Lumagen HDP and Mux HD
Posted: Mon Nov 16, 2009 3:35 am    Post subject: Lumagen HDP and Mux HD
Will this work
BD Player HDMI to Mux HD then DVI Output from Mux HD to Lumagen HDP via DVI input and then HDP DVI output from lumagen using DVI to VGA adaptor then to Projector. If this does work are there any restrictions in what can be transfered this way.
I want to get HDMI from the BD player to my Projector without a Moome box or Fury.
Posted: Mon Nov 16, 2009 10:57 am    Post subject:
I should add would the above accept 1080p from the BD player which I may want to scale down to 1080i or leave at 1080p and if this does work with the Lumagen HDP will 1080p via DVI work with the HDP Pro. The specs from Lumagen seem to suggest that the HDP accepts 1080p input via DVI but the Pro does not which seems a little strange.
Posted: Mon Nov 16, 2009 2:47 pm    Post subject:
I would use this for your set up. BD player to Lumagen , set lumagen to accept only 1080p@24 so it forces the BD player to only that res, sometimes a bonus is it will allow the BD player to output 480i for SD dvd's. Ok so then set the Lumagen to output 800p@72 for 2.40 aspect ratio movies, and 1080p@60 or 48hz for 1.78 aspect movies. each output and input can have 4 separate settings Exm, imput 1A= 1080p@24 >outputting 800p@72hz, input 1B=1080p@24>outputting 1080p@48hz. its a great unit, very flexible.
Posted: Mon Nov 16, 2009 3:09 pm    Post subject: Re: Lumagen HDP and Mux HD
km987654 wrote:
Will this work
That should work fine in theory and it seems like the best solution to me.
Do you also want to run 1080p at 72Hz? The RGBHV outputs on the Vision series are among the best in the industry and can support 1080p 72 with almost zero attenuation.
Posted: Mon Nov 16, 2009 8:23 pm    Post subject: Re: Lumagen HDP and Mux HD
CIR Engineering wrote:
km987654 wrote:
Will this work
Great input from both of you. That makes it very clear to me.
I would like to have as many possibilities as I can. I am not sure which of the two processors I should buy, that is either the HDP or the HDP Pro. The specs on the Lumagen site indicate that the HDP will accept 1080p/24 via DVI input but the HDP PRO does not (perhaps this has been addressed in later firmware). This seemed a little strange as I thought that the PRO was a superior device.
Posted: Mon Nov 16, 2009 9:48 pm    Post subject:
I think they both accept them, you might be talking about the Vision Pro(older pre HDP series). Id get the least expensive one since you could basically use the MUX for up to 4 inputs and the Lumagen can have 4 memories on one input, so you get a nice advantage there. and gain more inputs on the lumagen for non HDCP devises .
Posted: Mon Nov 16, 2009 10:11 pm    Post subject:
The PRO I am talking about has all BNC connectors on the back. If there is no advantage in that system yeah I will get the least expensive one.
Posted: Mon Nov 16, 2009 10:20 pm    Post subject:
yeah that one does not accept 1080p@24, the one for sale hear is the better of the two(MrHiEnd)
nashou
Posted: Mon Nov 16, 2009 10:36 pm    Post subject:
nashou
Thats the all BNC one I was reffering to. So this one does not accept 1080p via DVI.
The other HDP is also for sale on this forum and it appears to accept 1080p via DVI.
Is this correct??
Posted: Mon Nov 16, 2009 10:42 pm    Post subject:
nashou
Is this correct??
look again it has 2 DVI inputs in the pics, that has RGBHV out and DVI outs .
http://www.curtpalme.com/forum/viewtopic.php?p=218869#218869
Posted: Mon Nov 16, 2009 10:47 pm    Post subject:
Yes it has DVI input but and this is where I could be wrong Lumagen site shows the specs for this as accepting a maximum input of 720p over DVI. Therefore not able to accept 1080p/24.
Posted: Mon Nov 16, 2009 10:51 pm    Post subject:
Always look at the software updates pages on these sites, they never update the spec pages:
here is the 1080p@24 fix firmware release description:
Production Release 022007- Adds 1080-24p output for HDP, HDQ, ProHDP. To select it use the VRES command in the menu. When you set the VRES to 1080 it will ask you whether you want interlaced, progressive (which uses the currently set vertical rate), 24 SF, or 24 P. This is the only method allowed for setting the vertical rate to 24Hz.
Posted: Mon Nov 16, 2009 11:10 pm    Post subject:
Thanks Again for help and the tip about the updates I certainly did not look there.
It looks like this is the one to buy to solve the issue and get 1080p from BD to projector without Fury or Moome devices.
Posted: Mon Nov 16, 2009 11:13 pm    Post subject:
You'll still need the Moome MUX for HDCP unless you have a Moome internal card in the PJ. otherwise you wont be able to output 1080p form your player, it will shut it off. but you can then go 1080i out and upscale via the lumagen to 1080p. i had it that way for a few months before i got a moome internal card, the lumagen did a nice job upscaling from 1080i to 1080p.
Posted: Mon Nov 16, 2009 11:28 pm    Post subject:
As mentioned first up I need a Mux HD. It seems to me that this is the cleanest sollution. I currently have a Lumagen Vision, the most basic model no DVI inputs so i have been using the component inputs and scaling this to 1080i the Lumagen Vision will not accept 1080i input over component and I have no way of converting component or HDMI to RGBVH to use the passthrough on the Lumagen.
