lexx21
| Posted: Tue Sep 29, 2009 9:13 pm Post subject: painted screen for use with a CRT |
I have been looking around for info about using a painted wall as a screen but most of the discussions don't specify if they are using a digital or a crt. Has anyone here painted a screen before, and if so, what did you use? Would Behr ultra white flat work or would I want to go with a different finish?
Thanks in advance
Ben851
Joined: 13 Sep 2008 Posts: 221 Location: Ottawa, Ontario
| Posted: Tue Sep 29, 2009 9:21 pm Post subject: |
For the longest time I used a sheet of drywall and primer - not sure about the gain figures but color reproduction wasn't bad... I remember someone posting a "recipe" for a decent screen, I believe the top coat was Behr Eggshell White...
Don't know how much you're looking to spend, but here's a commercial product specifically designed for screens.
http://www.projectorcentral.com/Goo_Systems-Screen_Paint.htm
_________________ Thanks,
Ben
lexx21
| Posted: Tue Sep 29, 2009 9:29 pm Post subject: |
I'm kind of having to do this on a shoe string budget. I had looked at Goo systems, but they were pretty expensive.
dturco
| Posted: Tue Sep 29, 2009 9:39 pm Post subject: |
Foget paint it's not going to work, well not good anyway.
Check out the screen section. There's a couple of posts in it about, ahhhhh........Screens ..........
on the cheap.
http://www.hulu.com/firefly
| Posted: Tue Sep 29, 2009 10:47 pm Post subject: |
I'll try this again... I had a damn post written and the forum was in never-never land. Arrgghhh...
Anyway, if you have $100-150 to spend, check out WilsonArt Designer White laminate. It's about 1.3 gain, fairly rigid, easily mountable, and is about as good as a DIY screen gets.
If you're on a really tight budget, check out Parkland Plastics... Sometimes it's "Plast-Ex" or "PolyWall"... I think it's under $30/sheet and should be available from most home improvement stores or lumberyards, though you might have to call around. This is the white, shiny, pebble-surfaced stuff you see in gas station or bar restrooms sometimes, only for projection screen, you use the nice, smooth white back-side you don't usually see. I think it's about 1.1 gain or so. It's a little flimsy, so you have to use some cheap PVC or composite ranch trim or something on all four sides to hold it on the wall.
By the time you bought Behr paint and a good roller cover, I don't think you'd have much less in a screen than a PP screen.
jkruger
| Posted: Tue Sep 29, 2009 11:49 pm Post subject: |
| ecrabb wrote: | I'll try this again... I had a damn post written and the forum was in never-never land. Arrgghhh...
SC |
You use the back side? I used the front. Seems to work fine. It might give me a wider viewing angle than the back, not sure what the gain is like but it's better than the 1:1 pull down I was using.
Kiev Savoie
| Posted: Wed Sep 30, 2009 2:35 am Post subject: |
I have another option for you to consider as well. there's a guy on ebay that buys professional screen material in bulk rolls and sells it by the piece. He claims it's the same stuff Draper uses for a lot of their products. I bought a piece big enough to make a 4:3 120" screen for about $50. He included instructions on how to make a DIY rigid frame for it. It looks great, really improved my setup, has a 1.3 gain, it's easy to clean and cost me under $100 dollars all told.
| Posted: Wed Sep 30, 2009 3:04 am Post subject: |
Kiev,
Have you measured the gain on that screen? Draper doesn't sell a material with a 1.3 gain. If it's truly the same stuff Draper uses in a lot of their products, then it's like M1300, which is actually 1.0 gain. FYI.
If you have any scraps left over, I wouldn't mind comparing it to Wilsonart.
picree
Joined: 31 Mar 2006 Posts: 351 Location: Johnson City, TN
| Posted: Wed Sep 30, 2009 3:12 am Post subject: |
You asked about painted screens so,
For several years I had a painted screen. Here is the formula I used. I had the chance to buy a Stewart screen so I have that now but this worked great. You just have to be careful when rolling on the finish to get it even without roller marks. All Liquitex stuff can be bought at Michaels craft store.
