How is your projector mounted?
Ceiling
64%
 64%  [ 59 ]
Table
16%
 16%  [ 15 ]
Floor
10%
 10%  [ 10 ]
Other
7%
 7%  [ 7 ]
Total Votes : 91
bfeils
Posted: Thu Aug 24, 2006 2:12 am    Post subject:
bfeils wrote:
jowi wrote:
No, just straight into the concrete with a couple of heavy duty expansion bolts...
After what to that lady driving through the
"big dig" tunnel I'd be afraid to sit under that thing. Smile
Why what happened?
A few of the concrete fasteners came loose and a huge slab fell on her car and crushed her. There's a big investigation going on now.
jowi
Posted: Thu Aug 24, 2006 7:21 am    Post subject:
sh*t happens. If a plane crashes on my house i'm pretty shure the crt comes down as well. I mean, there's tons of things that can go wrong, all the time, everywhere, in all circumstances. No need to panic.
Posted: Fri Oct 20, 2006 4:34 am    Post subject:
BUMP
GREG1292
Posted: Tue Oct 24, 2006 1:03 am    Post subject:
I have an easy way to mount my Barco projectors. I just cut out a peiece of ply wood and slide it between the metal rails and with the help of a friend pick it up and slide it on to 2 wooden rails. I can slide front back left right in seconds and shim if need be. FUBAR INC. is the patent. Twisted Evil
Posted: Tue Oct 24, 2006 4:03 am    Post subject:
Post a pic of that one. Sounds...dangerous but interesting
GREG1292
Posted: Tue Oct 24, 2006 3:21 pm    Post subject:
I will try to post a pic tonight. I just want to add that I have had the following mounted this way!
Sony G70 attach bracket to plywood
Barco Graphics 1209,808
Barco Data 808s
Barco 800
I switch projector often enough that I needed an easy solution plus I had a 60 Mitsubishi Diamond that I took out and added the rails and reversed my home theater. I have a shelf built for dvds and a hushbox so it does finish off nicely. Very Happy
zaphod
Posted: Tue Oct 24, 2006 3:47 pm    Post subject:
a lot would depend on the thickness of the ply. 3/4" plywood sure. anything less and i'll be taking the seat not directly under the projector Smile
hmmm, do they sell 1" thick plywood?
GREG1292
Posted: Tue Oct 24, 2006 5:23 pm    Post subject:
I am using 1' plywood. With no bow and I set under the projector.
Person99
Posted: Tue Oct 24, 2006 6:11 pm    Post subject:
Where do you find that 1 foot thick plywood. Razz
Actually, I've heard of others doing this also with no issues.
GREG1292
Posted: Tue Oct 24, 2006 6:21 pm    Post subject:
I knew I screwed up Embarassed Embarassed I'll see you in the members area where we can take off the gloves. Very Happy
Posted: Wed Oct 25, 2006 4:45 am    Post subject:
DING DING DING throw down it's Springer time
AntC
Posted: Thu Oct 26, 2006 1:12 pm    Post subject:
Currently I'm using a table ( *sigh* ) but I'm in the process of build a stand so I can test doing a straight throw (0 degree). Hopefully it will work the way I want it to, if not the pj will end up on ceiling.
Ant
Soapsuds
Posted: Thu Oct 26, 2006 2:02 pm    Post subject:
Rear, table...... easy to work on, very little noise in the "theatre".
Soapie
zaphod
Posted: Thu Oct 26, 2006 2:08 pm    Post subject:
we'll get a tape measure and settle this once and for all.
Posted: Thu Oct 26, 2006 11:26 pm    Post subject:
Ant
That's how I have mine set up. Nice and brite and fairly stable.
mack1
Posted: Fri Oct 27, 2006 2:13 am    Post subject:
I got mine on the floor at the moment but I have the unistrut up on the ceilling.I cant lift the damn thing by myself and I want to change the green tube first.Picture looks good on a 8ft.x6ft. torus.i would post some pics but i'm not sure how to and my computer crashed 6 days ago(posting this on a borrowed laptop)Any ideas on how to post photos anyone?
Sonynut
Posted: Fri Oct 27, 2006 2:48 am    Post subject:
Too bad I can't change my "vote". Mine is finally up on the ceiling with a homemade mounting system Very Happy . I even solved the straight throw angle(nearly). My mounting system puts the center of the green lens about 14 inches down from the ceiling, with my screen right up against the ceiling. All in all, a bit brighter, more stable and a heck of a lot nicer now that it's all more like a real theater. A tip too, most of you know this, but lining the area around and above the screen with black fabric really helps the "total immersion" factor Very Happy .
Posted: Fri Oct 27, 2006 2:51 am    Post subject:
What's the estimated gain on your Tarus screen?
mack1
Posted: Sat Oct 28, 2006 12:08 am    Post subject:
I do believe that it is 3.2
mack1
Posted: Sat Oct 28, 2006 12:11 am    Post subject:
Did you get your floor welded in yet Analog? Wink
Page 3 of 4
