Howe much is this 9500Ultra worth ?
MikeEby
Posted: Wed Mar 18, 2009 2:17 am    Post subject:
Curt....If you fall for this one you deserve a bitch slap. Mr. Green
Posted: Wed Mar 18, 2009 2:18 am    Post subject:
Elaine Benes wrote:
tri_joel wrote:
Well, I was going to bid but with the Olympic symbol burn and whatever that vertical line is on all three tubes, and the fact that I can't stand Bob Costas; I've decided to stick with what I have.
Superb eye !
Static images burned into tubes make them worthless.
This is a $500. machine.
That looks more like the Audi Quattro symbol to me though...
Yep, its audi.
Elaine Benes
Posted: Wed Mar 18, 2009 2:28 am    Post subject:
So, the local Audi dealership has a pj running in the showroom, 14 hours a day, one day it spot burns the tubes and goes out...several months later after the bulb projector has been put in its place, an enterprising salesman lugs it home and finds this forum as the first hit in his research on how much he'll be able to pull out of his freebee ?
tri_joel
Posted: Wed Mar 18, 2009 2:29 am    Post subject:
Yep, its audi.
I still can't stand Bob Costas. Exclamation
NewbieDAN
Static and spot burnt tubes.....
um $100 Rolling Eyes
Mike1272
Posted: Wed Mar 18, 2009 2:37 am    Post subject:
Including delivery to Bunbury !
insert witty remark here
dturco
Posted: Wed Mar 18, 2009 3:39 am    Post subject:
Dam I had to turn my monitor sideways to see that. You guys are GOLDEN EYE d Shocked
http://www.hulu.com/firefly
Posted: Wed Mar 18, 2009 3:51 am    Post subject:
THen it's a $500 set. I Went back and looked at the original pix, tubes are not as good as expected.
Posted: Wed Mar 18, 2009 3:56 am    Post subject:
I'll take it for 500, i can retube it cheap.
dturco
Posted: Wed Mar 18, 2009 4:02 am    Post subject:
It's good to be the TUBE king. Razz
Wink
nashou
Posted: Wed Mar 18, 2009 4:06 am    Post subject:
Keep yer tube's in yer pnatz
Posted: Wed Mar 18, 2009 4:18 am    Post subject:
Drinking again there analog? Very Happy
Posted: Wed Mar 18, 2009 5:04 am    Post subject:
Nope worked 18 hours or so, little tired ( why am I STILL on here? )
Lantz
Posted: Wed Mar 18, 2009 7:37 am    Post subject:
Hi guys,
Actually it's not an stealth advertising.
I just got the pictures from the seller, and wanted to hear what you think is could be worth.
Seller wants ~4000 US Dollar for it, inc shipping to me.
Also I wonder if the wear on the tubes are "bad" or nothing to worry about.
Tubes been runned for ~2000h + stby so if it's been used correctly the tubes should be like new with lots of life left.
Is there anything else that I should ask the seller about ?
Regards
Patrik
huggy
Posted: Wed Mar 18, 2009 10:29 am    Post subject:
Regards
Patrik
Yes,where can you get what he's been smoking? Mr. Green
Seriously though, 4k for something thats worth 500$?I would direct himto this thread and not offer any more than suggested here.
For that kind of money I'd be emailing curt and grabbing a nice 9"er with support and warranty.
NewbieDAN
Posted: Wed Mar 18, 2009 10:44 am    Post subject:
Lantz wrote:
Hi guys,
Regards
Patrik
From what I see the tubes are BAD.
The static burn of the Audi logo you 'could' put up with if you paid under a grand for the projector.....that's not the issue, the issue is that if the photos are indicating (as suspected) that the 3 lines a few millimeters long in the exact spot on the tube face are indeed a 'deflection burn' then all three tubes are completely useless, as in crap, cannot be used, destroyed, damaged, in need of replacement....the phosphor coating has been burnt off, the projected image will ALWAYS show a large vertical line. All three tubes need to be replaced, at nearly $1200 each.....not too mention what has caused the deflection burn...EVEN if you replaced the tubes, what guaranttee that the problem still exist.
This projector is not worth anything like $4k, it's a $500 parts machine at best.
As suggested, redirect your 'seller' to this thread.
Lantz
Posted: Wed Mar 18, 2009 11:30 am    Post subject:
Then I must say it was close, since I were about to make a deal...
I've looked at the tubes (pictures) and thought they looked good, but soon as I tried the color/contrast I saw the AUDI logo.
Where is the "deflection burn" on the tubes, since I've not seen it yet.
Is there a way to make sure that the hardware is OK ?
The seller is a guy from Germany, and I has had more projectors for sale on E-bay before.
This one is not listed and is the second one he has, the other had a almost same serial #
Will check the "tubes" with the color/contrast when I come home, cause I where about to buy the other one before christmas.
Guess I saved myself a fortune here...
Heywood Jablome
Posted: Wed Mar 18, 2009 11:56 am    Post subject:
Electron-beam sweep can sometimes fail in one direction only... meaning rather than paint a square, the e-beam turns into a laser that etches a line into the phosphor and thereby destroys the tube.
The root cause is always electronic, and would likely repeat with new tubes until the failure is fully and completely repaired. Tubes are expensive... I assume the 'tz' in your name means you are in Germany also?
Regardless, Curt is the person to be speaking to if you want a known good set with warranty and support, shipping to EU notwithstanding.
NewbieDAN
Posted: Wed Mar 18, 2009 1:02 pm    Post subject:
Page 2 of 3
