Screen paint for CRT projector screen
Posted: Sun Oct 25, 2009 11:52 am    Post subject:
Mark_A_W wrote:
garyfritz wrote:
Damn you Mark!! I just watched Star Wars VI last night, and *especially* in the space scenes, all I could see was the bars above & below the image area!! Confused Laughing
Guess it's time to get some Wilsonart **AND** some masking fabric.......
MWHAHAHAHA!!
It's too late for Mike, and you're next Wink
Masks really are the number 1 tweak. Better than AC to LC, or 8" to 9". Hell, better than 1251 to G90.
My adjustable masks are just rolled around a 20mm dowel at the top, and hang from a string around the dowel at the bottom.
Really simple - one pull of a drawer string and they move.
Mark,
If you wish to complicate things and automate your masking, pick up two HiTec HS-785HB sail winch servos and a Pololu SSC04A serial servo controller from WWW.pololu.com
You can figure out the rest Wink
picree
Posted: Sun Oct 25, 2009 12:18 pm    Post subject:
Spanky Ham wrote:
Ummm, no his name was Ken (KBK). Yes, he was a character. I think he had someone heres 1292 for a long time with a promise to radically improve the performance. I don't think anything ever materialized.
I am curious if this was the only thread you read over there as there were a lot more than that.
I did read quite a lot at the time but that was so long ago. That's in the past now. Here is a link to the work done by algol that I referred to earlier when asked about screen paint formulas. It is in Archive 1 now. I eliminated the silver and gray components since I have a CRT. I did read about KBK but don't remember much now. Confused
EDIT: I overlooked the point about inventor of "Screen Goo". Crackpot=algol from my recollection Smile
MAIN THEATER: (JVC RS2000; Yamaha UDP-LX500; Yamaha RX-V2400; Lumagen Radiance Pro, Vertex)
SECOND WII-ATER: (BG808; WII; Oppo 971H; Moome external box; BG-DVI transcoder; tse gamma box; Extron)
Posted: Sun Oct 25, 2009 1:13 pm    Post subject:
All 1.3 gain commercial screens are not created equal. I mistakenly bought DaLite 1.3 material for my own screen and it sucks in comparison to Stewart. If I were to replace my material, it would be with Stewart. I plan to go back to a painted screen and that will be with Behr Ultra white (FLAT). This will happen when I build a new automated variable masking screen.
Posted: Sun Oct 25, 2009 3:24 pm    Post subject:
Just a leeetle bit of hyperbole there, Mark??
Posted: Sun Oct 25, 2009 11:47 pm    Post subject:
Wait till you have tried it.
I've got some pics somewhere - they aren't good. It's hard to take pics of a black felt screen border in a black room...
Posted: Sun Oct 25, 2009 11:51 pm    Post subject:
stefuel wrote:
Mark,
Thanks....but where would I stop? I already have to manually close the curtains, and shut the doors. I have to manually turn on the hushbox switch, and manually turn on 5 amplifiers. I even have to manually pull the lever on the recliner!! And the fridge door...you have to PULL IT open manually to get a beer.
In the scheme of things the pullstring on the screen is not a big deal - and by hand you can get precise control - not all movies are the same.
I really don't mind, and it works fine.
Mark
roland@b4
Posted: Mon Oct 26, 2009 9:15 am    Post subject:
I can tell what the problem is with part of the install, You are using the wrong type of Sheila
Posted: Mon Oct 26, 2009 2:09 pm    Post subject:
That's why I'd like to see your setup. I can do a simple mask but it would be a fixed-width deal. Adjustable would be nice. Can you sketch an approximation in Powerpoint or something?
jkruger
Posted: Mon Oct 26, 2009 3:01 pm    Post subject:
You guys need to keep a couple of Sheilas around so there will always be one around to fetch another beer while the other is busy giving you he... er... entertaining you.
