| Posted: Fri Apr 17, 2009 2:25 am Post subject: |
| macgyver655 wrote: | | stefuel wrote: | Mac will be proud of me. My new alien anal probe looks like it came straight from the mother ship, industrial strength and fused to boot. I told you that there were some here that were really out there and I'm one of them
Now it's time to study the schematic and make a list of test points. |
Hey, just dont be probing the neighbors................  |
Not even the big hootered dumb blonde next door??? Ohhhh the humanity...
_________________ Chip
| Posted: Fri Apr 17, 2009 10:43 am Post subject: |
OK I fell asleep last night studying the schematic for test points for the alien anal probe. Best I can figure, all inputs combine at pin 6 (input) IC 1 and outputs on pin 7. then the next logical test point looks like pin 6 (input) on IC 2 and outputs on pin 7 which is after VR 1 but before VR 2 which is the level pot. From there it's off to the amp section via ribbon cable lead #1 of 5.
VR 2 looks to have been replaced or at least re-soldered. If I have signal at lead 1 of the ribbon connector, I should be able to test the operation of VR 2 by listening for sound at lead 1 and adjusting VR 2 ???
I'm pretty sure this is all I need to confirm PCB 2
| Posted: Fri Apr 17, 2009 4:30 pm Post subject: |
Som-bitch, the alien anal probe has put me on the right track. I tried ribbon connection #1 and had no signal so I back-tracked until I did. I have signal to pin 6 on IC 1 (input) but not pin 7 (output) Why, brand new IC. I then re-checked votltage at pins 4 and 11. AhaaaaaaPin 4 should have +16 and pin 11 should have -16. Both have -16. Back to the schematic and trouble shooting flow-chart "with troubles on the 16V rail, check and replace as needed C5, C6, C7 and C8." My money is on C7 as that is next in line and right next to R2 which was one of the fried resistors. It looked physically fine so I left it alone.
| Posted: Fri Apr 17, 2009 6:01 pm Post subject: |
I'm paying attention, just awaiting your findings.......... if you get lost just let me know.
| Posted: Fri Apr 17, 2009 7:47 pm Post subject: |
| macgyver655 wrote: | I'm paying attention, just awaiting your findings.......... if you get lost just let me know. |
I'm lost, send up the beacon. I'm quite sure the problem is in the 16V rail on the + side. I've had problems in the past with NTE parts so I doubled up on my order I re-re IC'd the bitch with no better results. I think I'm reading -16 on both sides of IC 1 and 2 because it's back feeding through the IC's. If I pull IC 1 and 2 I only get -16 at one pin of the ribbon connector. I do have +16 at R2 and ZD1 and C39. I think something is open. I just can't find it.
| Posted: Fri Apr 17, 2009 7:57 pm Post subject: |
OK. One thing I want you to check real quick, just to eliminate it as the problem is R54, 10ohm. It should be on PCB-1. Let me know.
| Posted: Fri Apr 17, 2009 8:20 pm Post subject: |
| macgyver655 wrote: | | OK. One thing I want you to check real quick, just to eliminate it as the problem is R54, 10ohm. It should be on PCB-1. Let me know. |
OK will do just as soon as I finish adding the trace I missed on the burned section of the board
Pin/wire 3 on the ribbon connector is supposed to carry the +16V. It get's it's power from the +16 side of R2. A quick continuity test showed open circuit. It's real hard to see on the printed copy of the manual so I looked at page 34 component side on the PC blown up to 400% and sure enough, I missed it.
| Posted: Fri Apr 17, 2009 8:32 pm Post subject: |
Time to mount it in the cabinet for the real test.
| Posted: Sat Apr 18, 2009 3:22 am Post subject: |
Well I solved one problem but it's not finished yet. The issue with getting the signal to the amp is solved. The input/filter board now has signal on ribbon wire 1 to the main amp. Using the alien anal probe shows there is a clean signal to the amp. the filter is working as there is nothing but low clean bass at wire 1. However, when I installed the amp in the cabinet, hooked up to the speaker and to a input, I flip the power switch and the second the relay closes, I get what sounds like the nastiest feedback you ever heard. It does it with or without connection and with the level turned all the way down. There is one other place that I might have lost a hairline trace but I have to work tomorrow and don't want to get involved with something I can't finish. So I'll get back to it on Sunday.
| Posted: Sat Apr 18, 2009 3:28 am Post subject: |
89 posts for a lowly 10" woofer? I wonder what would happen if I posted about a double 18"?
Chip, send the manual to curtpalme@shaw.ca. 10 meg limit there though.
