| Posted: Fri Sep 04, 2009 9:33 pm Post subject: |
| jetty wrote: | | Have not messed with any of the pots. The only thing I've touched is the green focus on the system board(?). |
I believe you mean on the deflection board. Do you know which board is the deflection board?
jetty
| Posted: Fri Sep 04, 2009 9:48 pm Post subject: |
Yeah the deflection board......the one on top that flips up.
| Posted: Fri Sep 04, 2009 9:50 pm Post subject: |
Can you post a pic of the green tube face(lens off) with a cross hair pattern at the resolution your using, along with some more room light so I can see the whole tube face along with the pattern?
jetty
| Posted: Fri Sep 04, 2009 10:00 pm Post subject: |
will do
jetty
| Posted: Fri Sep 04, 2009 10:24 pm Post subject: |
I went back to my blu ray player since it was already set up. This is 1080i > hdmi > hdfury2 > rgb.
My cable box looked just about the same at 480i and 720p. Can you see that very faint white line in the green bar? That's about how much of the picture I am missing.
| Posted: Fri Sep 04, 2009 10:31 pm Post subject: |
Try it with a PC, running standard timings (1024x768 for instance).
| Posted: Fri Sep 04, 2009 10:34 pm Post subject: |
Hit the phase button and post another pic with the full grid.
jetty
| Posted: Fri Sep 04, 2009 10:50 pm Post subject: |
I can't hook up a computer just yet. My pc has a dvi connection.
| Posted: Fri Sep 04, 2009 10:56 pm Post subject: |
Why do you not have a full screen? Also it looks like the phase is off. you should be able to move that grid over with phase.
jetty
| Posted: Fri Sep 04, 2009 10:58 pm Post subject: |
The previous owner had it set up for 16:9. I don't know how to get it back to full screen. I move the grid over but it disappears into the green bar
wallace123456
Joined: 14 Aug 2006 Posts: 2236 Location: Northwest VA area
| Posted: Fri Sep 04, 2009 11:26 pm Post subject: |
I'm not sure what you are missing. Post a pic with something from a regular input. If you have something like a DVE dvd, put up a test pattern from that.
edit: I looked an saw the original pic on the post. Post a pic of what the tube looks like when you try to move the image to center position.
wallace
_________________ Life Is Good, But BBQ Is Better! BBQ Competition Team
jetty
| Posted: Fri Sep 04, 2009 11:38 pm Post subject: |
Wallace, the image is missing on the right side. It's getting cut off for some reason. I can shift the image left and right and see that it's all there it just won't show up in the right hand edge.
The image is in the center position....
| Posted: Fri Sep 04, 2009 11:50 pm Post subject: |
| jetty wrote: | | The previous owner had it set up for 16:9. I don't know how to get it back to full screen. I move the grid over but it disappears into the green bar |
Are you moving it with phase adjustment or position adjustment?
jetty
| Posted: Fri Sep 04, 2009 11:55 pm Post subject: |
Trying both, neither work.
| Posted: Sat Sep 05, 2009 12:01 am Post subject: |
So your saying if you neutral the position setting and adjust the phase, the grid moves back and forth but disappears into the raster strip? Just using phase?
Try moving the blanking in on the side with the wide raster and see what happens.
wallace123456
| Posted: Sat Sep 05, 2009 12:14 am Post subject: |
Was the pj working fine before this?
wallace
jetty
| Posted: Sat Sep 05, 2009 12:15 am Post subject: |
oh geez, what a moron I am. As many times as I adjusted the blanking I don't guess I ever used the cntrl key to get the side blanking. I thought I had hit the cntrl key for every adj., but I guess I didn't on that one. Can't thank you enough guys for all the suggestions. Sorry for my error. UGH. Thanks mac, your suggestion made me think about it.
| Posted: Sat Sep 05, 2009 12:23 am Post subject: |
Thank God. This one was starting to piss me off. Glad its fixed.
wallace123456
| Posted: Sat Sep 05, 2009 12:30 am Post subject: |
| jetty wrote: | | oh geez, what a moron I am. As many times as I adjusted the blanking I don't guess I ever used the cntrl key to get the side blanking. I thought I had hit the cntrl key for every adj., but I guess I didn't on that one. Can't thank you enough guys for all the suggestions. Sorry for my error. UGH. Thanks mac, your suggestion made me think about it. |
ROTFLOL! Been there, done that!
But, good feeling to find out it was a "co-pilot" problem and not a pj problem.
Follow Curt's set-up guide http://www.curtpalme.com/NECPG_MechSetup1.shtm and you can't go wrong.
For me, I always go thru the entire set-up 2-3 times. Every time it gets better.
The final (fine tuning) comes from a professional calibrator to get color and blacks perfect. (I'm still trying to figure that out. )
wallace
jetty
| Posted: Sat Sep 05, 2009 1:26 am Post subject: |
Yeah, that's what I am using to do this wallace. I can't believe I didn't check that again. I put a couple of hrs easy on this. Thanks to all.
