Dropped HDM Marquee 9500LC
dturco
Posted: Mon Aug 24, 2009 12:08 am    Post subject: Dropped HDM Marquee 9500LC
Yeah iI dropped it I'm sure it never ever happened to anyone else. Laughing but now my red tube convergence will not go to the right on the tube face far enough. It is off the tube face on the left hand side, all other grids move fine. Machine is set to 90v 35h short retrace. The cardboard tubes with the copper windings are bent and broken but the wires are still intact and taped up. {wrapped around}.
http://www.hulu.com/firefly
Posted: Mon Aug 24, 2009 12:24 am    Post subject:
Does the center square move the red raster at all left and right? If so, I'd say you have toe in issues. Did you bump the tube while freaking out? The left right shift power supply on the H board is common to all three tubes, I've never just had one color fail.
dturco
Posted: Mon Aug 24, 2009 12:29 am    Post subject:
Yes the red does move left and right up and down. Bump the tube, yeah, I mean hell yeah. Toe in can cause the image on the tube face not to move far enough on the tube face?
Posted: Mon Aug 24, 2009 12:45 am    Post subject:
Be careful with those Coils they have high voltage on them!!! As best you can try to make sure they are put back together as close to how the were and make sure the ferrite core adjustment plug is still in each tube. If not you'll have issues. But if its all ok then use some super glue on the paper tube being careful not to get any on the area where the ferrite core should be(you may need to adjust it later). then afterwards get some heat shrink tubing to go over the tube and heat it up for a tight fit, this should keep it all in place. then I would do a initialization and start over from scratch.
dturco
Posted: Mon Aug 24, 2009 1:01 am    Post subject:
Thanks Nashou, Repairing [Tape job] was done while board was out.I have not touched it while in the Machine. The ferrite core? I guess I'll have to look and see if that is still there, I doubt it. The smaller board that is piggy backed on popped off too. I just put it back on. How do you adjust this ferrite core? And how do you know what it is doing? For what it's worth the picture is good I just moved the other grids over to match the red. I'm just concerned for the tube if the image is spilling off the side [ever so slightly} just enough to make the edges of the grid droop.
Also if you buy a spare board would it need to be adjusted?
Posted: Mon Aug 24, 2009 1:41 am    Post subject:
Dont allow the image to go over the edge of the tube you can Explode the tube!!!
Thats what those ferrite cores are fore they adjust the width of the raster!!! Get the image back into safe territory!!!
dturco
Posted: Mon Aug 24, 2009 3:02 am    Post subject:
Will Do!
Posted: Mon Aug 24, 2009 4:07 pm    Post subject:
Hello
Maybe you have the H yoke wires mixed up; at the HDM red is front-most, green in the middle, blue to the rear. Check those.
Posted: Mon Aug 24, 2009 4:27 pm    Post subject:
Don't worry about the coils. WHile they do adjust width, their range is minimal, and guaranteed they have nothing to do with your problem.
dturco
Posted: Mon Aug 24, 2009 5:15 pm    Post subject:
I did check all the wires to the HDM. All are correct. I also did a better tape job made the cardboard tubes straighter and I now have full, complete control of all 3 grids
Thank you Guys.
Posted: Mon Aug 24, 2009 8:47 pm    Post subject:
you need to put a label inside that thing now
WARNING: Previously owned by Dave Durco
Laughing
Posted: Mon Aug 24, 2009 8:49 pm    Post subject:
Laughing
Thumbs Up Thumbs Up Thumbs Up
nashou!!!!!!
dturco
Posted: Mon Aug 24, 2009 9:25 pm    Post subject:
Jeez If your going to fling Crap At least get my name right. Rolling Eyes
Posted: Tue Aug 25, 2009 3:11 pm    Post subject:
awww now don't be that way. You can't really post this and not expect a little crap. Wink
I also mis-read the thread, I thought you drooped the whole thing. Actually had a guy do that here, 3 mint 9" tubes imploded when it hit the floor.
dturco
Posted: Tue Aug 25, 2009 3:55 pm    Post subject:
I do recall that. Insurance paid out? I did expect a DROP of poo tossing. Laughing
Good catch on the "drooped" or did you miss type as well..... I wish I could have caught the HDM instead.
I not upset buy your comment dregen dragen dragman Laughing
Besides I hear there's a guy that can Rebuild these things in Colorado and somewhere up in Canada. Laughing
Is all in fun. Smile
Besides I can get a plaque made for me by the same people that made Kal's Electric Brewery plate.
This Marquee is
"Tested Tough by Dave Turco". Mr. Green
Posted: Tue Aug 25, 2009 4:23 pm    Post subject:
Dude, you DROP a 9500 l/c MP modded Projector and think NOBODY is going to give you crap????
Could do it..... not gonna.....
dturco
Posted: Tue Aug 25, 2009 4:28 pm    Post subject:
Come on, I did not drop the Projector. Rolling Eyes
The HDM dropped out of its cage and bent the little card board tubes. Nothing that hasn't been talked about here tons of times.
dturco
Posted: Wed Sep 23, 2009 9:41 pm    Post subject:
Update on the HDM.
Although it survived the drop and still works, it is apparently causing noise in the image on screen. So I ordered a new one from Curt.
Lat's face it, all of the little cardboard tubes were bent and broken, save 1. I have also found a couple of lifted [Transistors?] with broken solder on one leg. I can't solder, and even if I could, I wouldn't know if what I was soldering was the only problem.
So Curt to the rescue.
Price? Fair. I would post the price, but I am not sure about how curt feels about that.
So very Fair.
Edit: Also I have used HK Steve's strap technique on the cages to hold them in place. Has anyone done something that will hold the HDM in the cage while ceiling mounted?.
Posted: Wed Sep 23, 2009 10:42 pm    Post subject:
I just use a bungee cord till I'm done messing around Wink
dturco
Posted: Wed Sep 23, 2009 11:09 pm    Post subject:
So it's a permanent attachment then. Laughing
