MikeEby
| Posted: Wed Mar 18, 2009 2:17 am Post subject: |
Curt....If you fall for this one you deserve a bitch slap.
| Posted: Wed Mar 18, 2009 2:18 am Post subject: |
| Elaine Benes wrote: | | tri_joel wrote: | | Well, I was going to bid but with the Olympic symbol burn and whatever that vertical line is on all three tubes, and the fact that I can't stand Bob Costas; I've decided to stick with what I have. |
Superb eye !
Static images burned into tubes make them worthless.
This is a $500. machine.
That looks more like the Audi Quattro symbol to me though... |
Yep, its audi.
_________________ Follow my blog
Elaine Benes
| Posted: Wed Mar 18, 2009 2:28 am Post subject: |
So, the local Audi dealership has a pj running in the showroom, 14 hours a day, one day it spot burns the tubes and goes out...several months later after the bulb projector has been put in its place, an enterprising salesman lugs it home and finds this forum as the first hit in his research on how much he'll be able to pull out of his freebee ?
tri_joel
Joined: 03 Jul 2007 Posts: 646 Location: Northern Virginia
| Posted: Wed Mar 18, 2009 2:29 am Post subject: |
I still can't stand Bob Costas.
NewbieDAN
Joined: 09 Mar 2006 Posts: 319 Location: Bunbury Western Australia
Static and spot burnt tubes.....
um $100
_________________ Sorting the fly sh*t from the pepper
Mike1272
| Posted: Wed Mar 18, 2009 2:37 am Post subject: |
| NewbieDAN wrote: | Static and spot burnt tubes.....
um $100  |
Including delivery to Bunbury !
_________________ insert witty remark here
dturco
| Posted: Wed Mar 18, 2009 3:39 am Post subject: |
Dam I had to turn my monitor sideways to see that. You guys are GOLDEN EYE d
http://www.hulu.com/firefly
| Posted: Wed Mar 18, 2009 3:51 am Post subject: |
THen it's a $500 set. I Went back and looked at the original pix, tubes are not as good as expected.
dturco
| Posted: Wed Mar 18, 2009 4:02 am Post subject: |
It's good to be the TUBE king.
| Posted: Wed Mar 18, 2009 4:06 am Post subject: |
Keep yer tube's in yer pnatz
| Posted: Wed Mar 18, 2009 4:18 am Post subject: |
Drinking again there analog?
| Posted: Wed Mar 18, 2009 5:04 am Post subject: |
| Curt Palme wrote: | Drinking again there analog?  |
Nope worked 18 hours or so, little tired ( why am I STILL on here? )
Lantz
| Posted: Wed Mar 18, 2009 7:37 am Post subject: |
Hi guys,
Actually it's not an stealth advertising.
I just got the pictures from the seller, and wanted to hear what you think is could be worth.
Seller wants ~4000 US Dollar for it, inc shipping to me.
Also I wonder if the wear on the tubes are "bad" or nothing to worry about.
Tubes been runned for ~2000h + stby so if it's been used correctly the tubes should be like new with lots of life left.
Is there anything else that I should ask the seller about ?
Regards
Patrik
huggy
Joined: 02 Aug 2008 Posts: 927 Location: Melbourne,Australia
| Posted: Wed Mar 18, 2009 10:29 am Post subject: |
| Lantz wrote: |
Regards
Patrik |
Yes,where can you get what he's been smoking?
Seriously though, 4k for something thats worth 500$?I would direct himto this thread and not offer any more than suggested here.
For that kind of money I'd be emailing curt and grabbing a nice 9"er with support and warranty.
NewbieDAN
| Posted: Wed Mar 18, 2009 10:44 am Post subject: |
| Lantz wrote: | Hi guys,
Regards
Patrik |
From what I see the tubes are BAD.
The static burn of the Audi logo you 'could' put up with if you paid under a grand for the projector.....that's not the issue, the issue is that if the photos are indicating (as suspected) that the 3 lines a few millimeters long in the exact spot on the tube face are indeed a 'deflection burn' then all three tubes are completely useless, as in crap, cannot be used, destroyed, damaged, in need of replacement....the phosphor coating has been burnt off, the projected image will ALWAYS show a large vertical line. All three tubes need to be replaced, at nearly $1200 each.....not too mention what has caused the deflection burn...EVEN if you replaced the tubes, what guaranttee that the problem still exist.
This projector is not worth anything like $4k, it's a $500 parts machine at best.
As suggested, redirect your 'seller' to this thread.
Lantz
| Posted: Wed Mar 18, 2009 11:30 am Post subject: |
Then I must say it was close, since I were about to make a deal...
I've looked at the tubes (pictures) and thought they looked good, but soon as I tried the color/contrast I saw the AUDI logo.
Where is the "deflection burn" on the tubes, since I've not seen it yet.
Is there a way to make sure that the hardware is OK ?
The seller is a guy from Germany, and I has had more projectors for sale on E-bay before.
This one is not listed and is the second one he has, the other had a almost same serial #
Will check the "tubes" with the color/contrast when I come home, cause I where about to buy the other one before christmas.
Guess I saved myself a fortune here...
Heywood Jablome
| Posted: Wed Mar 18, 2009 11:56 am Post subject: |
Electron-beam sweep can sometimes fail in one direction only... meaning rather than paint a square, the e-beam turns into a laser that etches a line into the phosphor and thereby destroys the tube.
The root cause is always electronic, and would likely repeat with new tubes until the failure is fully and completely repaired. Tubes are expensive... I assume the 'tz' in your name means you are in Germany also?
Regardless, Curt is the person to be speaking to if you want a known good set with warranty and support, shipping to EU notwithstanding.
_________________ "Those countries which lag behind in industry, in the application of mechanics and technical chemistry, in the careful selection and utilization of natural products, where the respect for such activities does not permeate all classes of society, will unfailingly decline in prosperity. They will sink faster when neighbor states, with an energetic exchange between science and industry, go forward with renewed vitality."
NewbieDAN
| Posted: Wed Mar 18, 2009 1:02 pm Post subject: |
