KABOOM!!!
Posted: Tue Apr 07, 2009 7:38 pm    Post subject: KABOOM!!!
Kaboom went the P19CLP09 9500LC Ultra tube while I was trying to get it off the hardware. Shame really, this was an 8 green tube with little wear, but an ESPN logo burned in... would have been a good tube for someone who wanted to do a 2.35 set up though.
Oh well, so I don't get to sell the used tube. I'm putting in a G90 Boeing simulation tube for this Ultra... should be a big improvement.
MikeEby
Posted: Tue Apr 07, 2009 9:09 pm    Post subject:
Damn, you didn't get hurt I take it? I had a 25" CRT implode on me ones it was not fun...Glass everywhere!
Posted: Tue Apr 07, 2009 9:19 pm    Post subject:
bbfarmht
Posted: Tue Apr 07, 2009 9:22 pm    Post subject:
I'm not sure if its similar. But I work with tempered glass. On several occasions I have had the glass "blow up" in my hands. Normally its because i accidentally hit the edge on something. When tempered glass breaks it throws shards everywhere. I have gotten home and found glass in my boots.
Adam
Benjamin Franklin
JorisS
Posted: Tue Apr 07, 2009 9:27 pm    Post subject:
How does such a tube explode Shocked
MikeEby
Posted: Tue Apr 07, 2009 9:37 pm    Post subject:
In my case I was young and stupid.... The tube was in cold storage, I installed the mounting hardware before it came up to room temp... As it came up with the mounting band tight...KABOOM.... or as Leeloo say's "Big Badda-Boom!"
Posted: Tue Apr 07, 2009 9:44 pm    Post subject:
Aside from loosing a few years of my life after breathing in CRT dust, I am fine.
These tubes are siliconed in really really well. I tried and tried to get the tube out, but in the end the tube gave up before the silicone did. If I knew it was going to implode, I would have just started out with a hammer and saved some time Twisted Evil
Glass IS everywhere.
PiDD
Posted: Wed Apr 08, 2009 2:46 am    Post subject:
I did the same thing a few weeks past ... maybe I was a little too excited with a new (to me) green tube. It was the second tube after I bought a VDC rebuild that was really soft. I was pumped to get my new ultra sharp green. The only issue is that it was in a LC casing. I followed Curt's procedure but the hammer claws did me in!!
I know they are supposed to implode... and I guess it did but man it exploded too! Glass everywhere. It blew the front off the tube!
Scared the sh*t outta me ... so that took a few years off me and no telling what the phosphorus did.
Posted: Wed Apr 08, 2009 3:23 am    Post subject:
Bummer that you had the C element in when it happened Sad Did it get scratched?
Lucky for me I had removed the C element to try and cut through the silicone from the front as well. The one I imploded was just siliconed so well that I could not get it free. Even after it imploded I had a hard time removing the front of the tube. I wound up hammering it from the front until it cracked all the way and then pulling out the pieces separate.
Posted: Wed Apr 08, 2009 3:39 am    Post subject:
yeah the way its done in curts advanced procedures is not the best way now that we have a safe way to remove the bellow and C-element. What i did was to remove the C-element and Bellow. Cut out all the silicone around the tube. Then you can either soak around the tube with turpentine or go from the front of the tube face with a thin flat flexible knive and try to get it between the tube face and the anodized metal plate the the tube is siliconed to. Work it all around the tube face, once you get in far enough about 1/8 inch i took a thin screw driver or you can use some type of metal wedge and tap it into the fine gap you created with the knive. On one tube the knive was enough. one i had to let sit over night with turpentine and it popped right out.
PS :Craig you still coming through Buffalo are later this month?
Athanasios [/code]
1031
Posted: Wed Apr 08, 2009 5:37 am    Post subject:
This is how i removed those tubes from hardware.
1. drillet out that "grey stuff"
2. soaked silicone few days with brake cleaning spray
3. cuttet silicone seam away with small blade knife
 Filesize:  50.27 KB
 Viewed:  10612 Time(s)
 Filesize:  67.33 KB
DVDO VP-50
New hobby, Rally
Posted: Wed Apr 08, 2009 7:32 am    Post subject:
Athanasios [/code]
You couldn't get a razor blade in front of a Barco tube. Barco must have glued them in because even though there is nothing there the nothing sticks really well. You guys are lucky if you can get tubes out with a knife.
