How is your projector mounted?
Ceiling
64%
 64%  [ 59 ]
Table
16%
 16%  [ 15 ]
Floor
10%
 10%  [ 10 ]
Other
7%
 7%  [ 7 ]
Total Votes : 91
Posted: Thu Aug 17, 2006 5:22 am    Post subject:
Tinman wrote:
Tinman wrote:
Doggy style.
Wink
You too?? Shocked
Marc
Hey Tinman
Would a T-shirt that says
"I create single mothers" be in bad taste?
Ummm doggy style...
Love your avatar
Sorry, I never come unprepared. Wink
Would be a fun T-shirt, though.
Marc
Which leads me to the next shirt:
"Baby you have to unwrap it before you use it"
hehehe
Av nutter
Posted: Thu Aug 17, 2006 2:08 pm    Post subject:
Laughing Is legal to mount your pj over there as i thinks its a criminal offence still here in UK.Mike
__________________
Always looking on the bright side of life.
Hi my name is Mike Drummond age 48 MS suffer for past 12 years if you have the time to look it will give you an insight of what i live on a daily basis
www.nmss.org -
tommo2
Posted: Fri Aug 18, 2006 2:01 am    Post subject:
Built it out of hardwood skids.
Our motto:
"Built by the Approximate Construction Company. We take pride in just comming close"
Literaly.
I heard they put the C*NT into C*NTSTRUCTION, HA!
And the thick into lunatic, and the ass into geniass
You get the idea
Laughing
pull up the handbrake and walk away
Barco Data 701s
iScan HD scaler with sdi mod
Oppo 981HD with sdi mod
Xbox 360
Playstation 2
Denon AVR 1507 7.1 AV receiver
Wharfedale Diamond 9.4 floorstanders (front)
Wharfedale EVO2 (center)
Pioneer 100W (sides)
Wharfedale Diamond 9.1 (rear)
Wharfedale SW150 active subwoofer
Photos on the way!
Tinman
Posted: Fri Aug 18, 2006 2:44 am    Post subject:
Ahhh, how wonderful...... the thread degenerates and nobody is shutting it down, banning members, or deleting posts.
Ahhh.... it's like a breath of sta.. FRESH air. Yeah!
Marc
This space for rent.
Posted: Fri Aug 18, 2006 5:39 am    Post subject:
Only from behind
nettwerkjohn
Posted: Sat Aug 19, 2006 4:08 am    Post subject:
well, 2 becomes 1, but ceiling mounted...
mental note to self:make sure to invert image BEFORE ceiling mounting as it is a REALLY fiddly job to do upside down while balancing the projector top cover with your head...
 Filesize:  175.9 KB
 Viewed:  9523 Time(s)
Posted: Mon Aug 21, 2006 4:51 pm    Post subject:
BUMP
Posted: Wed Aug 23, 2006 6:07 am    Post subject:
Anyone have their's hanging from cables? If so does it sway at all?
nettwerkjohn
Posted: Wed Aug 23, 2006 8:21 am    Post subject:
ours doesn't move at all. its a pain to set up, as every thing you touch moves it, but once set up, baby is rock solid...
jowi
Posted: Wed Aug 23, 2006 8:28 am    Post subject:
Mine is mounted using a custom made stainless steel mount. Check the size of the beast, the little plastic thing next to it on the leftmost picture is a cd case... the mount is hollow to allow cables for the Barco. The mount alone wheigs about 18Kg... (approx. 40lbs)
zaphod
Posted: Wed Aug 23, 2006 1:50 pm    Post subject:
fan-effin'-tabulous. that is awesome. but your set up and the post-industrial look of your place has always impressed me. send over your decorater, i have a 70's orange shag rug that needs burning... Smile
Person99
Posted: Wed Aug 23, 2006 2:39 pm    Post subject:
Looks great. Question, do you run both the power and the video cables through the mount? If so, how did you shield them?
Due to the risk of interference with those in parrellel, I've only run one through the mount, then the other zip tied to the outside of the mount.
jowi
Posted: Wed Aug 23, 2006 2:49 pm    Post subject:
Yes they both run through the mount. The powercable is shielded though, but i never experienced any problems whatsoever. But since a couple of weeks i'm using a 50ft Gefen fiber-optic DVI cable, so now there should be no problem at all Smile
Posted: Wed Aug 23, 2006 3:18 pm    Post subject:
That thing is masive. Did you make it yourself?
jowi
Posted: Wed Aug 23, 2006 4:04 pm    Post subject:
Nope... i had it made by a shop specialized in stainless steel stuff. The thing looks massive, but so does the barco... in fact it even looks slim when the barco is hanging under it Wink
Posted: Wed Aug 23, 2006 8:50 pm    Post subject:
What's it bolted into in the celing? I'd hope a steel I-beam
jowi
Posted: Wed Aug 23, 2006 8:58 pm    Post subject:
No, just straight into the concrete with a couple of heavy duty expansion bolts...
bfeils
Posted: Thu Aug 24, 2006 1:41 am    Post subject:
I made a mount copying a chief design only alot heavier, the salvage yard had a big 1/4 plate of steel that was just the right size. If I ever stop fooling around with projectors I could use to lift up cars or something.
 Filesize:  147.82 KB
 Viewed:  9389 Time(s)
bfeils
Posted: Thu Aug 24, 2006 1:44 am    Post subject:
After what to that lady driving through the
"big dig" tunnel I'd be afraid to sit under that thing. Smile
Posted: Thu Aug 24, 2006 1:51 am    Post subject:
Why what happened?
Page 2 of 4
