Another EAC3to GUI Plus Updated 5-31-2010
Goto page Previous  1, 2, 3 ... 9, 10, 11 ... 24, 25, 26  Next
MikeEby
Posted: Thu Feb 11, 2010 12:44 am    Post subject:
myrison wrote:
Hi Mike, sorry if I've missed this in the several pages leading up to this, but is it a known issue that attempting to use a source directory with a space in the name causes the GUI to fail? Example:
I usually rip all of my videos to Source file P:\Videos\Ripped Videos\Moviename
When I attempt to use this folder in the GUI, I get this error.
Code:
Source file "P:\Videos\Ripped" not found.  <ERROR>
It looks like it's just stalling out at the space in the directory name. Is this possible to be fixed in your code so that directories like this work as well?
Thanks!
Are you drilling down to the streams folder? "P:\Videos\Ripped\YOUR MOVIE NAME\BDMV\STREAM"
politby
Posted: Sun Feb 14, 2010 11:50 am    Post subject:
datman wrote:
My bad that was the wrong error picture Embarassed I was able to register the file on each computer, so I got that going for me.
this is the correct error
I am getting this "index and length must refer to a location within the string" error as well. I think it happens just before or when mkvmerge is started because what I end up with are the demuxed audio and video files in the working directory and I have no problem muxing them into an mkv manually with mkvmerge GUI.
Might be helpful to know that I am getting the exact same error when using the "eac3to and more" GUI, also apparently just before or at the start of the mkvmerge phase.
This is the output of the "show last eac3to run" command:
Code:
eac3to v3.17
command line: "C:\Program Files (x86)\Clown_BD_v0.75\eac3to\eac3to.exe" 4) -log="C:\Program Files (x86)\ACD\Another EAC3to GUI\log.txt"
M2TS, 2 video tracks, 2 audio tracks, 3 subtitle tracks, 0:43:16, 24p /1.001
1: Chapters, 4 chapters
2: VC-1, 1080p24 /1.001 (16:9)
3: VC-1, 480p24 /1.001 (3:2)
4: DTS Master Audio, English, 5.1 channels, 24 bits, 48khz
   (core: DTS, 5.1 channels, 24 bits, 1509kbps, 48khz)
5: DTS Express, English, 2.0 channels, 24 bits, 192kbps, 48khz
6: Subtitle (PGS), English
7: Subtitle (PGS), Spanish
8: Subtitle (PGS), French
and the full eac3to log:
Code:
eac3to v3.17
command line: "C:\Program Files (x86)\Clown_BD_v0.75\eac3to\eac3to.exe" "H:\BDMV\STREAM" 4) 1: "D:\mkvs\s03e04 - Chapters.txt" 2: "D:\mkvs\s03e04 1080p VC-1.mkv" 4: "D:\mkvs\s03e04 - 4 DTS Master.flac" 6: "D:\mkvs\s03e04 - 6  Subtitle.sup" 7: "D:\mkvs\s03e04 - 7  Subtitle.sup" 8: "D:\mkvs\s03e04 - 8  Subtitle.sup" -log="D:\mkvs\s03e04 - Log.txt"
Creating file "D:\mkvs\s03e04 - Chapters.txt"...
[s07] Extracting subtitle track number 7...
[a04] Extracting audio track number 4...
[s06] Extracting subtitle track number 6...
[v02] Extracting video track number 2...
[s08] Extracting subtitle track number 8...
[v02] Muxing video to Matroska...
[a04] Decoding with ArcSoft DTS Decoder...
[a04] Encoding FLAC with libFlac...
[a04] Creating file "D:\mkvs\s03e04 - 4 DTS Master.flac"...
[s08] Creating file "D:\mkvs\s03e04 - 8  Subtitle.sup"...
[s06] Creating file "D:\mkvs\s03e04 - 6  Subtitle.sup"...
[s07] Creating file "D:\mkvs\s03e04 - 7  Subtitle.sup"...
[a04] The original audio track has a constant bit depth of 24 bits.
Added fps value (24 /1.001) to MKV header.
Video track 2 contains 62252 frames.
Video track 3 contains 62251 frames.
Subtitle track 6 contains 578 captions.
Subtitle track 7 contains 507 captions.
Subtitle track 8 contains 507 captions.
eac3to processing took 17 minutes, 56 seconds.
Done.
No error messages in the log.
This is on Win7 Ultimate x64.
Great program, by the way. Much easier to use than "eac3to and more GUI" that I used to use.
MikeEby
Posted: Sun Feb 14, 2010 2:40 pm    Post subject:
It looks like you might not have a default language set in the options dialog. If not enter English in the Default Language text box, or what ever is your default langauge.
politby
Posted: Sun Feb 14, 2010 7:11 pm    Post subject:
Thank you, that was it! I put "English" in the language default field, and now it works perfectly.
MikeEby
Posted: Sun Feb 14, 2010 8:59 pm    Post subject:
I'll make English the default in the next release. It can always be changed by the user if they want a different language.
datman
Posted: Mon Feb 15, 2010 3:45 pm    Post subject: Something else I noticed
I have been seeing an audio sync problem, At the start of all movies converted by anotherac3to the audio is spot on and as the movie plays it becomes slightly off by the end it’s way off. It’s about a .5 second delay by the end of a 2-hour movie.
