KABOOM!!!
PiDD
Posted: Thu Apr 09, 2009 3:45 am    Post subject:
Did it get scratched?
Not as much as there is a film on it that wont come off.
Im such a monkey!!
Thx for the procedures if only they didnt come so late! Maybe Curt can update his procs?
Ridebreck
Posted: Thu Apr 09, 2009 4:02 am    Post subject:
km987654 wrote:
Thanks for the process. I am not sure that its too different to whats been suggested but again thanks. I guess there are worse things than being called a monkey!! Anyway whats wrong with monkeys??
Aside from the poo flinging thing, not much. Mr. Green
"Hooray Beer!!"
Posted: Thu Apr 09, 2009 9:28 am    Post subject:
Yes well there is that!!
Posted: Sun Apr 12, 2009 3:01 am    Post subject:
If you ever broke a tube unintentionally, you are a monkey. Very Happy
I am a monkey myself. But I wasn't trying to remove it from the LC assembly when I did it. I removed a complete LC assembly
from the Marquee but forgot and left one cable connected. The sudden yank in the wrong direction induced a hairline crack in the
glass and I didn't notice it. When I reinstalled the assembly later that day, the image (blue CRT) was dim and shaking around like
a reflection in a pond, accompanying by a hissing/arcing noise, and a few seconds later there was a bang as the neck snapped clean,
most likely caused by arc cutting or arc-induced thermal expansion at the cracked spot on the neck.
No, I wasn't happy about that. Fortunately I did have a spare.
CJ
Posted: Mon Apr 13, 2009 4:58 pm    Post subject:
Just to clarify...
I may be a monkey, but with a reason Smile This tube replacement is for a very (shall we say) demanding client. I like this guy a lot, but he appreciates it when everything goes perfectly all the time.
The reason this happened is because I wanted zero chance of damaging the rubber bellows. If I had damaged the bellows then there would have been a delay while I obtained new ones. This client does not like delays so I decided to remove the tube with the cooling chamber intact without touching the bellows.
This is also why I had the C element out, because I knew that the tube might implode even though I didn't think that it would. In any event, I wasn't going to remove the bellows and I wasn't going to soak the bellows in solvent either.
