Bad Contrast Modulation Board (Marquee) - Help!
HK-Steve
Posted: Tue Nov 24, 2009 12:33 pm    Post subject:
Athanasios said all that I have to say Thumbs Up
Cheers
Steve
Posted: Tue Nov 24, 2009 1:26 pm    Post subject:
I just wish they still made the OPA chip in a DIP package for the quad version. Sad
Sparky015
Posted: Tue Nov 24, 2009 2:02 pm    Post subject:
For what it's worth, I pulled the board and saw no change to my picture, so I'm in agreement with Mike that for a single display, it's not needed.
Paul
~Paul
antorsae
Posted: Tue Nov 24, 2009 4:15 pm    Post subject:
Athanasios: Is the TLE2074 a replacement for both (older) chips?
Posted: Tue Nov 24, 2009 4:38 pm    Post subject:
Paul
really? Were you even using the boards adjustments beofre pulling it? If you go into RGB temps, choose "zones", and bump up the 4 corners by 10% and maybe dial down the upper/lower area's by 5 to 10% you will have (more) uniform screen brightness. Typically a CRT is brighter in the center and dimmer towards the edges.
Sparky015
Posted: Tue Nov 24, 2009 4:53 pm    Post subject:
Thanks Dragon, I will try that. You are correct, I never messed with zone contrast. Probably why I didn't see a difference after pulling it! Razz
Posted: Tue Nov 24, 2009 8:01 pm    Post subject:
you might want to change those cheesy little caps first Wink
Posted: Tue Nov 24, 2009 8:15 pm    Post subject:
Yep, its a much lower noise Chip.
