Marquee mods RANKING - Have your say!
Posted: Tue Dec 01, 2009 7:27 pm    Post subject:
macgyver655 wrote:
Ok, question to Mike. Do your dots currently bloom at high contrast? I know your grid looks fine.
Somewhat. But nothing like what happens on a stock CRT projectors. I'll look at the dots later when the room darkens and post a picture showing them at 1080P.
Craig and I looked at this closely when he was here. He's on his way back home and he said he'll post on this when he gets back, but in the mean time, I'll take few shots later.
Posted: Tue Dec 01, 2009 7:48 pm    Post subject:
I'm in agreement with you here. I'm just trying to explain this so other understand it.
Everyone has to understand that when you increase beam current your increasing the number and speed of the electrons being emitted. This is what causes the phosper to glow stronger (contrast). This process also needs to be stable and no amount of focus control will resolve it. This also falls under bandwidth like you mention, which both pertain specifically to volume of something.
Posted: Tue Dec 01, 2009 8:09 pm    Post subject:
I understand what your both saying but I have scoped the video signals at the neck cards running 1080p72 greyscale pattern , yes the trace not perfectly smooth and had noise on it, but it did not look like that much where even after possibly cleaning it all up so it was pure signal is enough to cause the contrast to be raised with no or very little blooming, it's an inherent characteristic of CRT and phosphor . As phosphor is excited some energy will have to spread to nearby phosphor particles, they are not enclosed in self contained areas, like a pixel for example, you'd have to shrink the electron gun apertures to get the area excited smaller.
And even if the signal was not wibbly the surrounding phosphor of the area that is suppose to hit will also get some residual energy since they touch. and giving it greater speed and power by turning up contrast there would be more surrounding area excited . Even with super focus control it happen. tis just how Phosphor behaves.
Send me a Vim to test, you said you were going to anyhow and are looking for two more testers and i have two identical marquee's. They say seeing is believing. Wink
antorsae
Posted: Tue Dec 01, 2009 8:30 pm    Post subject:
Hey! I'm a voluteer too Wink
Posted: Tue Dec 01, 2009 8:32 pm    Post subject:
you already have his mods, i never seen them except for a very very early VNB.
Posted: Tue Dec 01, 2009 8:41 pm    Post subject:
As they say, A picture is worth a thousand words..... Smile
Posted: Tue Dec 01, 2009 9:35 pm    Post subject:
Dude, if you're ever in this area let me know, or anywhere near this area.
Posted: Tue Dec 01, 2009 10:07 pm    Post subject:
Yes I did. I'll have to get one together first to send you. I have two aready to go out, with one going to California and the other to Wisconsin. The people they are going to, only one knows he's going to be a tester.
There's a different type of noise I've been talking about. It's not really measurable or very hard to measure.
I've been tracking down three types of noise over the years:
1, common noise from the LVPS that's mostly generated from the switching circuits.
2, Sweep circuit noise that gets on the rails or is radiated to the video circuits from a design that did not consider the noise being a problem.
3, controller board or computer processing noise that is common wherever there's a clock frequency or digital high frequency digital processing going on.
Most concentrate on the noise coming from the LVPS, mainly because it is the easiest to go after. It's a noise that can cause a problem in the image, and when it does it's also easy to see in the image. It's the easy noise to track down.
The other form of noise (sweep pulse) will usually show itself using the the raster as a scope that shows it. it too is an easy noise to go after.
The last of the three (digital crap) is the most difficult to track down. That's because it does not show itself easily in the image, nor would there be lines or any other common noise term that one could use to put a handle on it. It's better known as HASH NOISE. Meaning it's equally in the image everywhere. And for the most part, it's been a silent enemy of achieving the best image quality. The reason why it's so stealth and hard to isolate is because unlike the noises from the LVPS and sweep cicuits, that are in the KHz range. The noise from digital crap is usually in the MHz range, making it so fine that it's not going to show up too often in lines or other easily seen distortions. It in turn put a mask or cloud over the image. And when it does that, the image fails to have clarity and solidity from foreground to background. And that means you loose depth and that life likeness that is what make FILM so special.
That noise (digital crap) when properly isolated or decoupled from the video chain, the video chain is several steps up in performance, with improved low end (black) performance that was not so easily seen because it was under a brighter cloud of hash noise.
The task of decoupling and isolating that noise requires a bit of work and time to select for each rail or data line the right filtering (decoupling) to isolate that particular problem frequency that's feed directly into the video chain, to either control a switch or provide a needed sync or timing pulse for the proper operation of the video chain.
