| Posted: Sat Nov 21, 2009 8:30 pm Post subject: |
| dturco wrote: |
This problem started after the last time the MODDER look at the boards.
Maybe there was more to this |
Interesting... a few upgrades to the VIm and neck boards caused the remote to flake out. And considering I have not seen the set in years, it's now all my fault..
But wait, the problem with the projector turning off the cell phone was there from day one... now we have to find a way to blame me for that.
Now you see why I only do the video chain..
Let's step back and look at this. YOU had a problem from day one with your Marquee turning off your cell phone. And the noise problem that you're having only showed up after the mod upgrade, which I told you was caused from boosting the bandwidth of the video chain.
I also offered to help to track it down, and you bought me the first round of boards which was your video chain. Now since we put your boards in my personal Marque 9500LC and then my test 8500LC while you were there, we both we not able to see the noise on either projector - is that correct?
So from my memory, we could not make that problem happen here on two Marquees. So from there I loaned you a stock (un-modified) VIM. And you called me and indicated that the noise was still there with the stock VIM, so I later loaned you a neck board, and we them determined that the noise was being caused from the neck boards. I then offered to dial them down because it's clear that there's a noise somewhere in your Marquee that's not agreeing with the neck boards 9as confirmed by my two Marquees).
But of course, you did not want then dial back down, because you were so impressed with the image you're now seeing, so you wanted to take me up on my offer to help you get to the bottom of this - is that also correct?
Now with you having a problem in your Marquee that was turning off your cell phone BEFORE any upgrades was done, there's now a problem with your remote, which in NO way could have anything to do with the VIM and neck board problem you're now claiming, but has also said in this same thread:
| dturco wrote: |
C'mon Mike I am not saying you haven't been helpful. But Free is relative, I did pay for the last round of upgrades. They may have uncovered another underlying problem. I don't know.
This thread was going fine up to you brought in a history lesson of dubious importance.
Lets just stop this and get back to the issue of the herringbone. |
Look, you purchased a projector that I have not seen in 4 or 5 years prior to me upgrading your video chain, which I've done a number of times. And have mentioned so many times about the problem I've had with the mods NOT working in some chassis, and explained what I've found to be the cause of the noise problems. And that's why I asked you to bring specific boards - which you did, but that was not the cause of the noise.
Again, the offer is still open to dial those neck boards down for you. And I'm sure you have to agree, that if the problem does not show up on either of my machines. there has to be something wrong with your marquee. You're a witness to this.
The similar situation happen with someone else a few years ago. They purchased a Marquee 9500LC from a guy that later disappeared from the forum. When they got the set to their house, they spent seems like months to get it working. It had a ton of problems and was poorly put together. It was a set i've never seen, but it had my mods in it, so I agreed to help out. When I say the set had problems, of the many problems it had, it was arching to tubes and had damaged the VIM. And that's when I got involved.
The damage to the VIM was extensive, and because I was really busy with a ton of other things I suggested that he send it to someone else to look at, because I was not able to fix that VIM, which I was going to do at NO charge (just like with you).
The person became very frustrated, and wanted out of the projector, but was very clear with me that it had nothing to do with my part in it, because I not only offered to fix his VIM. I felt so bad about that situation that i posted it on the forum that I would go out my way and do what i can to help him get it working. And again, I had absolutely nothing to do with that Marquee or the sale of it. It had my mods, and from there I had to take responsibility for everything.
Your situation reminds me of this one.
You purchased a marquee that you had a very difficult time with, and I somehow get the blame for a problem that you first need to be able to say was my fault.
The noise, yes. It's caused from my neck boards. But it'll only be a problem in a Marquee that already has a problem.
The remote and whatever else that's happening with your Marquee... I guess I'll also have to take the blame for that as well.
| Posted: Sat Nov 21, 2009 8:35 pm Post subject: |
| draganm wrote: | | dturco wrote: | The remote worked fine from the start and now a 2nd one doesn't relay the signal, or more likely the signal is being block by an unknown issue that was not present before Modding, HMM?
This problem started after the last time the MODDER look at the boards. | your getting a little silly here Dave, the video chain has absolutely nothing to do with the remote. The remote signals are processed by Chip U16 on the CLM and could be affected by oxidation on the chips contacts or possibly the small Tantalum buffering chip next to it. I also had a machine here that wouldn't respond correctly to the remote no matter what I did. It turned out to be a bad back-plane or motherboard as I swapped everything else over to a new chassis to fix it.
