sony 1272Q
chrissky
Posted: Mon Nov 23, 2009 5:32 am    Post subject: sony 1272Q
my crt sony 1272Q have blue ghost image, it was on/off a few time this week, but now is permanent anyone, try doing the B and R adjustment but did not help, as it is too far right side, can it be the blue bulb is out of position? can someone help, thanks
Posted: Mon Nov 23, 2009 4:39 pm    Post subject:
If the problem was intermittent, then finally permanent, that's electronic. If I understand the problem, the blue is shifted off to the right, and can't be adjusted. That sounds like convergence. I'm going to guess it's the CPU board. I'd pull the CPU board, make sure any socketed ICs are seated, then re-seat the board. I'd bet that will fix the problem.
http://www.curtpalme.com/Sony125x_Layout8.shtm
It's no small project getting to it, so wait for Curt to chime in what he thinks.
Posted: Mon Nov 23, 2009 4:44 pm    Post subject:
Can you post a picture of it? I read the post as the blue image has ghosting, which is probably a cable or source issue.
chrissky
Posted: Mon Nov 23, 2009 5:10 pm    Post subject:
thanks for reply, i try this morning and gave a couple bang on the right side of the casing and the blue image goes back to normal, will open to check the CPU, and component cable checked good, last calibration was done like 12years ago, and i was telling myself start saving for a sony VW85, do you sell them?
i still running at 480i with new sony blu ray BDP-S760
i think i have about less than 5000hrs, try to get the hours but unable i press page but can't get to page 5,
how much can i get this projector for ?
Posted: Mon Nov 23, 2009 5:38 pm    Post subject:
What!?!?? Seriously? You're watching Blu-ray at 480i? That's a CRIME!!! You know that old 1272 is capable of a great 1080i HD picture, don't you? It wouldn't take that much time or money to get it working, either.
You have to be in service mode to see the hour count page. Hold the test key key down (better to do it on the built-in control panel) until it asks if you want "service man" mode. Press the up key. Then, you'll be able to access page 5.
Oh, and quit whacking the side of the machine - that'll make it worse. Wink
What part of the world do hail from?
chrissky
Posted: Mon Nov 23, 2009 5:46 pm    Post subject:
thanks a lot, i know the only way is to buy the new sony IFB-HD card which is USD410 right, but because my projector is so old and i thought i should up grade , i will stop whacking, thanks again, i have the sony IFB card for component can i change setting to get above 480i?
Chris
Ben851
Posted: Mon Nov 23, 2009 6:03 pm    Post subject:
You can pick up an HD-Fury that will convert HDMI to RGB for less than $100 - it'll be the best $100 you'll ever spend in upgrades...
Ben
Posted: Mon Nov 23, 2009 6:38 pm    Post subject:
Yeah, no need to go to a Moome card.
Like Ben said, the older HD Fury is the best way to go (and there should be more used HD Fury 2's on the market soon with the new 3 coming out) for around $100, or a transcoder to transcode component would work, too. I sold my Kimcoder for something like $50.
I would say, even if you're planning to switch within the next year, the upgrade will still be WELL worth it.
chrissky
Posted: Mon Nov 23, 2009 8:01 pm    Post subject:
thanks everyone, my pj is working OK now, i think is the PCU cables, i remove and insert back all cables in the PCU on the left side , my PJ is ceiling mount, and no more blue ghost image, i am not sure it will come back again, hope not.
so for $100 is well spend to get to 1080i, can it go to 1080p?
i bought it used in 1997 when it has 900hr, now just checked it have 4600hrs.
thanks again.
Chris
Ben851
Posted: Mon Nov 23, 2009 8:05 pm    Post subject:
You can do 1080p on a 1272 but the picture would most likely be unwatchable - 1080i or 720p would be much better... To do 1080p properly you need a 9" set. It's overrated anyway - 1080i and 720p are both HUGE steps up from what you're currently watching. The jump from 1080i to 1080p is much less noticeable.
Ben
chrissky
Posted: Mon Nov 23, 2009 8:06 pm    Post subject:
thanks,
Chris
Posted: Mon Nov 23, 2009 8:17 pm    Post subject:
I had a 1271 before I went to my G70. There is no need to go 1080p - 1080i is beautiful. I'm not kidding when I say the picture will blow your mind compared to what you're watching now. The difference is night/day. Will it totally eliminate your desire to go to a new digital projector? Maybe not, but for well under $100, why not give it a whirl? If you stick with the 1272 for another year or two, digital projectors will be that much better/cheaper when you do switch.
Here's a few screenshots from my old projector that might give you an idea how much better 1080i could look:
http://ecrabb.com/crtforum/ecrabb_ht/0108/
Oh, and you didn't say where you are, but a good-condition 1271 may be worth around $100-300, depending where you live, what the market is like, and how many potential buyers you have around you. Since it isn't worth much to sell, you might as well use it up some more!!!
Posted: Mon Nov 23, 2009 8:31 pm    Post subject:
Oh, and here's a comparison I did for a friend who didn't think is worth upgrading to an HD source for his 12xx...
http://ecrabb.com/garen/sd_hd
The images use Javascript rollovers and I didn't preload them, so you might have to wait/fart around to make the images load.
chrissky
Posted: Mon Nov 23, 2009 8:40 pm    Post subject:
right now have sony ifb- card so do i have to remove and get a fury card?
Posted: Mon Nov 23, 2009 10:23 pm    Post subject:
No, it's not a card. It's an outboard device that plugs into the RGBHV input on one of your IFB cards.
http://www.curtpalme.com/HDFury.shtm
Bucketfoot
Posted: Mon Nov 23, 2009 10:56 pm    Post subject:
Definitely get a fury or something else that will let you run 1080i. It is well worth it and looks great on a 127x.
chrissky
Posted: Tue Nov 24, 2009 2:59 am    Post subject:
thanks again for all the help, no more blue ghost image but now after calibration i have white top broken line, normally will go away after 20 to 30 mins, this is still there, could it because i have set the vertical/horizontal max or minimum on some position on the test pattern? this calibration was my first time, picture looks OK as before, not much changes. can someone help thanks
Chris
Posted: Tue Nov 24, 2009 12:20 pm    Post subject:
thanks again.
Chris
I accidently fed a 1272 1080p once. Don't bother. It's Blurrrryyyyyy.
Set it up for 1080i and call it a day.
Get the HDFury1 with the power supply and the 'green' RGBHV cable. The get a DVI to HDMI cable and set your bluray player to 1080i. Turn off 24 frames per second in the players menu.
It's a great picture. Even at 4600 hours. My 1252 has 14 000 hours and still looks ok Laughing
Bucketfoot
Posted: Tue Nov 24, 2009 3:19 pm    Post subject:
Yep, I did the same thing when I first connected my PS3. Definitely stick with 1081i Smile
Posted: Tue Nov 24, 2009 3:29 pm    Post subject:
Chris
Setting the blanking controls properly should fix this.
