SONY VPH-1292Q STREAKING PROBLEM SOLVED
Goto page Previous  1, 2, 3 ... 5, 6, 7 ... 9, 10, 11  Next
Interested in purchasing upgrade?
Yes
79%
 79%  [ 39 ]
No
20%
 20%  [ 10 ]
Total Votes : 49
RogueChili
Posted: Mon Jul 27, 2009 3:13 pm    Post subject:
asubert wrote:
Dear all,
I see you did a great job on this topic.
Streaking problem is also my concern. I have drastically reduce it by lowering contrast and brightness, but it is still there.
I'm interesting in this mod, but there is some issue that make me hesitating:
1) I'm living in France, and I don't think about sending my parts oversea, that can take several weeks without my CRT
2) I have no technical knowledge. When I read the notice to demount board on the neck, it look a little hard for me. I've already use a welder, but i'm not sure if I would like to take the risk of burning the board, making my CRT dead.
But I'm very interesting if there is an easier way to do it. I will post a topic on french forum, to invite other sony's owner to visit this topic.
I think about one french guy that is very active in electronics mod for SOny (he did a and supply a sony IFB-DVI card for the community). He may be helpful.
THe noise reduction is also an interesting part of this work...
Hello asubert,
Good idea to find someone local to you that can install the modifications. Hopefully I will have a second version that will be much easier to install. More information regarding version two should be available within the next few weeks.
Regarding the modifications for noise reduction, I do not recommend these modifications at this time. Additional testing is required to be sure there are no hot spots that can damage any electronics. I recommend you refer to Grahams’ setup guide DVD, there is information regarding the reduction of noise in the 1292. Someone on this forum should be able to comment on the effectiveness of the mod.
Frenchman
Posted: Wed Aug 05, 2009 1:01 pm    Post subject:
Hello Good people!
I have been following all the posts on that subject with great attention. As I wrote earlier in this forum I have a 1292 with only 1300 hours, the image is just fantastic, have been able to display 1080p through the Moome card with great results, the 1292 is very, very sharp and the colours are nothing but wonderful. I am not worried about the lower light output as my screen is only 2m wide. Of course, like all the other owners of a 1292 I do have some streaking problems. I have to say I am not very literate with the CRT technology yet so please apologize my ignorance! I did voted yes and will definitely modify the boards, the tests look very promising this far!
I noticed that the streaking goes worst when playing at high frequency rates and when the room temperature is higher. I got my 1292 in February this year, barely noticed the streaking on DVDs, now playing Blue ray discs in the hot summer, the streaking is pretty bad! Crying or Very sad
Actually, how does the streaking builds up? Does anyone have an "easy to understand" answer? Very Happy
I am in the process of building a nice floor mounted hushbox with 2 separated inner walls and isolation and was thinking maybe adding some ventilation to cool the baby even more. My 1292 has Vantec low noise fans but when I compared with the original ones, I think they do not ventilate as much, maybe I would need to compensate the airflow with two 120mm extra fans. I've seen a very interesting fan design on this forum, very inspiring indeed especially relocating the neck board fans to the side!
Any help is very much appreciated!
Laurent from distant France
RogueChili
Posted: Sun Aug 09, 2009 12:59 am    Post subject:
It’s alive! The home brew amplifier is limping along however the output is crappy (technical term). The data shown on the scope is a single line (sweep) of data (line 122) of a 1080i RGBHV signal. The displayed data is a black background with the text “HELIOS” centered on line 128. The scope is connected directly to the output of the amplifier. Looking at IMG-0151 you can see the blanking pulse (if you can call it that) followed by video signal. Image IMG-0152 is a close up of the video signal; two problmes, the edges are slow(response) and an overshoot at the top and bottom of the signal; the signal should be almost flat at the bottom.
Not great but a start!
 Filesize:  107.04 KB
 Viewed:  9041 Time(s)
 Filesize:  45.95 KB
 Viewed:  12390 Time(s)
azzkicker
Posted: Mon Aug 10, 2009 6:34 pm    Post subject:
hi
i wait for this streaking mod soo long
but i think so with asubert
iam here in germany and sent my parts oversee takes a long time, and i have a long time no homecinema, this is the dead for me
the best way for me is sending the parts to me, i payed bevor and i need ecaktly instructions to put the mod an my neckboard
send me an pm i cant wait
best gereards
Frenchman
Posted: Wed Aug 12, 2009 7:11 am    Post subject: streaking
Hi there,
I live in France and I have no problem sending the boards, the fix is worth a few weeks wait! Honestly, once this issue is solved and the 1292 carefully placed on a vented hushbox with insulated double walls, the 1292 could well be one of the best CRT bargain around! Waiting for more good news.
Very Happy
EdoFede
Posted: Fri Aug 14, 2009 1:08 pm    Post subject:
Hello to all.
I'm interested for this modification too.
RogueChili, do you think that is possible to do a "DIY" version of the mod, once the problem of the waveform is solved?
Great work! Cool
Bye,
Edoardo.
RogueChili
Posted: Fri Aug 14, 2009 7:38 pm    Post subject:
EdoFede wrote:
Hello to all.
Great work! 8-)
Bye,
Edoardo.
Yes, my intention is to make a user installable kit.
I plan to send out a kit next week for the first user installation. This will be the original design only refined for easy installation. I’ll post the results of the installation when available.
azzkicker
Posted: Sat Aug 15, 2009 1:52 pm    Post subject:
yyeeahhh
i cant still wait for this great mod
regeards
1292 without streaking
RogueChili
Posted: Fri Aug 21, 2009 6:09 pm    Post subject:
azzkicker wrote:
yyeeahhh
regeards
Looking Good!
