Upgrading an 8500LC to 9500LC - what's needed?
Posted: Thu Mar 19, 2009 6:41 pm    Post subject:
Mike here are the data sheet pics.
What can you get from theses mike? I can ask Aferg what Voltage the Triton 1080HD projector used for the HV supply value.
But like I said before he did mix and match Lug's and thomas tubes in that Projector.... so can LUG's take 40KV?
Posted: Thu Mar 19, 2009 7:20 pm    Post subject:
Ok you say they bloom at 60, I notice the same with the regular LCP's maybe closer to 63, but witht he franken yokes i got better results with the LCPs
I was able to go to 70 with no blooming and about 75 where it began to be noticable. But i did not see Bens focus problems. But i also did not check
on a screen jsut on the tube face wearing sunglasses at a contrast of 50 and they were just as sharp as the LCP red i was comparing it to in the same PJ.
I cant go recheck now as I took that tube apart to give Dale the bellow from it. But i will be willing to try the HV test on a used Thomas tube i
have(have about 9 ). Mike is there any issue to the VNB's with the extra 5Kv?
Posted: Thu Mar 19, 2009 8:18 pm    Post subject:
Ok I got this email back from Aferg, i was wrong about mixing and matching tubes... I couldn't remember
exactly , they just used a VNB that had jumpers depending on what tube set that PJ had, but he said you could mix and match if you want to(that was a question I asked in the past, and that is what i was referring to). It was the same HVPS power value in the Triton 1080HD PJ.
Here is the E-Mail
Aferg wrote:
Hi Athanasios,
We use the same HV supply for both tubes set between 34 and 35KV. No,
we didn't mix the Panasonic and the Thomas tubes, but I'm not saying you
can't. We had a video neck card that would work with either just by
changing jumpers. The jumpers only changed the CRT pin arrangement.
The blooming he is describing is the true Raster getting larger or is
the video being saturated? If the Raster is getting larger the HV would
be going lower. But, if the HV is staying the same voltage when this
occurs, then I would say the issue is the video amps. Do you have this
same problem in your projector?
I didn't see this when I tested the two tubes in my Marquee.
Aferg
So Ben it might be those VNB's according to Aferg, and Jarmo you may just need to tweek your mods a bit more
on the HVPS, remember you did a few resistor changes to stop the over drive on the blue, but it was the VIM did you go back to the original resistors? or it might be the CPC magnets , but I am sure you have those ok.
Athanasios,
Posted: Thu Mar 19, 2009 9:02 pm    Post subject:
Here is the E-Mail
Aferg wrote:
Hi Athanasios,
Aferg
Athanasios,
I'm a bit perplexed here. If a CRT is rated for 40KV, then it needs 40KV to function properly!
I know that's the case with the Panasonic tubes and that's why the later version HVPS had an 9KV increase for anode.
I have a precision HV probe that plugs into my Fluke meter for digital readout. It is rated at 40KV. I use it to measure and make sure I'm getting the proper HV readings, and make sure the voltage is stable even when increasing drive on the tubes. This is part of a complete test, with the rest requiring test patterns to detect bloom.
Now, there are two different types of blooming. One is when you increase the contrast and there are lines or text in the image that gets FAT. The other is when the image expands beyond the raster. It is also known as image expansion.
One type of blooming can be related to the video chain, while the other is HIGH VOLTAGE related (expansion).
The one where the image expands is usually caused from dipping in the HIGH VOLTAGE or lagging when the drives are increased.
The lagging or dipping you're not going to see on any of the commercial sets because they are usually well regulated at whatever voltage they put out. This lagging was also seen in the 34KV supplies used in the early 8000/9000 Marquee supplies. It's not a problem at all on the later versions. It could be seen when one of the multiplier diodes would be failing.
With the later version Marquee HVPS, I doubt you'll see expansion blooming, so the type of blooming would more likely be text/line blooming. Which If using 40KV tubes on 34Kv supplies would make this problem more obvious.
Let me dig through and research this from my Marquee data on this...
