...
dturco
| Posted: Tue Dec 15, 2009 3:31 am Post subject: |
| Curt Palme wrote: | | The Frankenyokes are the focus coils, not the main yokes. You can have a main yoke for the price of shipping, I have piles here... |
Well that's completely different then isn't it?
I misunderstood> What were the chances of that ?
| Posted: Tue Dec 15, 2009 3:38 am Post subject: |
BTW, let me also point out that I think we're on the wrong path here with the AC power grounding thing.
With every strange problem I've ever had in electronics, and I am stumped, I end up going down some strange path of AC power, some tiny rare flaky component, or the fact that I didn't install directional cables ( ). In EVERY case it turns out to be something completely logical, which ends up putting my faith back into electronics, the fact it's so logical.
Here's my take on the grounding thing:
Even if the AC ground was flaky, the chassis itself is ground to the components inside the set, so even if there was no AC ground to the projector itself, the entire chassis itself is a ground reference to everything that the power supply feeds.
Trust me, this is bugging the crap out of me. All I can think is that something is giving out massive harmonics, I'm guessing the yokes, that are affecting the cell phone. I don't think this is AC power related at all.
Hey, try this:
Unplug one of the H deflection coils with the set off, and power up. That will kill the HV and H deflection. I'll bet the cellphone works.
Also, try leaving the H deflection coils plugged in, and yank out the HVPS and power up. I'll bet the cell cuts out.
I'll bet you guys a donut!
dturco
| Posted: Tue Dec 15, 2009 3:45 am Post subject: |
Sounds good Curt, I'll try tomorrow, I'm a bit burnt out from my trip to Philly. And thanks for the yoke offer too.
| Posted: Tue Dec 15, 2009 4:52 am Post subject: |
| Curt Palme wrote: | BTW, let me also point out that I think we're on the wrong path here with the AC power grounding thing.
Hey, try this:
Hey if this doesn't work does that mean you end up with 'yoke' on your face?
| Posted: Tue Dec 15, 2009 4:55 am Post subject: |
No silly, I become a glazed donut!
| Posted: Tue Dec 15, 2009 1:10 pm Post subject: |
| Curt Palme wrote: |
A yoke was my thought as well. AC grounding I could never see causing this. As you mentioned, there's some harmonics or better put, there's very aggressive harmonics in play here. It has to be in order to interfere with a cell phone.
Right now the projector is stock with no mods or tweaks (that I know of). I had him remove the video chain mods. Nothing else was ever done to it by me. If I knew beforehand that there was a noise problem as such in this marquee, in no way would I have upgraded that video chain to a later version of the mods.
I took a beating on this one and blamed for possible other problems in the set, when I was only trying to help out. And I think I should still try and help out, so he'll be bringing some things here for me to further check on my test unit on Thursday. I'll also have a few other people stopping by for one reason or the other. While they're here, we'll all look at this at the same time.
When this problem came up in another thread, I had mentioned that we'll be getting him out of the mods. I had three request for them, but someone had already asked for a set a week before. That person is purchasing the boards from him this week. And he'll be leaving here with a version of the mods he had before the upgrade, which should not be effected by the interference.
I am not a source for mods - any that's mods
He also claims that the interference is getting worse, and causing some other problems that may not have been there before.
dturco
| Posted: Tue Dec 15, 2009 5:51 pm Post subject: |
Hey, try this:
Ok I pulled the white connector, Of course the H fail light comes on but the cellphone works. I plugged it back in the cellphone cut off. I pulled the H/V supply and the phone keeps working, I put the H/V power back in the phone cuts off. I unplug all three tube H/V leads from the splitter, the phone still wont work that way.
So what have we figured out? It's the H/V power supply? Not the yokes?
1031
dturco
| Posted: Tue Dec 15, 2009 6:45 pm Post subject: |
| 1031 wrote: | | One thing came on my mind, Athan has that oscillating stig amp, could this be same issue? least worth of test that also. One another thing, you said that you get sparks/snaps sometimes, so open all tubecovers and see if there is blue glow inside tube. I had that once (whit oscillating neckboard) and that issue messed colorbalance and did loud snap time to time. |
Thanks for the thought, but we Checked that and all of the other boards on the backplane in previous rounds of diagnostics.
dturco
| Posted: Tue Dec 15, 2009 7:55 pm Post subject: |
| dturco wrote: | | Curt Palme wrote: | BTW, let me also point out that I think we're on the wrong path here with the AC power grounding thing.
Hey, try this:
So what have we figured out? It's the H/V power supply? Not the yokes? |
Bueller? Bueller?
| Posted: Tue Dec 15, 2009 8:17 pm Post subject: |
| dturco wrote: | | dturco wrote: | | Curt Palme wrote: | BTW, let me also point out that I think we're on the wrong path here with the AC power grounding thing.
Hey, try this:
Bueller? Bueller? |
Wait, when you pulled the hVPS did you have the yokes connected or not? Curt wanted you to pull the HVPS with the yokes connected. to me it seams its one of the yokes, so now you need to hunt down which one. do one H yoke at a time and power up, putting the previous one you disconnected back in so only one yoke is disconnected at a time, if its a yoke this should let you know which one is bad.
At least i think it should work that way.
dturco
| Posted: Tue Dec 15, 2009 8:33 pm Post subject: |
The Yokes were connected when the H/V power was pulled, and powercord was unplugged during H/V removal and then plugged back in, then turned on.
The H yokes done were the blue first, turned on P/J phone worked. Plugged blue back in phone didn't work. Unplugged green, phone worked, plugged green back in, no phone. Left all three H wires attached, pulled H/V power supply phone worked. Put H/V power supply back in no phone.
Unplugged all three H/V anode leads, left H/V lead from H/V supply in splitter and left all h/V wires connected. H/V power supply out P/J powered on, phone worked, H/V in and powered on, no phone.
Edit: GOZER was powered off each time between wire pulling and lead pulling, just in case anyone was wondering.
dturco
| Posted: Tue Dec 15, 2009 9:50 pm Post subject: |
| Nashou66 wrote: | ok sounds like the HVPS main lead might be it or the HVPS itslef, just to make sure, when all HV lead were not connected you had the H yokes all connected. right?
Athanasios |
Yes
dturco
| Posted: Wed Dec 16, 2009 12:44 am Post subject: |
| dturco wrote: | | Nashou66 wrote: | ok sounds like the HVPS main lead might be it or the HVPS itslef, just to make sure, when all HV lead were not connected you had the H yokes all connected. right?
Athanasios |
Yes |
So back to where we were. Yes.
| Posted: Wed Dec 16, 2009 1:07 am Post subject: |
Well looks like you need to swap in someone else's HVPS. If the same problems still happen it could be the yokes or worse, possibly the HVPS connector on the backplane. Maybe you can look at it from the front with the HVPS pulled. You might not be able to see it well from that distance. No HV goes through it but the G2's and the power from the LVPS 390VDC does. Th G2's can get higher than 600VDC , i am not sure if that would cause any interference for the cell, but it would do things to the video. However I never heard of the connector the HVPS get messed up unless the HVPS didn't fir and someone forced it hard. I while back someone with a LVPS connecter that snapped had start up problems.
So try another Supply and then go from there.
| Posted: Wed Dec 16, 2009 1:21 am Post subject: |
| dturco wrote: | | Edit: GOZER was powered off each time between wire pulling and lead pulling, just in case anyone was wondering. | actually no we weren't wondering since your obviosuly still alive