If someones helping you and loaning parts that's great, I wish you success. However only a fool would invest more money into that machine in it's current condition. It's a clunker and if you really want to hang onto it your best bet is to ship the whole thing to someone who can go through it. Someone needs to take a hard look at the MB and back-plane, on a 9500LC chances are very high for these to be poisoned by Glycol. |
Thanks D
I forgot all about some of the problems from leaky glycol. Noise is definitely one of them................
nuttall_chris
Joined: 08 Mar 2006 Posts: 832 Location: Ottawa, Ontario, Canada
| Posted: Sat Nov 21, 2009 9:56 pm Post subject: |
| mp20748 wrote: |
Your memory seems to be failing Mike, there was no arching in that set. It had a green tube with cathode contamination. And according to the seller all of the boards and power supplies had been modded by you a couple months before I bought it from him. You are correct that the projector had problems, both the LVPS and HVPS were DOA, the vertical board was not working properly (sent that to Curt and had it back in a week working perfectly) The seller paid to replace both the LVPS and HVPS. Also the "New" LUGs turned out to be NOS and the green tube had the cathode contamination (sent that to VDC to be fixed) Then when I finally get the whole projector together and try to use it the high voltage keeps shutting down. Swapping parts reveal that it's the modded VIM causing the problem so I contact Mike to see if I should send it to him or Curt to be fixed.
Mike says send it to him as it's got his mods, and also offers to warrantee the rest of the set for 1 year....
I sent the VIM to Mike (after taking very extensive and detailed pictures of the VIM)...many months later and after many emails/PM's I finally get the VIM back. According to Mike a "minor" fix was required to the protection circuit (won't tell me what he did) and I went over the board extensively after getting it back and found no evidence that anything was done to fix the problem, same failure still happening. BTW I doubt that Mike even looked at the board, he shipped it back in the same box that I had sent it in and it was still packed exactly the way I had sent it to him.....
So I contact Mike again and he says send it back.....boy am I a sucker for punishment...I sent it back and the cycle begins again......months later I am finally able to get Mike to send the board to Curt.....Curt had the board for less than a week and had it fixed and back to me. No more problems, the set now worked perfectly.
| mp20748 wrote: |
Frustrated doesn't even begin to describe how I felt with my boards being held hostage by you.
I'll reiterate what I said earlier in this thread....Want to get it fixed, send it to Curt, what to never see it again, send it to Mike.
Mike I salute you for trying to get the most out of the aging Marquee but you need to stop making commitments you can't keep and when you f*ck up you need to take resposibility for it and not pass the blame on to others.
Curt, keep up the good work.
Chris.
| Posted: Sat Nov 21, 2009 10:46 pm Post subject: |
| nuttall_chris wrote: | there was no arching in that set. It had a green tube with cathode contamination.
Chris. |
Yep, and what problems does that cause?
Actually the contamination is particles in the tubes envelope that float around in the tube, and when they get in certain areas of the tube.........
Can I repair the Marquee, absolutely. And have been doing so since 1996. But again, it's not something that I offer here.
Chris. |
Why should i take responsibility for a problem that's not really mine?
You're so right Chris, you board was not repaired by me... and since you've moved on to digital, why is this still bothering you. I know I'm shocked to read what you from time to time post about this situation at that time.
When we last spoke, you said that your wife had lost her job and you would need to sell the Marquee for the money. You also told me that you were really pissed with the person who sold you that set, which I can understand that, because you really had a ton of problems with it. And you were also clear with me that you were not blaming me for the problems you were having, and you really appreciated me offering to help. You actually starting parting out that project before you got the VIM repaired.
And some short time later, you post that you went digital.
Hey Chis, I know this has been awhile ago, but can you find it in your heart to forgive and move on. I wasn't the person who sold you that projector - I only tried to help out when maybe it was not a good time for me to offer my help.
| Posted: Sun Nov 22, 2009 12:47 am Post subject: |
Guys, this thread is turning into a pissing contest, and is really not solving anything, and is getting members pissed off. Now others are getting involved, bringing other projectors into it. Please stop.
Here's my (trying to be) neutral opinion:
1) Whatever happened to a CRT projector in the past (specifically brownouts) should not (IMHO) affect anything within the projector today. A brownout would only affect the LVPS, all other components are too far removed from the AC input to be affected. The LVPS is designed to run down to 100 volts, so even continuing slight brownouts will not affect the longevity of the set.
2) dturco, I've sent you a working remote and IR sensor for the set. SHould be there within the week.
3) I don't see how Mike's mods could affect the operation of anything else in the set.
If, however, this is true ( from Mike's post above):
Then it could well be that Mike's mods uncovered a problem that has been in the set along, and the greater video bandwidth of the video amps uncovered the problem.
4) This particular problem as described to be my dturco on the phone is completely baffling. I've never seen a MArquee be affected by cellphone and vice versa, and my cell sits on my bench and rings quite often, very close to the proximity of many projectors. Nothing has ever gone wrong.
5) My theory is that either the remote or the IR pickup is picking up crap from things like cellphones. Not sure about the herringbone issue, that could be any number of things, including Mike's mods, but it's UNLIKELY. It could also be a bad ground somewhere, a burnt ground connection within the chassis, so that one of the boards is picking up noise, which is then shown in the image.
I had a Barco 909 on the bench last week, and the herringbone pattern that I saw in the image was caused by the CLM (controller board) that put some hash into the convergence lines, which affected the image.