This might have something to do with me using BDrebuilder encodes as my source.
MikeEby
Posted: Mon Feb 15, 2010 3:48 pm    Post subject:
I use ReClock to even out lip sync issues. (32 Bit Only) it also helps with smooth motion. Once you install reclock you should watch a few movies and see if it fixes your problem.
http://forum.slysoft.com/showthread.php?t=19931
What player and OS are you using...32 or 64 Bit? What's BDRebuilder?
myrison
Posted: Mon Feb 15, 2010 6:55 pm    Post subject:
Code:
Thanks!
Thanks for the answer. Yes, I was drilling down to that folder. The issue is that the path is "P:\Videos\Ripped Videos\MovieName\BDMV\Stream," not "P:\Videos\Ripped\MovieName\BDMV\Stream"
If I change the path to take out the space and use RippedVideos instead of Ripped (space) Videos, it works fine. Obviously this is a workaround I can do on my own, but I thought you might want to review the code so that source directories with spaces included work without extra effort.
Thanks.
Jason
datman
Posted: Mon Feb 15, 2010 7:00 pm    Post subject:
I'm using Zoomplayer 6.0 and running vista32. BD rebuilder is a great program that re-encodes BD movies to your choice of sizes BD5,BD9 or BD25. http://forum.doom9.org/forumdisplay.php?s=ffa424950a431611ef4b6f1271ab6938&f=75
I never had this kind of an issue if playing from the ISO or original disc with PDVD8 or TMT3.
I installed reclock and playing the same movie and skipping forward to the end made no change, it was still out od sync. I'm letting it play and I will check every hour to see if it is buffered and possibly corrected.
MikeEby
Posted: Tue Feb 16, 2010 1:21 am    Post subject:
This is going to sound like the typical software developer question. Do mkv files have lip sync issues when you don't use BDrebuilder?
MikeEby
Posted: Tue Feb 16, 2010 1:22 am    Post subject:
Thanks.
Jason
Jason... I was able to duplicate that issue...I will try to get it fixed on the next release.
datman
Posted: Tue Feb 16, 2010 3:40 am    Post subject:
I'll re-rip and let you know. BDRB is great even if it is creating the sync issue. I'm still using it because it is the best (or so I have read) at encoding BD files. Most backups don't need lossless audio 448 ac3 is fine and archiving to a BD5 size is preferable. The handful that have great soundtracks I save to a BD25 and the HDaudio is untouched. These are the files I use anotherac3to on. The finish product is always small enough to fit on a much cheaper BD25 disc.
I'm still grateful to you for your program I have been having a lot of fun messing with it for the last few weeks. The benefit of lossless Flac audio is undeniable on certain movies.
okashira
Posted: Tue Feb 16, 2010 6:24 am    Post subject:
Try using AAC audio. Best of both worlds IMO. I haven't been able to detect the difference between any lossless original track, out of the few samples I tried, the FLAC'd version or the AAC (NeroAacEnc @ -q 0.50) encoded version at ~400kbps. AAC at ~400kbps will grossly outperform ac3 @ 448kbps.
Mike's next release just might include an option for AAC alongside FLAC. Wink
myrison
Posted: Tue Feb 16, 2010 1:50 pm    Post subject:
Thanks.
Jason
Great, thanks for confirming Mike.
Posted: Wed Feb 17, 2010 12:25 am    Post subject:
Mike, just some feedback about the standby issues.
With the latest version it seems to work fine, in that I set the batch running, went to the shed, and when I came back hours later the monitor was off and the job had finished successfully.
So, it's not going into standby in the mkvMerge stage anymore, and I don't think there are any monitor staying on when it shouldn't issues anymore.
Mark
MikeEby
Posted: Wed Feb 17, 2010 2:48 am    Post subject:
Mark
Thanks Mark, your tip on remuxing to a different drive has been a big hit too. With my fast AMD box I seldom see a MKV conversion take longer then an hour...Most are in the 30-40 minute range.
Posted: Wed Feb 17, 2010 3:22 am    Post subject:
That's about how long it takes me too (40mins)...If I do it command line and don't select any subtitles.
If I do select subtitles (or use your gui which does that), then it takes longer, maybe 1.5hrs. The subs really slow it down.
Anyway, it's no big deal, it hasn't caused an issue for me, and the one gui solution is well worth the extra time.
Mark
chadd
Posted: Thu Feb 18, 2010 11:09 pm    Post subject:
MikeEby wrote:
chadd wrote:
well, it looks like everything is working fine now.
just made a successful mkv of ratatouille.
what i ended up doing:
- uninstalled shark007 win7 and x64 codecs.
- uninstalled haali
- installed the newest shark007 win7 and x64 codecs and configured them
- noticed that shark was using the v1.9.63.13 of haali, so i installed the version that you posted
- that seemed to change what version the win7 codecs used, but it still lists the newer version in the x64 codec config, and the 1.9.42.1 in the x32 config... i'm no codec expert, so i'm not sure exactly how that is working, best guess is i currently have 2 versions of haali installed, one x32 and one x64
- reran another attempt at ripping ratatouille with your app and success!
let me know if you want any other info on what i did or have installed to help with the debugging/dev process, but i think that's all i did.
thanks much!
