menec
| Posted: Sun May 24, 2009 12:28 am Post subject: |
Ok, I'm pretty desperate.
I wrote down the values of contrast and brightness to check if they stay the same and powered down the PJ. After returning from the video store I tried to fire up the 8500 again and it seems that it is dead now!
The unit won't power on anymore! The only thing it does is producing a high pitch noise which gets slowly higher and all the red LEDs on the CLM are blinking. No lights from the tubes, no picture and the only way to power off the PJ is to pull the plug. No reaction to the remote
What's going on here?!
| Posted: Sun May 24, 2009 9:00 am Post subject: |
| menec wrote: | Ok, I'm pretty desperate.
What's going on here?!  | blinking lights on CLM and failure to respond to remote sounds like a control module problem. BTW, don't pull the plug, it's bad for the machine. ?Use a paper-clip and push the little re-set button on CLM to power off.
| Posted: Sun May 24, 2009 10:12 am Post subject: |
I have seen that when the Deflection processor Board on the CLM is not on or if it's connector pins or the U7 chip on it has lost contact from oxidation. Try to clean all chips on the CLM and the DPB with DeOxit and after with Denatured alcohol. Especially the Contacts from the DPB to the CLM, if that does not do it then the solder joints on the connector to the two boards might need to be checked for cracks.
It sure sounds Like a CLM problem aside from the squealing noise which might be a side affect somewhere else in the machine as an result of the bad CLM/DPB.
menec
| Posted: Sun May 24, 2009 10:46 pm Post subject: |
Ok, I didn't have much time today so I quickly tried to fix the problem with DeOxit and I also checked the connection of the chips and the solder joints. No luck so far. But I'll have a closer look at the CLM board during this week when I have more time for testing.
Thanks for your help so far!
PS: Maybe it's important to note that the red lights on the CLM do not actually blink in sync but go from left to right.
| Posted: Mon May 25, 2009 12:09 am Post subject: |
| menec wrote: |
PS: Maybe it's important to note that the red lights on the CLM do not actually blink in sync but go from left to right. |
Hello
That is likely a problem in the control board or deflection processor, which is mounted on the control board.
WayneB
Joined: 24 Dec 2008 Posts: 113 Location: Victoria, BC
TV/Projector: Marquee 9500LC Ultra
| Posted: Wed May 27, 2009 1:43 am Post subject: |
| Quote: | BTW, don't pull the plug, it's bad for the machine. ?Use a paper-clip and push the little re-set button on CLM to power off.
Draganm, We have a lot of power failures each winter. We probably had 10 or more while watching our projector.
I have the electronics behind a Monster 5000 Power Conditioner and have it set to require manual turn-on of power after a power failure. What else can be done so that it is not "bad for the machine" on an 8500 (or 9500)?
| Posted: Wed May 27, 2009 2:15 am Post subject: |
I'm not really an expert on the subject but I know that rolling Brown outs are actually the worst. The power conditioner you have now should alleviate most of that power from surging through your set. To eliminate it completely you would need a UPS (Uninterruptible power supply ) which is a battery back-up but I'm betting one capable of driving the Marquee would be big and expensive.
WayneB
| Posted: Wed May 27, 2009 3:12 am Post subject: |
Yes, a UPS would work for the times when we are watching something (projector is powered on). I have an APC UPS for my computers that provides up to 600 watts. It was about $450. But it sends a signal to the computer to shut itself down gracefully. If connected to a projector, it would only delay the dropping of power by about 5-10 minutes. Lots of time if you are watching something to manually shut down the projector. No benefit if you are away from the projector and it is on.
Still, I have lost a Faroudja DVP-2200 and my Runco 980 Ultra to power failures this winter, so it is probably worth it.
Thanks for the input...
| Posted: Wed May 27, 2009 5:31 am Post subject: |
maybe what you really need is an emergency back-up generator for the whole house. I know the ones at Hospitals are driven by a Turbine engine and cost a million dollars. Does anyone make an affordable one for home use?
| Posted: Wed May 27, 2009 3:45 pm Post subject: |
| Nashou66 wrote: | Yep the Guardian line of NG powered generators work great and I think Home depot has them. in the few $K area cost wise.
