AC for HT
hhlurker
Posted: Tue Aug 08, 2006 2:48 am    Post subject: AC for HT
Hi all,
I am looking for an air conditioner for my HT room. Size is 18'Lx12'Wx8'H. The Sony pj is pumping out alot of hot air and i would like to cool the room without adding too much noise.
Is a split system the way to go or has anyone installed a wall mounted one? Is there an easy and inexpensive way to accomplish this?
Any recommendations appreciated.
TIA,
jer
Posted: Tue Aug 08, 2006 4:00 am    Post subject:
Dont know if I can help you but you just nailed my theater exactly 18x12x8 ft high with a sony projector. I was looking at 2 piece air conditioners last week.
And my name is Jer.
Too weird.
Check out the 2 piece Panasonics. I've also has good luck with Carier and Fedders.
Posted: Tue Aug 08, 2006 4:04 am    Post subject:
check this out.
Split Ductless hvac.
http://www.mrslim.com/products/itemDetail.asp?ProductCategoryID=24&ProductSubCategoryID=140&ProductID=1488
Its a mitsubishi product.
Posted: Tue Aug 08, 2006 5:21 am    Post subject:
http://www.residential.carrier.com/products/ductfree/index.shtml
http://www.panasonic.ca/English/appliance/airconditioner/cs-mc12dkk.asp
There's a couple of the pages I was looking at last week.
Are you in a house or an apartment?
hhlurker
Posted: Tue Aug 08, 2006 3:56 pm    Post subject:
Thanks for reply guys.
Jer, Analog,
I live in a house in Canada. I've been eyeing the Panasonic Split Air, C9CKPG. Low price and low noise is what i'm looking for. I may try a portable first because they are alot cheaper.
Have you installed yours yet and which one did you get?
jer
Posted: Tue Aug 08, 2006 4:20 pm    Post subject:
Jer, Analog,
jer
I was already to buy then the weather cooled off. I was thinking of the Panasonic as well CS-MC12DKK 230 volt 2 piece with a quiet mode of 29dB
hhlurker
Posted: Tue Aug 08, 2006 4:39 pm    Post subject:
I think i will need one regardless of the weather. When you have a full room of 6 ppl watching a 14hr marathon(Star Wars Ep. 1-6) the Sony generates so much heat, it can get uncomfortable.
I will get some quotes today. Who knows i may bring home a portable to test out.
jer
Posted: Tue Aug 08, 2006 5:27 pm    Post subject:
Jer, Analog,
jer
I just looked up that model C9CKPG it's 8800 BTU my question to you is do you have this room closed off or is it open to the rest of the house? I ask because I have owned 8000 BTU window air conditioners that worked fine with my room, the hallway and maybe 1 back bedroom but if I had all the rooms opends up it just stayed on constantly and didn't cool enuff.
That's why I was looking at 12 000 btu/ On the other hand I may put up some insulation and drapes to close off the room from the rest of the apartment then I could go smaller or portable like you sugest. Guess it all depends on the weather this August and September.
cabinetguy
Posted: Tue Aug 08, 2006 5:53 pm    Post subject:
before you buy one of those disposable units check into a heat pump they are not as expensive as you might think and it will add value to your home
Runco 980,VP30,Panasonic RP62 w/gary's SDI mod.Pioneer elite into some AR's
Person99
Posted: Tue Aug 08, 2006 7:16 pm    Post subject:
I've been looking at doing this for awhile. Dual zoning your A/C may be a pain if you need lots of motorized dampers. For me, all that is upstairs is a gameroom, bathroom and the theater, so dual zoning only requires 4 motorized dampers and the only thing I have to install in a room is the thermostat. If I want to do it myself, I could do it for less than $500.
How much are these devices you guys are linking to? Also, don't you have an ugly in room unit with these?
hhlurker
Posted: Wed Aug 09, 2006 11:41 pm    Post subject:
The one im looking at is the Panasonic 8800 Btu Split Unit.
Cost is $1200 CDN and install is another $800 CDN or so.
The portables can be an eye sore but these split ones are pretty sleek.
http://www.panasonic.ca/english/appliance/airconditioner/cs-c9dkk.asp
jer
cabinetguy
Posted: Thu Aug 10, 2006 12:11 am    Post subject:
My aunt had a heat pump installed in her house for $1600 although your furnace needs to be heat pump ready the pumps themselves only cost about $600 and a new furnace would be about the same. There is a huge markup on this stuff if you get in touch with the wrong supplier.So if your handy this would be the way I would go as long as you already have a forced air system(ductwork).
Person99
Posted: Thu Aug 10, 2006 12:35 am    Post subject:
Hmmm, not cheap. Is that really less costly then putting your HT on a seperate zone? Seems that you could do that for about this amount or less and would be a more efficient and desireable set up. No?
Posted: Thu Aug 10, 2006 12:39 am    Post subject:
jer
Hey...custom paint job anyone? It would probably void the warranty but it would look nice in satin black.
I just did a little figuring the 12000 btu split model on 220volt uses about the same energy as the 10 000btu window air conditioner on 110volts. The split model must be more efficient . Cool ( no pun intended )
David Cox
Posted: Thu Aug 10, 2006 1:20 am    Post subject:
Take a look at the LG Art Cool systems. Looks good on the wall and well made too.
http://us.lge.com/products/category/list/home%20appliances_air%20conditioners_art%20cool%202006.jhtml
http://www.lgaircon.co.uk/product.php
Posted: Thu Aug 10, 2006 2:00 am    Post subject:
Ok now that's really cool.
Posted: Thu Aug 10, 2006 6:54 am    Post subject:
I watched a MRSLIM commercial last week and they provded a telephone number to get setup. Starting price was $2300! Sorry, the idea of living in the poor south was a complete joke .. again.
I once asked a mechanical company what it would cost to upgrade my current upstairs zone: $3,000. I asked him what it would cost to install a new zone if the upstairs didn't have a unit: $3,000. Seems that the bulk of the costs were the same. So, to get a 'real' AC unit to cool my upstairs is increasing.
I am sitting in a extra bedroom over a den. This zone is set to 75ºF and feels it at the thermostat, but is 5ºF warmer just outside the room with that thermostat and >5ºF in the room I am sitting in. Now, if the room with the thermostat is the coolest room in this zone and can't get <78ºF on warm days ... then this is the f-ed zone.
Why exactly are AC units so damn expensive in the first place? Its not like we are talking about serious technology here, or something invented yesterday.
Posted: Thu Aug 10, 2006 7:20 am    Post subject:
I think companies use their "pro" line HVAC to offset the cost of selling the low end consumer gear.
Posted: Fri Aug 11, 2006 2:28 pm    Post subject:
Note: Moved to the new "Home Theater Design & Construction" forum.
hhlurker
Posted: Wed Aug 16, 2006 2:13 am    Post subject:
The Panasonic was installed today and it's working as advertised.
It's very quiet on "Quiet" mode.
I'm surprised at how powerful this unit really is.
Cost is a bit high but comfort is worth it. Very Happy
jer