Great!...That's good info to know...I will probably note it on the original post and provide a link to the above version Haali.
Thanks for the help figuring this out.
well, just ran into the same problem i was having with 'ratatouille' when trying to rip 'run fat boy run'
exact same experience, same popup asking to manually select audio track with no audio tracks available to select.
i haven't changed any codecs/halli versions, etc since the successful ratatouille rip, and have ripped a few others successfully since then...
i'm stumped.
landchark!
Posted: Thu Feb 18, 2010 11:30 pm    Post subject:
I would just stay away from Codec packs.
Just install what you need.
MikeEby
Posted: Fri Feb 19, 2010 2:27 am    Post subject:
i'm stumped.
Download and install the version linked below, this is a version with AAC audio conversion I've been testing. Then click on Tools>EAC3to Info and paste the results here.
Also double check and make sure your default language is set, after you set it close the program then restart.
There was a problem where that was not being set correctly sometimes after an upgrade.
http://www.acdnow.com/AnotherEAC3toGUI/AnotherEAC3toGUISetupAACTest3.zip
BTW Here are my logs from Run Fatboy Run.
Code:
Analyzing .....started at 18:51:42
Analyzing complete
Starting EAC3To.exe
EAC3to Command Line arguments : "F:\BDMV\STREAM" 1) 1: "C:\Work Folder\Run Fatboy Run - Chapters.txt" 2: "C:\Work Folder\Run Fatboy Run 1080p VC-1.mkv" 3: "C:\Work Folder\Run Fatboy Run - 3 DTS Master.flac" 6: "C:\Work Folder\Run Fatboy Run - 6 English Subtitle.sup" -log="C:\Work Folder\Run Fatboy Run - Log.txt"
EAC3to complete
Looking for forced subtitles...
No flagged forced subtitles found, looking for other types of forced subtitles...
Likely forced subtitle not found...
MKVMerge Started...
MKVMerge Command Line arguments:  -o "e:\Movies 3\Run Fatboy Run.mkv"  "--default-track" "1:no" "--forced-track" "1:no" "--display-dimensions" "1:1920x1080" "-d" "1" "-A" "-S" "-T" "--no-global-tags" "--no-chapters" "C:\Work Folder\Run Fatboy Run 1080p VC-1.mkv" "--forced-track" "0:no" "-a" "0" "-D" "-S" "-T" "--no-global-tags" "--no-chapters" "C:\Work Folder\Run Fatboy Run - 3 DTS Master.flac"  "--track-order" "0:1,1:0"  "--chapter-language" "eng" "--chapters" "C:\Work Folder\Run Fatboy Run - Chapters.txt"
MKVMerge Done!
[URL=file://C:\Program Files\ACD\Another EAC3to GUI\Logs\EAC3to\Run Fatboy Run~12-2-2009 19_31 - Log.txt/URL]
Deleting work files...
Deleting C:\Work Folder\Run Fatboy Run - Chapters.txt
C:\Work Folder\Run Fatboy Run - Chapters.txt deleted.
Deleting C:\Work Folder\Run Fatboy Run 1080p VC-1.mkv
C:\Work Folder\Run Fatboy Run 1080p VC-1.mkv deleted.
All work files deletedÛTotal time 00:45:59
Code:
eac3to v3.17
command line: "C:\eac3to\eac3to.exe" "F:\BDMV\STREAM" 1) 1: "C:\Work Folder\Run Fatboy Run - Chapters.txt" 2: "C:\Work Folder\Run Fatboy Run 1080p VC-1.mkv" 3: "C:\Work Folder\Run Fatboy Run - 3 DTS Master.flac" 6: "C:\Work Folder\Run Fatboy Run - 6 English Subtitle.sup" -log="C:\Work Folder\Run Fatboy Run - Log.txt"
M2TS, 1 video track, 2 audio tracks, 2 subtitle tracks, 1:40:20, 24p /1.001
1: Chapters, 16 chapters
3: DTS Master Audio, English, 7.1 channels, 24 bits, 48khz
   (core: DTS-ES, 5.1 channels, 24 bits, 1509kbps, 48khz)
4: AC3 Surround, English, 2.0 channels, 192kbps, 48khz
5: Subtitle (PGS), Spanish
Creating file "C:\Work Folder\Run Fatboy Run - Chapters.txt"...
[a03] Extracting audio track number 3...
[a03] Decoding with ArcSoft DTS Decoder...
[a03] Encoding FLAC with libFlac...
[a03] Creating file "C:\Work Folder\Run Fatboy Run - 3 DTS Master.flac"...
[s06] Creating file "C:\Work Folder\Run Fatboy Run - 6 English Subtitle.sup"...
[a03] The original audio track has a constant bit depth of 24 bits.
Video track 2 contains 144333 frames.
Subtitle track 6 contains 2297 captions.
eac3to processing took 38 minutes, 59 seconds.
Done.
Page 10 of 26
