kal Forum Administrator
| Posted: Sat May 16, 2009 2:42 pm Post subject: |
| fuzzybee wrote: | I work for a commercial and residential AV integrator, and we often work in houses where they just plain don't want the source device beside their display. If we want to use HDMI, we have to use baluns.
Unfortunately, our most recent job that we speced HDMI baluns on just flat-out didn't work. They worked fine to 100+ ft over 2x CAT-6 in our shop, but then didn't work over much shorter distance in the house.
I may contact you to check these out when they go on sale. |
No problems! 200' is not a problem. You can go longer if needed with repeaters. If there's interest we'll carry distribution stuff as well.
Hooty
| Posted: Wed Jan 06, 2010 3:00 pm Post subject: |
I wonder how much better these would perform if they used STP instead of UTP.
andrewhuculak@hotmail.com
| Posted: Wed Jan 02, 2013 4:57 am Post subject: Re: HDMI or CAT 5? |
I used the Monoprice units and Cat5 to get the signal up to our bedroom with great success.
Audiophile
| Posted: Thu Jan 24, 2013 4:35 am Post subject: |
I have used the Atlona products to send 1080 HD over cat 6 successfully (http://www.atlona.com). Our vendor at work installed them to send HDMI, RS232 control, and line level audio over a ~100ft single cat 6 cable. While I have not set up any test gear to see how well they work, the picture on the other end of the cat 6 cable appears to be free from errors. The key is to use something that is more than a simple balun for the best picture quality. It looks like kal's product would work this way as well. Although not always the case, the requirement of a external power supply generally means you are getting something more advanced than a simple balun.
I use a "high speed" BlueRigger 35ft HDMI cable with no issues in my theater. Anyone running more than ~50ft of HDMI should really consider something like the Blu-Wire.
_________________ JVC RS40U Screening Room