I clipped this from the comments in my photo album here:
"Screen: the screen is just the drywall painted with Behr Premium Plus Interior Flat Ultra Pure White No. 1050. On top of that I used a version of the formula posted by algol on AVSForum on 01-22-03 "Mommy, Daddy's Painting the Screen... Again!" The formula was:
16 oz. Liquitex Basics Acrylic Gesso, white
8 oz. Liquitex Colored Acrylic Gesso, neutral gray
2 x 2 oz. Liquitex Concentrated Medium Viscosity Acrylic Artist Color, iridescent white
2 x 2 oz. Liquitex Concentrated Medium Viscosity Acrylic Artist Color, iridescent bright silver
2 x 2 oz. DecoArt Pearlizing Medium
If I remember correctly, that formula was for a DLP/Greyhawk-type screen. According to my notes I did not use the neurtal gray nor the iridescent bright silver. So my final formula was:
And I substituted one (or two...can't remember exactly) jars of 4 oz. of Liquitex Matte Medium and more white Gesso to make up for the omitted components. I would go with one jar of Matte Medium and if it didn't look thin enough then add one more."
The gain was about 1.3 by eye. I would NOT just use flat white since a gain of 1.0 would look dull and washed out. Heck, if this doesn't work just paint over it.
_________________ MAIN THEATER: (JVC RS2000; Yamaha UDP-LX500; Yamaha RX-V2400; Lumagen Radiance Pro, Vertex)
SECOND WII-ATER: (BG808; WII; Oppo 971H; Moome external box; BG-DVI transcoder; tse gamma box; Extron)
grogthegreat
Joined: 16 May 2007 Posts: 166 Location: San Diego, CA
| Posted: Wed Sep 30, 2009 5:27 am Post subject: Re: painted screen for use with a CRT |
I have used the Behr ultra white flat with a sony 1292 which is a pretty dim projector with a 96" diagonal with a 16:9. I found that with the picture was acceptable in a completely light controlled room. It wasn't as bright as I would have liked and this was in a perfectly dark basement at night but the picture was definitely watchable. It was bright enough to the point that no one else in my family noticed that it should have been brighter.
_________________ First projector: Sony 1252q with 3500 hours
Second projector: NEC 9PG+
current projector: Sony G90
100" 3:4 draper screen.
I must keep upgrading till the voices stop!!
"I CAN HAZ CRT PRUJEKTER."
-Curt Palme
lexx21
| Posted: Wed Sep 30, 2009 1:17 pm Post subject: |
Good information! I appreciate the feedback.
paw
| Posted: Wed Sep 30, 2009 2:07 pm Post subject: |
| picree wrote: | You asked about painted screens so,
The gain was about 1.3 by eye. I would NOT just use flat white since a gain of 1.0 would look dull and washed out. Heck, if this doesn't work just paint over it. |
Was there room in the Behr can for the extra liquid?
I wonder how well Behr is working theses days. Company's like to reformula their paint like every year. Which I've never understood - "If it ain't broke, why fix it?"
_________________ Aubrey
| Posted: Thu Oct 01, 2009 12:00 am Post subject: |
| dturco wrote: | Foget paint it's not going to work, well not good anyway.
on the cheap.  |
BULL$HIT.
I have a blockout cloth screen with Gesso rolled on (and a masking system).
I've seen a few commercial screens, and I've never thought mine was lacking at all.
| Posted: Thu Oct 01, 2009 12:37 am Post subject: |
I had good luck stretching fabric across a wall / piece of foam board when I was first playing around. Dig around in a craft/fabric store, or a superduper walmart if there's one near you, and you can usually find some fine-textured white fabric that'll work well. Blackout cloth can be far from white - the stuff I've seen is more beige - but you can find some pretty damn bright white fabric out there. Get stuff that's stretchy, too, and it's great.