Posted: Tue Oct 27, 2009 1:45 am    Post subject:
Hereyar
masking.zip
 Filename:  masking.zip
 Filesize:  303.22 KB
 Downloaded:  235 Time(s)
picree
Posted: Tue Oct 27, 2009 2:54 am    Post subject:
Since we have now moved on to the topic of masking, Gary-here is a link to the details of the masking system I made out of 1/8" masonite board. Look through my photo album for other pics and details for the side masks. I have masking on top/bottom and sides. It's really hard to take any photos that do it justice. I can fill in any gaps via PM if you like.
Posted: Tue Oct 27, 2009 3:21 pm    Post subject:
Thanks Mark. You're right, it's hard to see, but that helps. Nice design, picree! Unfortunately I don't think I'm going to get that fancy. Existing limitations (like the sound panels on both sides of my screen) would make it very difficult to build in any kind of pulley system like that. I think for now I'll go with a simple "dowel sewn into fabric" approach. I can flip it up and hide it behind the top of the frame, and the bottom will just hang down behind the center speaker. Should take only a few seconds to change it in & out.
VideoGrabber
Posted: Wed Oct 28, 2009 2:46 pm    Post subject:
Chip wrote:
> automate your masking, pick up two HiTec HS-785HB sail winch servos... <
When you said servos, at first I was a bit confused, since they're usually limited to a 180 or 270-deg rotational range. But I see these winch servos have been geared to run 3.5 turns. Misconception on my part, I guess. So with a 1" diameter rod, that means an 11" range for your masking (on each border). Increase the rod diameter for more masking range if needed.
- Tim
VideoGrabber
Posted: Wed Oct 28, 2009 3:00 pm    Post subject: Dark images enhanced a bit
Mark commented:
> It's hard to take pics of a black felt screen border in a black room... <
True. Thanks for sharing the pix. It does help though to toss in a bit of gamma boost, so I tweaked your images and rezipped them. It makes it a fair bit easier to see what's what.
MarkAW_masking.zip
 Filename:  MarkAW_masking.zip
 Filesize:  432.59 KB
 Downloaded:  191 Time(s)
- Tim
benareeno
Posted: Fri Nov 06, 2009 3:10 am    Post subject:
Masking is an absolute must...there is no doubt!
ALso, with respect to the screens I've had....I would say the Studiotek is the brightest, but the color is no better than the Goo screen. In some ways I think the goo was better than the Stewart.
Blackout cloth is complete crap...it's a dull and lifeless image..
UltraPureWhite is too blue biased...there are more neutral white paints out there. Perhaps a neutral white base with a GOO topcoat would be nice.
But, my favourite screen was the Dalite Cinema Vision....I just loved it. It had a strange way of showing green (if I was watching baseball for instance), but for movies, it was just excellent. You could likely buy a 4x8 piece of cinema vision for 150 or so...make your own frame and masks.
Posted: Fri Nov 06, 2009 3:25 am    Post subject:
Where did you find CV for $150 for a 4x8 piece? I'm seeing prices like $13.50/sq ft, which is about $430...
benareeno
Posted: Fri Nov 06, 2009 3:41 am    Post subject:
perhaps a few sheckles more...but likely worth it.
It's $6.77 a square here : http://www.projectorzone.com/Da-Lite-Cut-To-Size-Cinema-Vision-Material
Posted: Fri Nov 06, 2009 3:09 pm    Post subject:
Hmm, interesting. Stretching & stapling CV over my current BO frame would be a whole lot easier than buying Wilsonart, cutting it to size, gluing it to a backing, figuring out mounting, etc -- and the results would probaby be at least as good. My frame is about 52x90; add 4" on all sides to wrap & staple and I'm looking at about 41 sq ft. That's about $277 plus shipping. Still at least 2x what the Wilsonart would run me. Hmmm.
Any guesses how the CV would compare to Wilsonart?
benareeno
Posted: Fri Nov 06, 2009 4:16 pm    Post subject:
My "guess" is that it would be better....
But, as I said...green can be a tad strange if there's a lot of green on the pic. I kinda liked it...
You could also go for Draper m1300 material....might be even cheaper still!
dturco
Posted: Fri Nov 06, 2009 4:17 pm    Post subject:
1 word HURLEY.
http://www.hulu.com/firefly
Page 3 of 4