Ile
Posted: Wed Apr 08, 2009 8:13 am    Post subject:
It depend about Barco, all hardwares I have removed (B500, B800, B808, B1200) had room for Olfa cutter and nothing else wasn't needed.
Marquee LC tubes I cutted as much I could and then pressed tube out with 20 ton hydraulic press. Very Happy
I used thick mdf plate against face plate, so that pressure is even in larger area.
Posted: Wed Apr 08, 2009 8:33 am    Post subject:
Barco 1001 and 1100 9" Sony SD146A tubes are so tightly glued in that you cannot get a razor blade in to remove the tube. Ampro housings with the same tube can easily be removed with a sharp blade.
Posted: Wed Apr 08, 2009 8:51 am    Post subject:
At 9"Marquee tube, there were no room for blade.. Until that silicone was soaked while (turpentine or brake cleaner) Then with little pressure i was able cut tube out from hardware.
DVDO VP-50
New hobby, Rally
Posted: Wed Apr 08, 2009 8:55 am    Post subject:
Sony tubes have a glued on lens. I am not sure how that glue would react to turpentine?
Ile
Posted: Wed Apr 08, 2009 10:04 am    Post subject:
That white plaster between bell and front glass would probably soften and finally front glass crack under use, like when it's contact with glycol. It probably will dissolve even to water. Very Happy
Mechanical force (hydraulic press) could be your best bet. Bad thing is that Sony front glass is also thinner than MEC glass, so pressing peace should cover whole front glass.
Posted: Wed Apr 08, 2009 10:21 am    Post subject:
I had thought of placing a plate of some kind over the tube face and applying pressure to the entire front of the tube but a little to one side to push the tube out. On the other hand I came to the conclusion the best thing would be to replace the Barco housings with Ampro housings which the tubes can easily be reomved. The Ampro housings also have lens flapping and the mounting system allows you to remove one tube only if needed. With the current Barco system I have to remove all three tubes to get one out.
Posted: Wed Apr 08, 2009 10:53 pm    Post subject:
Pardon me for saying it, but you guys are a bunch of monkeys!
Let me explain a better way to remove a 9500LC tube from the LC assembly without harming anything.
You need a long drill bit that is small enough to easily sink into the space between the aluminum casting and the glass CRT,
touching only the silicone.
Put this long bit in a variable speed cordless screw gun and start drilling through the silicone, as many holes as you can, almost touching
each other. Be patient, it takes a while. Drill down until you encounter more resistance but not a bit past that point.
After you've completed your ring of nearly touching holes, insert a screwdriver or hex wrench that matches well to the size of the holes
you drilled, and start gently levering out the pieces of silicone between the holes.
Next, the removal: If you haven't already done so by now, disassemble the LC assembly until you have just the rear casting with the
tube in it. All the rest should be set aside.
Cut a piece of plywood or MDF or particle board or whatever else you have lying around, shaped to fit pretty neatly into the front of
the casting and touching the CRT face. You don't want a lot of gap between the edge of the block and the casting, because you want
to support as much of the CRT face as is possible.
This piece of wood you just cut should be thick enough that when you place it on the CRT face, at least a good quarter inch, or more,
is above the level of the casting.
Place the block on your workbench. Place the CRT and casting on top of the block, settling the block onto the CRT face. Now, get
out the clamps. Bar clamps are fine. Clamp both sides of the assembly to the bench with two or more different clamps. Tighten
them down to firm but not really tight. Every few minutes, give each clamp handle about a half turn, alternating from one to the other.
In a few turns and a few minutes, the silicone will give up and the tube will start to come out, UNDAMAGED.
I've done this a number of times and it's always successful. No problem at all.
CJ
Posted: Thu Apr 09, 2009 2:52 am    Post subject:
Thanks for the process. I am not sure that its too different to whats been suggested but again thanks. I guess there are worse things than being called a monkey!! Anyway whats wrong with monkeys??