 Filesize:  16.66 KB
 Viewed:  12140 Time(s)
EdoFede
Posted: Fri Aug 21, 2009 6:41 pm    Post subject:
WOW! Very very good Cool
azzkicker
Posted: Mon Aug 24, 2009 5:38 pm    Post subject:
hi
in a few days i have the kit Mr. Green Mr. Green Mr. Green Mr. Green Mr. Green
then i bring the mod on my neckboards, and hope ich dont see the f*cking streaking
regards
Frode
Posted: Sun Sep 13, 2009 3:03 pm    Post subject:
Just joined the forum and will definitely buy the modification.
It's been too long since I got my degree in electrical engineering to follow all the details, but it all sounds reasonable so far. I've put about 3,000 hours on my 1292 since I got it and had actually started thinking about getting another projector due to the streaking, but now I will wait and see.
speedyandre
Posted: Sat Oct 10, 2009 10:16 am    Post subject:
It's a shame that this topic died Embarassed Laughing
I'm up and running again after moving home, the green neck board also gets dark Sad
I'll have a look at the fans because I think the problem is heat because it happens within an hour.
When my 1292 is off for 10 minutes the green tube works again but it gets dark soon then.
My blue neck board has the same problem, this was the first neck board I tried because of the short cables on it.
I want to move the rear fans of the neck boards to the sides to get the pcb's cooled better.
Maybe it has to do with the missing fans on the back corners but I doubt that because my standard neck board don't have this problem.
André
I'll be broke
RogueChili
Posted: Sat Oct 10, 2009 12:52 pm    Post subject:
Hi speedy, good to hear from you! I thought something happened during you move when I didn’t get replies to the PM’s I sent you.
The thread didn’t die; we are all waiting for you! Hope you can bear the pressure!
Regarding the problem you’re having, it is not clear to me how the modification is causing it and will need your help to understand it. We can continue troubleshooting via PM.
What I would like you to do, if you haven’t already, is disable the ABL circuit and see if that solves the problem. Let me know your results
As far as the missing corner fans, you should replace them as soon as possible. I have done extensive research on temperature control and can say with authority that the boards in that area run extremely hot.
speedyandre
Posted: Sat Oct 10, 2009 2:58 pm    Post subject:
I've never seen an abl jumper on a 1292, where can I find it or does it have a different name?
André
I'll be broke
RogueChili
Posted: Sat Oct 10, 2009 4:31 pm    Post subject: jumper
Remove the jumper from pc board shown in IMG_0568.jpg and install it to pc board shown in IMG_0570.jpg. After you move the jumper you will have to adjust the bias levels for RG and B. Remember to record your original bias values befor making any changes.
I recommend the following adjustment procedure as a starting point:
1) Select the input of choice then enter the service mode
2) Select <BIAS>
3) Select Cut off <B> and <G> ( only red enabled )
4) Select ADJ <R> ( enable red adjustment )
5) Select STATUS <OFF> ( eliminate interference from status text )
6) using <<> and <>> keys adjust the bias level so you can just see the diagonal red squares. There should not be any light, other then from the squares, visible on the screen.
7) Select Cut off <R> ( red disabled )
8) Repeat for G and B
9) Select <MEMORY> to save the adjusted bias values to memory
Notes:
Turn off room lighting during this procedure ( you should not be able to see any ambient room light on the screen- screen should look black ).
Be sure only one tube at a time is enabled during the adjustment procedure.
 Filesize:  20.79 KB
 Viewed:  11752 Time(s)
 Filesize:  18.8 KB
speedyandre
Posted: Sat Oct 10, 2009 5:01 pm    Post subject:
Thanks, I'll work on it tonight Wink
André
I'll be broke
speedyandre
Posted: Sat Oct 10, 2009 9:37 pm    Post subject:
My 1292 has showed a movie, including setting the bias it did run 2 hours without failing neck boards Thumbs Up
I think I can place the blue neck board too if it stays like this Smile
The streaking is invisible already Wink
André
I'll be broke
RogueChili
Posted: Sat Oct 10, 2009 11:18 pm    Post subject:
Yes, if you eliminate the streaking on any one of the tubes it becomes difficult to see the streak because it is no longer bright white and for the most part disappears in the background, under most conditions. The streak will still appear under certain conditions however and all three mod boards must be installed for the mod to work properly. Another issue is the time delay introduced to the video path by the mod board puts the signal out of phase with the other two signals. Theoretically this could cause a smearing effect.
What troubles me now is why the ABL circuit is failing. The mod does increase the video bandwidth slightly and knowing that a good deal of time was spent analyzing the ABL circuit. The conclusion was that there were no unwanted transient effects during the calculation of the beam cutoff current. The fact that disabling the ABL appears to solve the problem suggests there is a slight effect.
The EBRG board is where the ABL current is processed and it is possible that significant overheating of the boards is causing this problem by moving the ABL detection reference point slightly. The EBRG board is located in that area where you said the fans are missing.
I recommend you replace both fans before moving forward. Those fans force cool air over the EBRG board and into the neck board fans. Without them installed both the EBRG and the neck boards are going to get very hot and possibly fail at some point.
A good course of action would be to install the fans, complete the mod installation and verify it’s working properly with the ABL disabled. The next step is to enable the ABL circuit and see if the problem persists with the fans installed.
donaldk
Posted: Mon Oct 12, 2009 12:07 am    Post subject:
OT Rogue, how many tube do you have in stock, those CRTs only last 100 hours, fortunately twisting a new one in only takes two minutes a piece...
Page 6 of 11
