1208s TDA2030 went poof. :(
JBoom
Posted: Sun Dec 06, 2009 6:19 pm    Post subject:
I thought you might like to see the 1208s destruction.
Posted: Sun Dec 06, 2009 6:30 pm    Post subject:
That looks like a set with MEC tubes in it.
JBoom
Posted: Sun Dec 06, 2009 6:33 pm    Post subject:
Does that mean replacement may be an option?
Posted: Sun Dec 06, 2009 6:34 pm    Post subject:
Yes, MEC tubes are easier to come by. It was the green you needed?
Is there a red fairly thick wire that runs from each CRT socket to the G2/focus block? If not, you have MEC tubes and I'd repair it.
bbfarmht
Posted: Sun Dec 06, 2009 6:40 pm    Post subject:
JBoom wrote:
Just out of curosity, is this issue with putting different style tubes in the 1208s mostly mechanical? I ask this because I have access to a machine shop, and can probably make any sort of adapter to make a differect tube fit mechanically.
No mechanically the tubes will fit. Its the orientation of the pins in the end of the neck that make the difference.
Adam
Benjamin Franklin
JBoom
Posted: Sun Dec 06, 2009 6:41 pm    Post subject:
Yes indeed it was the green that shattered.
Does this pic help?
bbfarmht
Posted: Sun Dec 06, 2009 6:44 pm    Post subject:
No, look at the neckboard. Does it have a red wire coming out of the crt socket.
Adam
Benjamin Franklin
JBoom
Posted: Sun Dec 06, 2009 6:55 pm    Post subject:
I don't see any red wire on the board(s) on the tube's neck. But here's a pic incase you see something different. BTW, it looks like the model Number on the tube is PT18-205(G).
Posted: Sun Dec 06, 2009 6:59 pm    Post subject:
Looks like A P18 tube, not sure what type P18 but those are what are in my marquee 8 inch LC housings.
Looks like your in Luck with a slight neck mod even marquee tubes can be used.
http://archive2.avsforum.com/avs-vb/showthread.php?t=458252
JBoom
Posted: Sun Dec 06, 2009 7:40 pm    Post subject:
I took the remainder of the green tube out. Here's a pic of the Model tag:
bbfarmht
Posted: Sun Dec 06, 2009 8:00 pm    Post subject:
lets see a picture of the whole tube and mounting assy.
Adam
Benjamin Franklin
JBoom
Posted: Sun Dec 06, 2009 8:24 pm    Post subject:
The whole mounting assy. Here goes.
bbfarmht
Posted: Sun Dec 06, 2009 8:59 pm    Post subject:
From that burn I'd say the tube committed suicide. It was doing you a favor.
"Please change me I'm dying"
Adam
Benjamin Franklin
JBoom
Posted: Sun Dec 06, 2009 9:04 pm    Post subject:
HAHA. Yea..I already knew it was nice and burned in, but suprisingly it didn't look TOO terrible on the screen when projected. In it's previous life, it was a conference room projector that was used quite heavily.
Any how, I'm still unclear as to whether this is a replaceable item. I mean, is this NOT the tube that is extremely difficult to find a replacement for?
Posted: Sun Dec 06, 2009 9:05 pm    Post subject:
THat is indeed a Panasonic (MEC) tube. If the set worked otherwise, I'd change the green tube and put the set back in service.
BB is right, the green tube needed changing anyways.
Someone got something better than a 6 tube to get to JBoom?
Posted: Sun Dec 06, 2009 9:42 pm    Post subject:
Curt do you have the pinout chart for the p18's ? are they similar to the 9 inch tube chart that is floating around?
Posted: Sun Dec 06, 2009 9:47 pm    Post subject:
THese tubes are identical to the 180DVBs that BArco used in earlier models. A 180DVB drops in without mods.
bbfarmht
Posted: Sun Dec 06, 2009 9:48 pm    Post subject:
And the P-16's as well right?
Adam
Benjamin Franklin
Posted: Sun Dec 06, 2009 10:04 pm    Post subject:
Ok my 8 inch marquee tubes are p18-136's. I think the G2 pin on the P18-205's are at 6 not 2 like the P18-136's.
JBoom
Posted: Tue Dec 08, 2009 7:46 am    Post subject:
When you said "P18-205's" did you mean PT18-205?
On the AVS forums there is a list someone compiled of compatible CRTs:
180DVB
180DMB
P16LCP
P16LNN
P16LNQ
P16LNP
PT18-205
Not entirely sure these are correct as there seemed to be some confusion in the original post.
http://www.avsforum.com/avs-vb/showthread.php?t=1143347
Page 2 of 3
