My G90 Arrived Yesterday. --> I have a problem. Help!
Posted: Wed Sep 23, 2009 11:12 pm    Post subject:
CIR Engineering wrote:
Mark_A_W wrote:
How come the green doesn't have a (lightly) filtered C-element?
YEAH!!! WTF???
Does it just look green and the photo didn't get it?
Umm.... I thought G90s always have the lighter/brighter C-element for a better brightness spec... Don't they all have to have the green C-element replaced for HT duty for correct green primaries. Question
tri_joel
Posted: Wed Sep 23, 2009 11:20 pm    Post subject:
Tom.W wrote:
How much closer did you adjust the throw difference ? In my case it was about 11 inches. I maxed out my 808 raster without problem.
It was about 2 feet. But let me explain, the original position was too far back. If I maxed the raster with the lenses off, when I put the lenses on then the corners of the projected image were rounded and I couldn't focus them. I had the PJ on a cart, it didn't matter how close or far away from the screen.
Anyway, I didn't intend to hijack this thread.
www.vawinesnob.com
Posted: Thu Sep 24, 2009 12:09 am    Post subject:
YEAH!!! WTF???
The G90 green C element is about half as "green" as a fully filtered one.
The one in the photo appears clear.
I just thought it was odd.
Is the red "red"?
Posted: Thu Sep 24, 2009 12:15 am    Post subject:
dochlywd wrote:
I have to agree! The problem is, the customer was not properly advised on the importance of getting it set up by someone who knew what they were doing. Or the company that sold it to him ACTUALLY did do the set up and it's obvious that they had no idea what they were doing. Provided that there weren't any mounting distance constraints due to the room layout, these people weren't even aware of PJ Calc!!!! Totally incompetent and a dis-service to the HT community......what a shame. If you are going to order a tube or two, I would advise you to do so through Greg Eisemann. He has the best grade tubes at the best pricing available.
Congrats on the G90!!! You won't be disappointed!!!
Doc
overclkr wrote:
What is wrong with the setup? It looks ok to me........
If you don't think there is enough raster usage, you'll quickly find out if you go any further, your corner focus will suffer. If I remember correctly, that is about the raster usage I currently have.
Cliff
What Cliff said. I am not sure you can say they didn't know what they were doing. They may have had limited room to install the pj, but probably they were trying to make sure they had the sharpest image. A lot of people don't care about the loss in sharpness when maxing the raster, because you don't focus on the corner. This is a personal decision, so neither one is wrong.
Posted: Thu Sep 24, 2009 12:51 am    Post subject:
Yeah, I have a client with a Madrigal attached to a beam below cathedral ceilings. The projector can't be moved and neither can the screen... the throw distance is too long, but nothing can be done so we live with it. It's set up as best as possible.
betel
Posted: Thu Sep 24, 2009 1:03 am    Post subject:
Is the red "red"?
The image I posted is not a good representation for the color. In reality, the green is more evident although it is very light. The green on my G70 is noticably darker.
The red is very red.
Posted: Thu Sep 24, 2009 1:50 am    Post subject:
Ah, THAT'S what you guys were talking about... The photo! That was the automatic color balance in the camera... The flash coming back from the green-tinted c-element got balanced back to neutral. You can tell because the white flash on the lens mounting flange (where it actually would/should have been neutral) is all magenta... It's funny... I see stuff like that, and my brain balances it back without even thinking about it.
Here... I tweaked it back toward neutral on the mounting flange, and it made the c-element go back to pale green.
Original version...
 Filesize:  19.97 KB
 Viewed:  6728 Time(s)
Tweaked version...
 Filesize:  30.2 KB
Posted: Thu Sep 24, 2009 2:38 am    Post subject:
Ah, that explains it.
And yes Steve, your tweaked photo looks about right to me, maybe a touch light still, but close.
HaydnG90
Posted: Thu Sep 24, 2009 4:21 pm    Post subject:
C-element looks right to me. The OEM filter is REALLY light.
betel
Posted: Sun Oct 18, 2009 3:23 pm    Post subject:
Finally got the the replacement tubes & DALLAS chip installed and hung the projector. I've attached a few images showing the installation. You may notice my mod to the mounting bracket to allow a single person to hang a crt.
Those fasteners Sony used to attached the lenses suck. Two of the screws heads stripped when I removed them. I replaced all the lens fasteners with stainless cap screws.
Now to work on the registration to see how those replacement tubes are going to work out.
BTW: The replacement green crt's coolant color is noticeably darker than the original.
Just a bit of wear on the blue tube. Hopefully it won't be too noticable in the image.
 Filesize:  115.68 KB
 Viewed:  6547 Time(s)
All dressed up.
 Filesize:  49.23 KB
Moome card installed.
 Filesize:  104.42 KB
Lens mounted.
 Filesize:  102.25 KB
Bolted to the ceiling!
 Filesize:  110.25 KB
Ready to lift into position.
 Filesize:  112.04 KB
Modded lower ceiling bracket.
 Filesize:  111.65 KB
Modded upper ceiling bracket.
 Filesize:  102.95 KB
Comparison of G70 and G90 tube. What a difference 1 inch makes in size!
 Filesize:  134.08 KB
Posted: Sun Oct 18, 2009 4:43 pm    Post subject:
I LOVE your lift!
betel
Posted: Sun Oct 18, 2009 5:06 pm    Post subject:
Thanks for the compliment Craig!
Posted: Sun Oct 18, 2009 6:30 pm    Post subject:
I LOVE your lift!
Looks Familiar Wink
Those Lifts do make it sooo much easier, i put an Eye hook into the floor and attached the rope while i was on the ladder connecting the two halfs.
MikeEby
Posted: Sun Oct 18, 2009 6:58 pm    Post subject:
That is nice...I love my lift too...I think I've only used it twice in 7 years....Probably a good thing.
betel
Posted: Sun Oct 18, 2009 7:13 pm    Post subject:
I hope this is the last projector I ever have to install.
betel
Posted: Sun Oct 18, 2009 9:39 pm    Post subject:
Got a problem.
HDMI Source: BluRay-->PS3 (1080p/RGB)-->Onkyo Receiver-->Moome Card-->G90 C input (RGB)
I'm getting horizontal streaking. The B input is doing the same thing.
If I was using 5BNC input, I'd say I had bad cables/connections.
The Moome card didn't have a problem in the G70 I removed it from. Maybe the G90 mating connectors need cleaning. They have been unused for 10 years.
Interesting though if I set the G90 input to YPbPr there no problem but the overall image quality is poor.
Anyone seen this before or got any ideas what could be the source of the problem..
betel
Posted: Mon Oct 19, 2009 12:11 am    Post subject:
I watched a movie. It is obvious in between the streaking the G90 has the potential to display a fantastic image. The registration process is superior to the G70. Zone adjustment is almost unnecessary. With a little more effort, I should be ale to achieve perfect convergence across the entire image. Something I was never able to do with the G70.
The streaking problem is directly related to signal level. The more infomation displayed, the worse the streaking. During the closing credits the problem completey goes away. This makes me think this is a connections problem. Tomorrow I'l get some contact cleaner and clean the connectors.
Posted: Mon Oct 19, 2009 1:19 am    Post subject:
Go to service menu > Input Setting >Clamp h/c
betel
Posted: Mon Oct 19, 2009 1:48 am    Post subject:
Damn, it's fixed. You are good Craig!
So what is "clamp h/c"? It was on auto. Anything else I should know about menu setup?