When cleaned up properly to include doing a reasonably good job with the other two, CRT moves from being something on it's way out, to setting even more goals for digital technology to achieve..Mr. Green
Posted: Tue Dec 01, 2009 10:12 pm    Post subject:
Ok Mike, you have my e-mail address, if you saved the one with my address just send one out when you have a chance. Now will we need different VNB's or will the VIM comparison be fairly evident with 100%stock vnb?
Posted: Tue Dec 01, 2009 10:29 pm    Post subject:
The VIM I'll be sending you should be used with 100% stock neck boards.
The Mikron mods from here on will not require that the neck boards be modified. However, the neck boards should be confirmed to be working to it's maximum performance level.
Posted: Tue Dec 01, 2009 11:20 pm    Post subject:
Under 300 hours on these VNB's Very Happy
Sparky015
Posted: Wed Dec 02, 2009 12:48 am    Post subject:
Nash, when you get it, I may take a road trip up your way and check out your picture versus mine. I'm sure yours will blow mine away, but curious to see it nonetheless. I should have my pj mounted and go through a tedious setup by then, so I should have something to compare.
Paul
~Paul
Posted: Wed Dec 02, 2009 1:21 am    Post subject:
Paul
No problem If he can send it to me by the 12th of December it be great if you too come as Beenaroo and cliff are coming.
Ben is bringing an Ampro 3600 for me to mess with Very Happy and cliff just wants to hang. Were also going to work on the blend and fix some issues I have. Maybe do a complete set up from scratch.
The Tv-one units have some issues and I am finding more, the more time i spend with it. I think they can fix it but not sure how committed they are right now. Bob Stephan and I and Andy in England are trying to put pressure on them.
I am going to work on the astig tomorrow as the move to the ceiling altered the dots. I had then perfect and no movement when ramping focus but now both flare to one side. Earths magnetics change just form a 5 foot move in height ;( I hate doing astig while the PJ's are on the ceiling but in some locations it has to be done, others nothing changes.
dturco
Posted: Wed Dec 02, 2009 1:30 am    Post subject:
Paul
Can I come Too Smile
http://www.hulu.com/firefly
Posted: Wed Dec 02, 2009 2:03 am    Post subject:
mp20748 wrote:
I'd hate to go digital, I've yet to see one that looks natural. They also seem to bother me somehow. I think I'm allergic to digitals..Mr. Green
You too huh? Mr. Green Thumbs Up
Posted: Wed Dec 02, 2009 2:05 am    Post subject:
dturco wrote:
Paul
Hey a projector meet a stones throw from spicy chicken meet. Hmmm........
Posted: Wed Dec 02, 2009 3:14 am    Post subject:
Not really a "Theater meet" since the Blend is not up to par yet. This is turning into more like a Crt owner meet ! I work on weekends since I am the Owner and Main cook, so I wont be around in the AM from 7 till 3-4 pm on Saturday and Sunday. But i'll be there in the Evening. Ben was going to drive down to drop off the Ampro and Cliff has been wanting to visit and see if the Thomas Tubes will work with a G90 mod tot he neck board, so I invited him and I think Arli might be tagging along.
I have been telling Ben about the blending Issues and he's going to help Calibrate the twins since I think my i1 Pro is off from sitting in the damp basement Sad
But the Issues with the Tv-one unit are still there and I am relentlessly trying to get them to be a bit more serious about it. There is a flaw that needs addressing.
But thats a long story that Bob Stephan (Boilermaker) and Andy Haliday( MadMrH) have been trying to work out with Tv-One.
But it be great to hang out and look at Mikes Vim and compare if he can find a spare to send.
let me think on the extra people for a bit and see what happens, It's short notice so don't expect much if we do have a small get togeth.
dturco
Posted: Wed Dec 02, 2009 3:23 am    Post subject:
I'll bring Guinness, Jeremy will bring rum, and then all we need is spicy buffalo chicken, slim jims, and potato chips. It'll be a manly
gathering. Men, men, men, men,men, men....... a ship all filled with men. Very Happy
Posted: Wed Dec 02, 2009 3:39 am    Post subject:
Monty Python: "Bet you're gay!" Laughing
antorsae
Posted: Wed Dec 02, 2009 10:56 am    Post subject:
Nash - I'd very interested in your findings. I am curious as to the PERCEIVED benefits of changing CLC449 op amps with EL5166ISZ ones. I understand you did this to VNBs and VIMs, right?
Page 4 of 6