Athanasios | that's really not that awful if your losing PJ's and expensive scalers to power failure.
menec
| Posted: Fri Jun 05, 2009 8:36 pm Post subject: |
Hello,
My unit is still not working Here is what I tried:
- Removed the daughter boards and cleaned all the connection pins
- Visually checked all the solder joints
- Removed all the socketed chips on the CLM and the daughter boards and cleaned them thoroughly.
- Replaced the two blue capacitors on the deflection processor board
- Visually checked the capacitors on the vertical deflection board (is that the one that drives the coils? ) but none is leaking
What I noticed:
- I tried to power up the unit without the stigmator daughter board in place. According to this page this should work, shouldn't it? Result was, that the unit did not even start to flash the error LEDs and switched itself off after about two seconds.
- The squealing noise (which gets higher and higher) comes from the vertical output board on the rear heat sink. The source of the noise seems to be in the lower part where all the capacitors are mounted
- I counted 17 tantalum (are those the little squarish, yellow guys all over the clm?) capacitors but I did not replace any of them
Is there anything else I can try or should I start replacing the caps?
menec
| Posted: Sat Jun 06, 2009 7:46 pm Post subject: |
Ok, I got a replacement CLM for the Marquee and with this board the PJ powers up again! Next step was swapping the deflection processor board. And with the old DPB the new CLM did not work anymore. So the problem seems to be a defect in the DPB.
I tried swapping the U7 chip and it's working.
So the problem seems to be some where else on the board.
Any ideas?
menec
| Posted: Fri Jun 12, 2009 10:36 pm Post subject: |
More and more problems are coming up
With the replacement CLM the PJ powers up fine, but I'm not able to change the Top/Bottom Key and Pin adjustments anymore (the same settings that were not saved correctly before the complete power-up failure). The sliders move but nothing happens on the screen.
Do you think this behavior is caused by the HDM (precisely by bad caps on the HDM)? Or which board is responsible for the Key and Pin adjustments?
menec
| Posted: Sat Jun 20, 2009 9:05 am Post subject: |
Ok, I checked the ribbon cables and they seem to be perfectly fine (not pinched or cut).
After that I exchanged all three boards on the rear heat sink but nothing changed.
Those are the settings that can't be adjusted anymore (neither with the old boards nor with the replacement boards):
-Vertical Skew
-Horizontal/Vertical Bow
-Top/Bottom Key and Pin
Any idea what could be wrong here?
menec
| Posted: Sun Jun 21, 2009 9:03 pm Post subject: |
I could fix the problem not being able to adjust the above mentioned settings! The culprit was the little cable connecting two pins on the Deflection Processor Board. The replacement DPB is completely identical to the non-working original board, except this cable. So I put the cable in place and am able to adjust all the settings again!
Next step will be replacing the yellow caps on the broken DPB to see if this fixes the blinking LEDs on the CLM. Hopefully with the new DPB also the settings are reapplied after powering down the unit (to finally fix the problem I started with )
I'll keep you informed. Thanks for all the help so far!
menec
| Posted: Sat Sep 19, 2009 3:36 pm Post subject: |
Ok, just to make sure I got this right: You say the problem with the ignored geometry settings could be related to the backplane? Hmm that's interesting.
The only board I did not swap in this PJ (besides the backplane) is the HDM, simply because I don't have a spare one. I was about to order new caps and try if recapping this board might help to fix it.
But if the backplane really could be the culprit this would cause a LOT of work to fix...
To sum it up: The PJ is in a working condition again, except that the problem with the ignored geometry settings I started with (from my very first post in this thread) is still present.
| Posted: Sat Sep 19, 2009 7:28 pm Post subject: |
Which CLM and DPB combo are you using now? is it the original CLM with the NEW DPB? I am not sure about the back plane thing but you never know, i doubt it though it was just me thinking out load.
if you did not change the HDM it could be that. I have to read the service manual to see what areas to look at on the hDM but if you still have control and the grids are moving then it should save, i say it could be a bad memory chip, on some CLM's(newer ones) there are leds that light up as writing is going on to the CLM, these are very small and on the CLM you can see then lighting up if you look into the slots near the CLM. this lets you know there is communication between the CPU and the memory I believe. I have to look again to see what color the LED's should illuminate for correct communication, now I am not sure all CLM's have this.