Posted: Thu Mar 19, 2009 9:42 pm    Post subject:
Mike these are not 40KV tubes, Aferg confirmed that in his E-Mail, and looking at the second sheet i have (did not take pic of it) it lists how the test are to be preformed. There is no mention of 40KV I will retype the second Sheet.
Notes:
1. The Cut off voltage is the grid No. 2 voltage required for visual extinction of an undeflected focus spot. This
is accomplished by adjusting the Grid 2 control with a fixed Cathode voltage applied.
2. The line width is measured at the center of the CRT, Both Horizontally and vertically using the merged line method.
3. Area brightness of a raster having the size indicated and the measurement taken with a photometer with a photometric
response curve. The photometer acceptance area is sufficiently large to measure several adjacent scan lines.
4. Is the peak or instantaneous value at the stated condition.
5. Is the difference between the recorded cutoff voltage and the voltage at the indicated conditions.
6. Normalize for a -50VDC grid one via reduced G2, with anode set at 20 KVDC, and raster fully scanning the phosphor area.
maintain 0 bias for less than 5 seconds.
7. Each CRT shall be subjected to a 4 hour minimum D.C. spot knocking prior to test.
8a. With heater voltage supply "off", connect the 9M198 to the test console. Set G2=0.0V, G1=0.0V, K= +250V.
Spark Trap shall be grounded for test.
b. Observe the Grid 1 leakage meter. The measure leakage should be 0:A
c. Turn the heater voltage supply to 6.3V.
d. Observe the Grid 1 leakage meter. The maximum leakage current allowed during the first 2 minuts of operation for a cold
start shall be 3:A. Record as S/SU on data sheet.
9. Set voltages and currents as follows. Burn-in to be performed for the maximum hours listed.
Set Anode voltage t 30.0KV
Set Focus voltage to GROUND
Set G2 voltage to 500VC
Set Filament voltage to 7.5V
Set Anode current to 200uA
10. When setting the 1500uA level apply a 50% duty cycle blanked signal.(This would be an on-time of 26uS for a standard 525 line raster.)
Set Anode current to 750uA. This approximates the drive conditions of 1500uA @ 100& duty cycle.
This is what the data sheet says for the test proceeders of the test records in the pics i posted.
Not sure if it helps.... I'll make sure from Aferg if these are definitely 34kv tubes.
EDIT: if you look at the pic of the data sheet you'll see on the right bottom of one pic 34 twice,
its in a column that has Eb2 and KVDC under the Eb2. I think that is the KVDC for the tubes.
Posted: Thu Mar 19, 2009 10:03 pm    Post subject:
I got that from a previous thread here:
1031 wrote:
Hello Mike. Datasheet says: 40Kv (max) and testreport says that they use 34Kv during "test run" Hmm, i have HVPS from M8000, maybe i test if that 900volt difference has something to do with blooming.
Anyway, here's something from the Marquee Appendix on Blooming:
BLOOMING - The defocusing of regions of the picture where the brightness is at an excessive level., due to enlargement of spot size and halation of the fluorescent screen of the cathode-ray picture tube. Most noticeable at the edges of images on a CRT, "blooming" is when the light (colour) is so intense that it seems to exceed the boundary of the object. Thin lines and sharp edges could look thick and fuzzy. This may be caused by the brightness being set to high, or by a high voltage problem.
Posted: Thu Mar 19, 2009 10:34 pm    Post subject:
Yepp I bet that is it for jarmos issue , in a PM he was telling me about how he was trying different resistors in his HVPS, not sure if its related but it could be?
I and Aferg did not notice any problems, Aferg has used them more extensively that me but during my testing and also the testing of the 1292 coils they seemed to be fine.
I wish i still had the tube in an assembly, id swap it into the marquee now as I am curious . Smile
I also sent Aferg another E-mail asking if he thinks these could possibly perform better at 40KV than the standard 34 KVA he is running them at, and if that would do any harm to the other boards at the higher voltage.
Thanks for the info Mike !!
Posted: Fri Mar 20, 2009 12:49 am    Post subject:
That's interesting. I wonder how well they would work in a AmPro at 36KV?
