Toe-In Trouble! Help Please?
lexx21
Posted: Mon Aug 03, 2009 2:55 pm    Post subject:
He moved his green tube?
atotaldoofus
Posted: Mon Aug 03, 2009 8:48 pm    Post subject:
Hi!
Thanks for the replies!
When I made that statement, I knew much less about the way a projector works, and what I was really remarking on was the fact that, when the warm-up full-white screen came on, there seemed to be an equal bit of "pure red" and "pure blue" each tilting up beyond the top corners of the white part. I did not know enough at that time to bring up the crosshair test pattern and to check that way. Sad So I don't know how big the change from then to now really might be...
Since I posted that message, yes, I have taken the lens housings off, in order to look directly at the tube faces as I set the rasters, and also so that I could clean the lenses. I haven't touched the actual tubes though.
When I reattached the lens housings, I made certain to put the lens spacers in the right spot, and that I put the right lenses over the same tubes they were originally on. I tightened the screws each until they felt tight enough but not too tight.
The only difference that I can think of off-hand was that the blue lens spacer was, when I first opened the case, upside-down. I turned it rightside-up.
I guess I could turn it upside-down again Question
Okay, thanks, bye!
atotaldoofus
Posted: Mon Aug 03, 2009 10:45 pm    Post subject:
Hi
I've re-read the DIY guide for the spring and rubber grommet mod and now that I've familiarized myself with the internal layout a bit more, it finally makes sense - and doesn't seem so hard after all Smile I think I was getting it mixed-up with a similar guide in the MoneyAss PDF that was a lot more complex... So anyway I'll just go that route!
I'll post again in this thread if it doesn't work out for some reason. Smile