Put up some pic of the amp module. I wanna see what kind of parts the output section uses.
| Posted: Sat Apr 18, 2009 4:05 am Post subject: |
| Curt Palme wrote: | 89 posts for a lowly 10" woofer? I wonder what would happen if I posted about a double 18"?
Put up some pic of the amp module. I wanna see what kind of parts the output section uses. |
Nope, I'm going to finish this on my own. I couldn't stop thinking about it after the last post. Back to the PC and blow up the torched section of the board one more time. It looks like I missed another trace. The output of R3 goes in two directions. I repaired it but in only one direction. It's supposed to feed C37 and C8. I missed the trace to C8.
I hate trying to revive torched circuit boards with hairline traces. There's about a 1 inch square where the two big torched resistors were that is charcoal black. The Manual in printed form is useless for checking for traces. Only when you view it on the PC blown up to 400% can you even see it.
This is a case of a "just deal with it" electronics lesson. I've invested to much time in it to give up now and let someone else finish it.
I'm a stubborn bastard ain't I , but thanks for the offer
| Posted: Sat Apr 18, 2009 2:00 pm Post subject: |
"89 posts for a lowly 10" woofer? I wonder what would happen if I posted about a double 18"?"
Heywood Jablome
| Posted: Sun Apr 19, 2009 12:04 pm Post subject: |
Chip's rockstar name is "Tenacious C"
_________________ "Those countries which lag behind in industry, in the application of mechanics and technical chemistry, in the careful selection and utilization of natural products, where the respect for such activities does not permeate all classes of society, will unfailingly decline in prosperity. They will sink faster when neighbor states, with an energetic exchange between science and industry, go forward with renewed vitality."
| Posted: Sun Apr 19, 2009 11:22 pm Post subject: |
OK, I'll jump in now, Chip, forget the second email, you answered above.
If you can send me an audio clip of the noise, that would be good. I wanna know if it's motorboating, 120Hz hum, an open feedback loop somewhere or ??
Since the relay clicks closed, and you get a loud sound, we can assume that most of the amp section is OK. SInce however the volume control at 0 still produces the sound, then either the problem is in the amp section or the power supply driving the amp section.
You need to scope the main power supply. If you have no scope, you can meter it as well. If one side of the balanced power supply is say 2-3 volts lower than the other, you can assume that one of the big filter caps is open. A true balanced supply should be within about 1 volt of each other.
Another possibility is that an op amp has a missing feedback resistor, or it or the trace (most likely) is open. That causes exceptionally high gain of that op amp, and iit will oscillate.
For example, R19 and R25 are feedback resistors in the input stage, but I also see others in the power amp section as well. Measure those resistors across the pins of the IC, to make sure both sides of the resistor are making connections to the chip. Minor problem is, the chip and other parts might throw off the value of the resistor a bit. As long as you read the rated value of the resistor or lower, you should be fine.
Also, take the negative side of C24 and short it to ground. That will short out all signals coming from the input stage from getting to the power amplifier section, which starts at the base of Q 4.
Last thing: Take an old amp or receiver, couple the input 'hot' lead with a 10Uf, 100 volt capacitor to a test probe, connect the negative side to the amp chassis, and you've got a signal tracer, that allows you to feed signals of the woofer to another amplifier and speaker that you know works. You can then connect the capacitor to each output of each op amp to see where the noise starts from.
You're close...
| Posted: Mon Apr 20, 2009 12:19 am Post subject: |
Oh sure. Hop in now at the easy part. This was suppose to be a learning session for Chip..... Now your fixing it for him.....
| Posted: Mon Apr 20, 2009 12:51 am Post subject: |
I can hit delete..
I think most of my points are steering him in the right direction as to what part of the amp to look in depending on the sound the amp is making.
| Posted: Mon Apr 20, 2009 1:26 am Post subject: |
| Curt Palme wrote: | I can hit delete..
I think most of my points are steering him in the right direction as to what part of the amp to look in depending on the sound the amp is making. |
I'm just bustin your chops. I dont care.. Actually I'm kinda tired so if you want to finish up, thats fine with me...
| Posted: Mon Apr 20, 2009 1:28 am Post subject: |
I was going to say you can have sloppy seconds...but.....wait......I just said it.......
| Posted: Mon Apr 20, 2009 1:42 am Post subject: |
A well built woofer can take all you gots, and come back for seconds.
| Posted: Mon Apr 20, 2009 12:35 pm Post subject: |
The input to R2 and R3 which is just after the 10,000uf filter caps is less than 1/4 volt difference. I was going to test those caps but my meter is limited to 4,000uf. I'll check the other things mentioned after lunch. I have to clean the house for company later,