Blorton
Posted: Fri Mar 20, 2009 1:25 am    Post subject:
Holy Threadjack, Batman!!! Mr. Green
Posted: Fri Mar 20, 2009 6:36 am    Post subject:
Athanasios,
Athanasios, that blue issue what i had was related to my vim, it picked some hf-noise to blue channel, so iīm runnig with pretty much standart 2035-02p vim right now. Firts i suspected that it was tube, then those hvps resistors on G-2 section..But it was vim issue and it was not overdrive, backgroung had elevation when picture had much blue. That is solved now.
Magnets are now "spot on"
OK now scary part Shocked I have 40KV rated hv-probe and iīm going to test if i got say 38-39KV out of older HVPS that i have here.
If that jumper at HVPS will give proper range of HV, i adjust it about 38KV and going to test that HVPS with those thomas tubes and see how much there is difference.
And to Blorton, sorry that this thread is "little" off topic now
DVDO VP-50
New hobby, Rally
Posted: Fri Mar 20, 2009 8:05 am    Post subject:
OK. THIS IS SOMETHING THAT YOU SHOULD NOT TRY IF YOU DONT HAVE EXPERIENCE AND PROPER TEST GEAR!!!!
Here are results, HV selection jumper at 40KV position-> No hv out (probably different control pcb is needet. Not clm, that one that is inside of HVPS)
I started with measuring hv and hv regulation (pictures shows that there is no variation between Min/Max contrast.So regulation works perfect.
Then i tested what is max voltage that can be taken out of HVPS. It goes up to 38KV and if i try adjust that higher then there is OVP that limits it.
OVP was set to trigger at near 36KV when i tested that. Now it limits HV to 38.250Kv so there is not much room between Max HV/OVP trigger point, only 250v.
So this evening iīm gonna test how that old M8000 hvps vith 38Kv out works with those thomas tubes..Wish me luck Laughing
 Filesize:  41.56 KB
 Viewed:  7948 Time(s)
 Filesize:  36.4 KB
 Filesize:  36.79 KB
DVDO VP-50
New hobby, Rally
Posted: Fri Mar 20, 2009 11:05 am    Post subject:
There is that 40KV at Max section(inside red circle), test is done HV at 34KV
 Filesize:  54.16 KB
 Viewed:  7931 Time(s)
DVDO VP-50
New hobby, Rally
Posted: Fri Mar 20, 2009 11:47 am    Post subject:
Right Jarmo, but i think that is just a maximum that the tube will handle and not what it should be run at. Aferg has them set for 34.9 KVA on the old PJ they used.
And here they ran tests on them from 20KV up to 30 KVA if you look on the second sheet describing the tests , and the results are recorded on the first page. I think the 34 KVA below the 40 KVA is what they are finally to be used at. But try them at the 38 KVA and see what happens, maybe its too much and 34 is the correct value? I did not see the blooming problem on my VNB i used for the test and neither did Aferg. But i need to put on in and have a closer look, but i did use a magnifying glass to see if i could see the individual lines that are in each grid line and they were there up to 50 for sure and still there to 60 IIRC.
But i would be interested in your experiment !!
1031
Posted: Fri Mar 20, 2009 12:39 pm    Post subject:
That might be true, but didnt they used some kind special focusyoke also? Maybe lower HV needs stronger magnetic field to get good focus....But i let you know how those run at 38Kv. Lets see what is results ( beware that i may need set of new tubes after my tests Mr. Green ) Hope not..
DVDO VP-50
New hobby, Rally
Posted: Fri Mar 20, 2009 1:06 pm    Post subject:
yes but those focus coils were also used on the LUG's as well, so i dont think that is it. Aferg also told me the focus yoke had about the same gauss just that they were encased in stanless steel to isolate the magnetic field.
Just run a red or blue i have a few more of those extra. Disconnect the HV leads for the other tubes when testing so you only possibly toast one. Very Happy
Blorton
Posted: Fri Mar 20, 2009 4:09 pm    Post subject:
Oh, I'm not complaining! This is a great discussion. Very Happy
Posted: Fri Mar 20, 2009 6:08 pm    Post subject:
Hello.. Iīm still alive and so is marquee Thumbs Up
Ok i started testing by measuring HV at my main HVPS, it was 35Kv. Then i installed second HVPS that was adjusted to 36KV and connected only red, raster was smaller, about two inch horizontal and little less at vertical.