I suppose I could just get a Mux HD and connect a DVI to VGA adaptor to the DVI out of the MUx HD and run this to the Pass through of the Lumagen Vision??
Posted: Tue Nov 17, 2009 4:37 am    Post subject:
Too bad it wasnt a DVI Vision, you can fool it to accept 1080p@24: read here
http://www.curtpalme.com/forum/viewtopic.php?p=116684#116684
Posted: Tue Nov 17, 2009 3:24 pm    Post subject:
The VisionHDP, VisionHDP, and VisionProHDP all have exactly the same firmware, image quality, and function. All three support 1080p 60Hz output on DVI, and up to 1080p 72Hz through RGBHV analog. All three accept 1080i, 720p, and 1080p 24Hz on their DVI/HDMI inputs. None of the three accept 1080p 60Hz on their DVI/HDMI inputs.
Theoretically, if you are using RGBHV you should prefer the HDQ or PRO because the analog output sections on these processors is slightly better than the HDP.
Also, when using a VP, you should always maintain a digital feed throughout the signal chain and only have one DA conversion at the end. Don't create a system that has multiple DA and AD conversions as you are only causing deterioration of the signal.
Your best bet is to run through the MUXHD and then directly to the Lumagen through DVI. Output from the Lumagen with RGBHV or DVI to a DVI/HDMI > RGBHV converter or IFB.
The Vision processor can also support YCbCr 444 and 422 on their "DVI" inputs. I am not sure that the MUXHD supports YCbCr, but if it does, your very best image from a Vision processor would be to input YCbCr to the DVI and output RGBHV through analog. This way the Vision will support 10-bit color because the DA conversion is taking place inside the processor with CYbCr as the source. The Vision line does not support YCbCr on the DVI output; so if you were to use the DVI out from a Vision you are stuck with 8-bit color.
So run source > MUX > Lumagen > RGBHV
Posted: Tue Nov 17, 2009 4:04 pm    Post subject:
Mux-HD Specifications:
INPUTS: 4 HDMI inputs
VIDEO OUTPUTS: 1 HDMI and 1 DVI-D output.
HDMI 1.1/1.2, HDCP 1.0/1.1, DVI 1.0 compliant.
AUDIO OUTPUTS: 2 Toslink (fibre optic) digital sound output from the HDMI inputs. This can output compressed 7.1 channels or uncompressed 2 channel PCM. Note that the HDMI/DVI outputs do not contain embedded audio.
The HDMI and DVI outputs are functional at the same time (the MUX-HD can be used as a splitter).
Supports *any* resolution from 640x480 up to 1600x1200, including all the popular resolutions such as 720p, 1080i, 1080p, etc. (Any resolution and refresh rate up to 165Mhz pixel clock is supported).
DTV mode support (480p, 576p, 720p, 1080i, 1080p) for 50 and 60Hz
PC mod support (VGA, SVGA, XGA, SXGA, UXGA) up to 165Mhz
Supports 4:4:4 RGB / YCbCr (digital component) Input
Supports 4:2:2 YCbCr (digital component) input
Supports both 16-235 and 0-255 colour range and auto selects correct value
Able to drive cables up to 10 meters (approx 33 feet) in length
IR remote control for input selection
Manual selection of input port available too
Metal case providing a clean electrical environment for high definition content processing
Global power supply (100V-240V)
AaronB
Posted: Wed Nov 18, 2009 2:21 pm    Post subject:
km987654 wrote:
As mentioned first up I need a Mux HD. It seems to me that this is the cleanest sollution. I currently have a Lumagen Vision, the most basic model no DVI inputs ...
I think that what you are referring to as a "DVI to VGA" adapter is nothing more than a simple cable adapter, which does not convert the digital signals on a DVI to analog signals for VGA. Instead, it connects a set of analog signals on the DVI port to the appropriate signals on the VGA side. In order for this to work, the equipment with the DVI output needs to be transmitting both analog and digital signals on the DVI connector. In the case of computers, this is virtually always the case. In the case of consumer equipment, this is not likely. The MuxHD certainly does not output analog signals on its DVI port. In the case of a HDMI to DVI adapter, there are never analog signals on the DVI side. HDMI does not carry analog, only digital.
So in order to connect the Vision, you need a DVI (or HDMI) to VGA converter (not adapter), i.e. an HDFury1/2/3, or something similar. The unfortunate consequence of this is that you will have a digital to analog (D/A) conversion (HDFury), then a A/D conversion in the Vision, and another D/A conversion in the Vision output. Not great.
The other option, which is what you suggested when you started the thread, it is use a VisionHDP. This will accept the digital output of the MuxHD, keeping the signal digital until one step before the projector. You have two options for the final analog output, use the VisionHDP RGBHV output, or use its digital output along with an HDFury1/2/3/whatever. The VisionHDP output is good but not spectacular in quality (especially on non-BNC units), so you may (read: may) get better results with the external converter. But you definitely can only get HDCP compliancy with the external converter. When the VisionHDP has its analog output enabled, it becomes an non-HDCP compliant device. This is only a problem if your source requires this, but more and more, you will find that this is the case as more and more content providers choose to enforce copy protection (it is an option now for Blu-ray, dependant on the disc, and most do not require it).
Posted: Wed Nov 18, 2009 10:10 pm    Post subject:
I was of the view that the compliance problem was dealt with by the Mux HD meaning that the lumagen would have an unencoded DVI input that it would then convert to analog and output that on its BNC ports and then connect this to the projector. The idea was to avoid another box in the chain like a Fury etc.