I ended up with an electric Stewart ultramatte 130 for $-50, but that's not really something you can plan on.
picree
| Posted: Thu Oct 01, 2009 3:29 am Post subject: |
| paw wrote: | Was there room in the Behr can for the extra liquid?
I wonder how well Behr is working theses days. Company's like to reformula their paint like every year. Which I've never understood - "If it ain't broke, why fix it?" |
No, no, no! The Behr goes on first as a base coat! Then all the other Liquitex stuff is mixed and applied on top. The iridescent white and Pearlizing Medium stuff have mica chips in them (one or both I think) that give the finish a reflective appearance with about a 1.3 gain. If you use too much iridescent white you can get problems with color shifting but I had none that I could see or notice. The Gesso is to thin the mix. The final finish is VERY much like the old projector screens we used to have in school with a frosty finish...you know?
picree
| Posted: Thu Oct 01, 2009 3:38 am Post subject: |
| Mark_A_W wrote: | | dturco wrote: | Foget paint it's not going to work, well not good anyway.
on the cheap.  |
BULL$HIT.
I've seen a few commercial screens, and I've never thought mine was lacking at all. |
VERY much agreed Mark. I was very happy with mine. I did have one spot where there was a faint roller mark that could be seen on panning sky scenes but otherwise it had almost the same gain and pop that my Stewart screen has now. If I painted again I would have rolled left to right rather than up and down to better blend any roller variations. Otherwise it was very cool.
I will say though-painting on a cloth screen stretched on a frame is very tricky to get smooth and even-which is why it would be best to try to figure out a way to spray on iridescence and Gesso (never has worked AFAIK). That was why I painted on the wall and not on cloth.
Maybe we just need one big eight foot roller!
dturco
| Posted: Thu Oct 01, 2009 3:57 am Post subject: |
I don't think paint is the answer. It is too temperamental in application to get even responses for most people. Color shifting heavy roller lines and such, and an unknown gain when your done.
My screen is crap that I bought online. Its even but not nearly enough gain for a CRT. No I haven't measured it's reflectance it just looks dull.
The next thing I am going to try is the Wilsonart white laminate S/C posted about. Its relatively cheap, and once you build a frame for it if you don't like it, you can still use the frame for some cloth or actual screen material later.
| Posted: Thu Oct 01, 2009 4:14 am Post subject: |
| dturco wrote: | I don't think paint is the answer. It is too temperamental in application to get even responses for most people. Color shifting heavy roller lines and such, and an unknown gain when your done.
The next thing I am going to try is the Wilsonart white laminate S/C posted about. Its relatively cheap, and once you build a frame for it if you don't like it, you can still use the frame for some cloth or actual screen material later. |
You could also reuse the wilsonart as a counter top
dturco
| Posted: Thu Oct 01, 2009 4:24 am Post subject: |
| AnalogRocks wrote: | | dturco wrote: | I don't think paint is the answer. It is too temperamental in application to get even responses for most people. Color shifting heavy roller lines and such, and an unknown gain when your done.
You could also reuse the wilsonart as a counter top  |
Bringing this up are you?
haven't started any comparisons yet. My thought for the Wilsonart was it's $112.00, if I don't like the results I can cut it up and use it for 2-3 bathroom counter tops/ garage work bench/ potting shed/ later so it could be easy to re-purpose or use as intended. The Da-Lite screen however means I would have to unload it somehow. I see from Drag,mans post that it has been done but I like to see things with my own eyes not in writing by someone in an article touting his opinion. Of course if it were someone here it would lend a lot more credence to my feelings towards the results.
Edit I guess we're talking about the Draper M1300 Not a Da-lite. I could not find a Dalite M1300
| Posted: Thu Oct 01, 2009 4:27 am Post subject: |
One of these winter days I have to get some Willsonart. I did sample it and it looked good as compared to a standard 8 1/2 x 11 sheet of paper.