Blooming seems to start little higher contrast numbers and there is more brighness also focus needet readjust to lower.
So mike was right higher hv seems reduce blooming..But if i think to use higher Hv voltages then i run out of size control and also focus range is going to be problem.
So iīm going to put my main HVPS back and live with this little issue and wait those Frankenyokes to arrive Smile
Btw. while i was there, i measured resistanse at HV-splitter: From M8000 in-> out connectors 22Kohm and splitter from 97 7500 (8110) There was 3,3Kohm.. In theory that makes little more hv drop at high beam currents (older splitter)
But mine seems to be ok.
DVDO VP-50
New hobby, Rally
Posted: Fri Mar 20, 2009 6:29 pm    Post subject:
did you try using the lower ohm splitter on the higher voltage HVPS? and Vice versa?
1031
Posted: Fri Mar 20, 2009 6:43 pm    Post subject:
I used that 97 m7500 splitter (3,3Kohm) with both testīs. That should be better because that dont let HV to drop so much that 22Kohm one does at high beam currents .
DVDO VP-50
New hobby, Rally
Posted: Mon Mar 30, 2009 1:11 pm    Post subject:
here's something on the Thompson tubes that were being used in the early Marquees.
Marquee 9000 with Thomson CRT Replacement
Recently, Electrohome has changed the manufacturer of the CRTs used in Marquee 9000 series projectors from Thomson of France to Panasonic. The intent of this bulletin is to inform our customers what to do should CRT replacement be required on units originally equipped with Thomson CRTs. These projectors are identifible as part number 38-P13091-93. Electrohome is maintaining stock of Thomson CRT service assemblies. While supplies last, Thomson CRT service assemblies can be ordered with the following part numbers:
03-000242-01P Red CRT Bulkhead Service Assembly (Thomson)
03-000242-02P Blue CRT Bulkhead Service Assembly (Thomson)
(yes, the -02 is indeed blue)
03-000242-03P Green CRT Bulkhead Service Assembly (Thomson)
These service assemblies come with installation instructions for qualified service personnel and are recommended when replacement of one CRTs is necessary. Should the replacement of two or all three Thomson CRTs be deemed necessary, Electrohome recommends changing the three CRTs to Panasonic.This is the less expensive alternative and also ensures future CRT service assembly availability and avoids having to make the change to Panasonic CRTs at a later date when Thomson CRTs may no longer be available. A mixture of Thomson and Panasonic CRTs on a single projector is not allowed. That is, a Marquee 9000 projector must have either three Panasonic CRTs (and a 34 kV high voltage power supply) or three Thomson CRTs (and a 40 kV high voltage power supply). All of the CRT bulkhead service assemblies for the Marquee 9000 come complete with deflection yokes, convergence coils, magnetic focus coils, etc. They do not come with Video Neck Boards (VNB) or Lenses. In the case of direct Thomson to Thomson replacement, simply reinstall the old VNB(s) and lens(es). If replacing Thomson CRTs with Panasonic CRTs, only the lenses are reused.
If replacing Thomson CRTs with Panasonic, you must order the following parts:
1 - 03-000254-01P Red CRT Bulkhead Service Assembly (Panasonic)
1 - 03-000254-02P Green CRT Bulkhead Service Assembly (Panasonic)
1 - 03-000254-03P Blue CRT Bulkhead Service Assembly (Panasonic)
3 - 03-270300-07P Panasonic VNB (Video Neck Board) Marquee 9000
1 - 03-000234-01P 34 kV HVPS (High Voltage Power Supply)
3 - 39-001596-01P VNB Foam Supports
continued...2
3 - 34-001236-01P FCC Ground Wire
1 - 54-007987-05P Instruction Sheet Thomson To Panasonic 9000 Conversion
The 03-000254-XXP and the 03-270300-07P service assemblies contain instruction sheets that supplement the 54-007987-05P instructions that you must order. As well, we ask that you please return the original 40kV HVPS to Electrohome.
Page 2 of 3
