HK-Steve
| Posted: Tue Nov 24, 2009 12:33 pm Post subject: |
Athanasios said all that I have to say
Cheers
Steve
Sparky015
| Posted: Tue Nov 24, 2009 2:02 pm Post subject: |
For what it's worth, I pulled the board and saw no change to my picture, so I'm in agreement with Mike that for a single display, it's not needed.
Paul
_________________ ~Paul
antorsae
| Posted: Tue Nov 24, 2009 4:15 pm Post subject: |
Athanasios: Is the TLE2074 a replacement for both (older) chips?
| Posted: Tue Nov 24, 2009 4:38 pm Post subject: |
| Sparky015 wrote: | For what it's worth, I pulled the board and saw no change to my picture, so I'm in agreement with Mike that for a single display, it's not needed.
Paul | really? Were you even using the boards adjustments beofre pulling it? If you go into RGB temps, choose "zones", and bump up the 4 corners by 10% and maybe dial down the upper/lower area's by 5 to 10% you will have (more) uniform screen brightness. Typically a CRT is brighter in the center and dimmer towards the edges.
Sparky015
| Posted: Tue Nov 24, 2009 4:53 pm Post subject: |
Thanks Dragon, I will try that. You are correct, I never messed with zone contrast. Probably why I didn't see a difference after pulling it!
| Posted: Tue Nov 24, 2009 8:01 pm Post subject: |
| Sparky015 wrote: | Thanks Dragon, I will try that. You are correct, I never messed with zone contrast. Probably why I didn't see a difference after pulling it!  | you might want to change those cheesy little caps first