6) What I would do at this point as a non techy end user is to part the set out, and take a financial hit... or get the set out of the installation, and to another CRTers house where it can be tested within another system. That would at least eliminate the location as being a part of the issue.
As a techy, I'm curious as hell what is going on with this set, so the LAST thing I personally would do is part the set out or give up on it, but a round trip with the set to me would run $400 in shipping and customs alone.
There's no question that some Marquees are getting older at this point, but I can't say that I've seen an increase in Marquee repairs due to age. In fact, in 2009 I've seen less Marquee repairs than say NEC XGs. Last year (2008) I sold buckets of Marquee HVPS, I sold none this year. This year I've repaired piles of NEC XG boards. But I digress.
Now that these sets are older, they also usually have a few more owners than 10 years ago, so the condition of what any surplus projector was run at for the last 10-15 years is usually unknown. I've sold more than one set over the years that ran fine here, and ended up being a lemon at the final destination. sh*t happens, as they say. I still consider ANY problem in a CRT projector solvable, but in a case like this, it's going to be difficult.
I've been asked to nuke this thread, but I won't. Let's just try and assist, keep old business out of the thread, and let's see if we can't resolve the problem. I for one am curious what the problem is.
<Edit> I've edited this a couple of times since re-reading it and posts above it. Here's what I'd do:
1) Put the stock video chain back into the set. See if that stops the herringbone and the cell phone stuff.
2) Disconnect the convergence ribbon cable and pull out the focus board. See if disconnecting either the focus or convergence gets rid of the intereference.
That would at least narrow down the issues to some parts of the set.[/i]
Mr. Green
| Posted: Sun Nov 22, 2009 1:08 am Post subject: |
Hey Dave (Dturco),
Sorry to hear you are having issue with Gozer man. That blows.
The fact that you've already invested so much time and effort into it, you are definitely for this hobby. I've owned CRT for about a year and a half longer than you (we got the 9500's at about the same time), but my old 9pg+ had loads of small issues, mainly my inexperience. Now I wish I had that level of control on the marquee, but I digress. That frustrating pg+ got me hooked on this hobby and I have no intention of giving up on it any time soon. I'm also not doing anywhere near as much as you. I own the red C, Nash's bellows and now the vidikron case. All I need is a new green and blue tube and I'll put it all together. I'm so happy with my original fury and box 1040 I doubt I'll even opt for an input card for it, but that will be decided later. I'd love to have someone professionally calibrate it for me, but I doubt there's anyone around Calgary that can do it anymore. Again, I wouldn't bother until I've got everything installed. I would suggest the same to you. Get Gozer up and running then get it professionally calibrated and finally watch some movies!!!
I'm a little shocked at how often people tell us nubes to just "go digital" as opposed to realizing we are just frustrated and need help. Sure I just spent $3k and will just start new.. NOT. Sure there's probably a random thread somewhere that has all the info we need, but it's really hard to wade through thousands of posts, so easier to just ask. Besides, I'd rather have a new thread an get some camaraderie versus finding an ancient thread and never speak to anyone. Half the fun of this hobby/forum is the great people on it. RA RA curtpalme.com!!!
There's a lot of random stuff in this thread so I personally vote you start a thread "Herringbone issue on Marquee" with a quick run down of the problem and suggested steps and stick to repairing the issue.
It was a major pain in the a$$ to read all this smack, just to finally get to the issue at hand. Please start fresh and allow the personal relations work them selves out here. Don't get me wrong, I'm really sorry that Chris N. and people like Dave (Person99) have moved on to digitals, but glad they still come around every now and then.
Now my turn for 2 cents of advice (1.8 cents after conversion)
1: Like Nash suggested, locate that chip and clean the contacts that would be the simplest place to start.
2: look for any glycol spills as discussed as it might be causing an issue and might be an indication of future problems. Again relatively small fix.
3: See if you can source a good chassis for it with bad tubes, so you can swap and get one nice projector. Based on what I've read, it seems likely moving everything over to a new chassis might be the solution.
4: Next time buy from Curt. Mine is also having some issues and Curt has once again, been AMAZING! Hopefully mine will be all sorted out soon so I can worry about watching movies again.
5: Turn your f**king cell phone off in the theatre!!! What's wrong with you!!!?
Mr. Green
| Posted: Sun Nov 22, 2009 1:15 am Post subject: |
Oh, there you go. ditto to Curt's post.
dturco
| Posted: Sun Nov 22, 2009 2:53 pm Post subject: |
I agree it has become unintentionally volatile.
Also the Cell phone part is a big issue because I don't use a land line anymore, and when trying to diagnose over the phone I have to go downstairs to hear what the instructions are then go back upstairs to do it come back downstairs to report, but I digress.
Mike and I have done this before I'm sure we'll get over it and back on track.
New thread will be started to unclutter the issue.
And my apologies to Curt for jamming up his forum.
Mike you have a P/M that has been sitting for a while Please check it.
http://www.hulu.com/firefly
