kal Forum Administrator
| Posted: Mon May 04, 2009 3:58 am Post subject: |
| beun wrote: | | You actually may be able to seperate out the secondary windings on the transformer, if it is the small one I see in the bottom picture you probably just have the two 0 lines soldered to the same pin. |
Good point. It's all encased however, with 3 wires sticking out of the output side. I can't get at the windings at all.
So I finally got my second power supply and got a second transformer... hooked it up tonight, checked and double checked everything, then plugged it in and it all works like a charm.
<rant>
Silly meters from china will little or no instructions telling you to keep any power supply used by their voltmeter completely separate from anything else you may be powering....
</rant>
Thanks again for the tips guys. I'm glad I've been able to explain my way out of this problem. Nothing worse than something that doesn't work that you can't explain.
